The following workflows describe how to configure SL1 and PowerFlow to work with the "Jenkins" SyncPack.
Configuring SL1
- Enable the Jenkins event policies
- Edit the Jenkins run book actions
- Enable the Jenkins run book automations
Configuring PowerFlow
- Create and align a PowerFlow configuration object
- Configure the Jenkins PowerFlow applications
Configuring SL1
The following topics cover how to set up your SL1 instance to work with the "Jenkins" SyncPack.
Enabling the Jenkins Event Policies
The "Jenkins Automation" PowerPack includes 11 event policies that you can enable to trigger the events detected by the applications included in the"Jenkins" SyncPack and its associated automation action policy.
To enable the event policies:
- Go to the Event Policies page (Events > Event Policies).
- Click the check boxes for all of the "Jenkins" event policies. A row of buttons appear at the top of the list.
- Click . The Status for all 11 policies is updated to "Enabled".
You will need to create a SOAP/XML credential in SL1 so that the action policies included in the "Jenkins Automation" PowerPack can access your PowerFlow system. The PowerPack includes the "PowerFlow Jenkins" sample credential, which you can edit for use with your PowerFlow system.
- Locate the "PowerFlow Jenkins" sample credential, click its icon (
), and select Duplicate. A copy of the credential, called "PowerFlow Jenkins copy" appears.
Editing the Jenkins Run Book Actions
The "Jenkins Automation" PowerPack includes eleven following run book action policies. These action policies use the "Run Integration Service Application" action type to trigger the corresponding PowerFlow application that collects data from Ansible. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
Enabling the Jenkins Run Book Automations
The "Jenkins Automation" PowerPack includes eleven run book automation policies that you will need to enable. These policies update the SL1 event with the state of the associated Jenkins job. When a node is offline, a failure occurs, or a major event is detected in Jenkins, SL1 creates an event and updates the associated event with relevant job details.
- Locate a"Jenkins" automation policy and click its wrench icon (
- Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the Jenkins automation policy you selected in step 2, and click the arrows to move it to Aligned Actions.
- Repeat steps 2-4 for the remaining "Jenkins" run book automation policies.
| Jenkins Node: Healthy | Jenkins: Healthy Event | Jenkins: Event Update |
| Jenkins Node: Major | Jenkins: Major Event | Jenkins: Alert |
| Jenkins: Job Pending | Jenkins: Pending Event | Jenkins: Event Update |
| Jenkins: Job Failure | Jenkins: Major Event | Jenkins: Alert |
| Jenkins: Healthy | Jenkins: Healthy Event | Jenkins: Event Update |
| Jenkins: Trigger | Jenkins: Trigger | Jenkins: Trigger |
| Jenkins: Trigger Healthy | Jenkins: Healthy Event | Jenkins: Event Update |
| Jenkins: Trigger Job Pending | Jenkins: Pending Event | Jenkins: Job Pending State |
| Jenkins: Pipeline Job Failure | Jenkins: Major Event | Jenkins: Alert |
| Jenkins: Pipeline Job Healthy | Jenkins: Healthy Event | Jenkins: Event Update |
| Jenkins: Pipeline Job Pending | Jenkins: Pending Event | Jenkins: Job Pending State |
The following topics cover how to set up your PowerFlow instance to work with the "Jenkins" SyncPack.
Creating and a Configuration Object
For this SyncPack, you should make a copy of the "Base Jenkins Configuration" configuration object, which is the sample configuration file that was installed with the Jenkins SyncPack.
The "Base Jenkins Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Jenkins settings.
To create a configuration object based on the "Base Jenkins Configuration" configuration object:
Click the button (
) for the "Base Jenkins Configuration" configuration object and select Edit. The Configuration pane appears.
- jenkins_url. Enter the URL for your Jenkins system.
- jenkins_username. Type the username for your Jenkins system.
- jenkins_password. Type the password for your Jenkins system.
- job_name. Type the name for your Jenkins job.
- receiver_mail. Type the email address that you want to receive updates on SL1 events and your Jenkins jobs.
- sender_mail. Type the email address that you want updates on SL1 events and your Jenkins jobs to send from.
- sender_mail_password. Type the password for the sender email address that you entered.
- mailserver. Type the server for your sender email.
- mailserverport. Type the port for your sender email.
- node_device_class_id. Type the device class ID for your Jenkins instance.
- job_device_class_id. Type the device class ID for your Jenkins job.
- guid_node_major_event. Enter the GUID of the SL1 event policy.
- collector_group_id. Type the collector group ID for your Jenkins instance.
- device_id. Type the device ID for your Jenkins instance.
- guid_job_major_event. Enter the GUID of the SL1 event policy.
- guid_job_trigger_event. Enter the GUID of the SL1 event policy.
- guid_pipeline_job_major_event Enter the GUID of the SL1 event policy.
With this SyncPack, you can create SL1 events based on Jenkins jobs. You will need to align the Jenkins SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
). The Configurations pane for that application appears.
Click to align that configuration with the application.
Repeat this process for the other PowerFlow applications.
To trigger the applications in the SyncPack, you must schedule the PowerFlow applications that are included in the SyncPack.
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple SL1 instances or multiple Jenkins instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Jenkins instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Jenkins instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
