The following workflows describe how to configure SL1 and PowerFlow to work with the "Opsgenie" SyncPack.
Configuring SL1
- Edit the Opsgenie run book actions
- Enable the Opsgenie run book automations
Configuring PowerFlow
- Create and align a PowerFlow configuration object
- Configure the Opsgenie PowerFlow applications
Configuring SL1
The following topics cover how to set up your SL1 instance to work with the "Opsgenie" SyncPack.
You will need to create a SOAP/XML credential so that the action policies included in the "Opsgenie Incident Integration" PowerPack can access your PowerFlow system.
The "Opsgenie Incident Integration" PowerPack includes the "PowerFlow Opsgenie" credential, which you can use as a template for a SOAP/XML credential.
- Click the wrench icon (
) for the "PowerFlow Opsgenie" credential. The Credential Editor modal window appears. - Complete the following fields:
Editing the Opsgenie Run Book Actions
The "Opsgenie Incident Integration" PowerPack includes five automation action policies. These action policies use the "Run Integration Service Application" action type to trigger the PowerFlow application that sends and receives data to Opsgenie. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
- Locate the "Opsgenie automation action that you want to use and click its wrench icon (
Enabling the Opsgenie Run Book Automations
The "Opsgenie Incident Integration" PowerPack includes five standard automation policies that you will need to enable.
These policies update the Opsgenie alert or SL1 events with the state of the associated event or alert, create a maintenance object, or populates SL1 with on-call details. When the event is first detected in SL1 or Opsgenie, the "triggered" state is sent. When the event is acknowledged in SL1 or Opsgenie, the "acknowledged" state is sent. When the event is cleared in SL1 or Opsgenie, the "resolved" state is sent. When the on-call policy is triggered, on-call details are added to the SL1 event notes. When a maintenance object is required, a maintenance object is created in Opsgenie.
If you enable the "Opsgenie: Acknowledge Alert", "Opsgenie: Resolve Alert", and "Opsgenie: Trigger Alert" automation policies, it is best practice to align the same devices for all three policies.
| Opsgenie: Acknowledge Alert | All events | Opsgenie: Acknowledge Alert |
| Opsgenie: Maintenance | All events | Opsgenie: Maintenance Alert |
| Opsgenie: Oncall Trigger | All events | Opsgenie: Oncall |
| Opsgenie: Resolve Alert | All events | Opsgenie: Resolve Alert |
| Opsgenie: Trigger Alert | All events | Opsgenie: Trigger Alert |
- Locate an "Opsgenie" automation policy and click its wrench icon (
- Repeat steps 2-4 for the remaining "Opsgenie run book automation policies.
The following topics cover how to set up your PowerFlow instance to work with the "Opsgenie" SyncPack.
For this SyncPack, you can make a copy of the "Opsgenie Config" configuration object, which is the sample configuration file that was installed with the "Opsgenie" SyncPack.
The "Opsgenie Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Opsgenie settings.
To create a configuration object based on the "Opsgenie Config" configuration object:
Click the button (
) for the "Opsgenie Config" configuration object and select Edit. The Configuration pane appears.
- opsgenie_api_key. The API key for the Opsgenie Team that you want to send alerts to. You can generate an API key for SL1 to use in the Integrations page of the Opsgenie user interface.
- opsgenie_univ_api_key. The universal API key for Opsgenie. For information on adding an API key in Opsgenie, see https://support.atlassian.com/opsgenie/docs/api-key-management/.
- proxy_host. The hostname or IP address of the HTTP proxy that will be used when making an API request to Opsgenie.
- proxy_protocol. The protocol of the HTTP proxy. Enter either 'HTTP' or 'HTTPS'.
- sl1_host. The hostname or IP address of the SL1 system the alerts will synchronize to.
- schedule_name. The name of the on-call schedule on Opsgenie to query when collection the current on-call user(s).
- maintenance_description. The description of your Opsgenie maintenance.
- maintenance_policy_id. The ID of your Opsgenie maintenance.
- maintenance_time_length. The time configuration of your Opsgenie maintenance.
- maintenance_state. The state rule defined in maintenance.
- device_id. The SL1 device ID that the Opsgenie Heartbeat application will use when sending alerts. Typically, this is a device that represents the Opsgenie service.
- heartbeat_name. The name of your Heartbeat URL.
- opsgenie_base_url. The base URL of the Alert Rest API.
- opsgenie_private_instance_url. The URL to use for links to the Opsgenie user interface. Enter the base URL you navigate to. This URL will be displayed in SL1 and will open your Opsgenie instance in a browser.
- resolve_from_org. The option to resolve events from Opsgenie
- default_ack_user. The default user to acknowledge events and alerts.
- populate_external_url. The option to add an Opsgenie incident URL to the corresponding SL1 event.
With this SyncPack, any status changes made to an SL1 event is sent to Opsgenie to update the corresponding alert. Any status changes to the Opsgenie alert are synced back to the corresponding SL1 event. You will need to align the Opsgenie applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- "Bulk Clear SL1 Events"
- "Create Opsgenie Maintenance"
- "Get Oncall Details From Opsgenie and Send to SL1"
- "Opsgenie Heartbeat"
- "Pass Acknowledgment details from Opsgenie to SL1"
- "Close Opsgenie Alert"
- "Save Accounts To Cache"
- "Create Alert in Opsgenie from a received SL1 event"
To trigger some applications in this SyncPack, you must schedule the application. If you want to use the following applications, you must schedule the application. ScienceLogic recommends that you schedule the following PowerFlow applications:
- "Bulk Clear SL1": Every minute
- "Opsgenie Heartbeat": Every 5 minutes
- "Pass Acknowledged Alerts from Opsgenie to SL1": Every minute
- "Save Accounts To Cache": Every hour
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple SL1 instance or multiple Opsgenie instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Opsgenie instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Opsgenie instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
