This ) of the PowerFlow user interface to import, install, and view SyncPacks.
PowerFlow and SyncPack content not created by ScienceLogic is not supported by ScienceLogic. This includes custom steps, PowerFlow applications, and SyncPacks.
What is a SyncPack?
A SyncPack contains all of the code and logic needed to perform integrations on the PowerFlow platform. A SyncPack is saved as a Python .whl file, and it typically includes Python steps that are listed in PowerFlow applications and shipped with one or configuration objects:
You can view the latest steps, applications, and configurations for PowerFlow or a third-party integration, such as ServiceNow, by downloading the most recent SyncPack for that integration. You can download SyncPacks from the PowerPacks & SyncPacks page at the ScienceLogic Support Site at https://support.sciencelogic.com/s/powerpacks (login required).
You can access all SyncPacks that have been uploaded to your PowerFlow system on the SyncPacks page of the PowerFlow user interface.
A SyncPack is highly customizable, and you can modify the contents of a SyncPack to meet your business needs, instead of changing your SL1 configuration. You can categorize and segment your business integration solutions using a SyncPack.
SyncPacks let you distribute content to simplify installations, upgrades, and maintenance of integration solutions. Just like PowerPacks, you can also share SyncPacks. In addition, SyncPacks protect a company's intellectual property using licensing and encryption technologies.
Viewing the List of SyncPacks
The SyncPacks page () provides a list of the SyncPacks on your PowerFlow system.
Searching for a SyncPack
You can search for a specific SyncPack by typing the name of that SyncPack in the Search field at the top of the SyncPacks page. The user interface filters the list as you type. You can also filter the list by typing in the text box above a column header, and sort by clicking most column headers.
If you have more than one version of a SyncPack the active version of the SyncPack is highlighted in green in the Versions column.
Click the Filter icon () at the top right of the SyncPacks page and select Toggle Inactive SyncPacks to show all SyncPacks on the PowerFlow system.
Viewing a Detail Page for a SyncPack
Click the name of a SyncPack from the list to view the detail page for the SyncPack.
At the top of this page you can view additional metadata, including the active version, the minimum PowerFlow platform version, and other details.:
In the Package Contents section, you can view more details about the steps, applications, and configuration objects include with that SyncPack:
- The tab includes a link to the detail page for each application, along with a list of steps in the application (with the option of clicking the step name to view the code for that step), and a thumbnail image of the workflow for the application.
- The tab includes a link to the Step Code dialog for each step, along with a list of any applications that are using that step. You can also click the name of the application from the list to go to the detail page for that application.
- The tab includes a link to the detail page for each configuration object, along with a list of any PowerFlow applications that are aligned with that configuration object (with the option of clicking the application name to view the detail page for that application).
Using the Actions Button to Manage SyncPacks
On the SyncPacks page of the PowerFlow user interface, you can access the following SyncPack options by clicking the button () next to a SyncPack:
Activate & Install. Before you can use a SyncPack, you will need to activate and install it. An activated SyncPack has been installed and is ready to be used. For more information, see Activating and Installing a SyncPack.
Change active version. If you have more than one SyncPack installed, select this option to specify a new active version (other than the version that is currently running).
Uninstall. Select this option if you want to completely remove all versions of a SyncPack, instead of deleting one or more versions using the Delete option, below.
Delete. Remove one or more versions of a SyncPack from PowerFlow. You cannot delete the active version of a SyncPack (the version that is currently running).
Importing and Installing a SyncPack
The SyncPacks page in the PowerFlow user interface lets you import and install the latest version of a SyncPack. After you install a SyncPack, PowerFlow considers that SyncPack to be activated and ready to be used.
By default, the SyncPacks page displays all activated and installed SyncPacks. If you do not see the PowerPack that you want to install, click the Filter icon (
After you install a SyncPack, that SyncPack is available on the SyncPacks page of the PowerFlow user interface. The PowerFlow applications from that SyncPack are added to the Applications page of the user interface. You can click the name of that SyncPack to view the detail page for that SyncPack.
If you want to upload and install multiple ServiceNow SyncPacks at the same time, you should upload all of the SyncPacks first, and then install them to address any dependencies between the SyncPacks.
Also, you can click the dropdown arrow next to the button to import or view dependencies for PowerFlow SyncPacks. For more information, see Locating and Importing Dependencies for a SyncPack.
If a SyncPack has a dependency on another specific SyncPack version, you will need to install that SyncPack version on the PowerFlow system before you can install the SyncPack with the dependency. For more information, see the SL1 PowerFlow Dependency Matrix page at https://docs.sciencelogic.com/latest/Content/Web_General_Information/Doc_Archive/powerflow_release_matrix.htm.
You must have the Develop or Administrator role to install a SyncPack. For more information, see Managing Users in PowerFlow.
If your PowerFlow system uses self-signed certificates, you will need to manually accept the certificate before you can upload SyncPacks. Go to https://<IP address of PowerFlow>:3141/isadmin, accept the certificate, and then exit out of the tab. When you log into PowerFlow again, you will be able to upload SyncPacks.
Locating and Downloading a SyncPack
If you are upgrading to this version of the SyncPack from a previous version, make a note of any settings you made on the Configuration pane of the various PowerFlow applications in this SyncPack, as these settings are not retained when you upgrade.
- Click the tab and select PowerPack.
- On the tab, click the name of the SyncPack version that you want to install. The Release File Details page appears.
- Click the button or click the name of the .zip file containing the .whl file for this SyncPack to start downloading the file.
If you are installing or upgrading to the latest version of this SyncPack in an offline deployment, see "Installing or Upgrading in an Offline Environment" in the SyncPack release notes to ensure you install any external dependencies.
Importing a SyncPack
- On the SyncPacks page (
- Click and select the .whl file for the SyncPack you want to install. You can also drag and drop a .whl file to the Import SyncPack page.
- Click . PowerFlow registers and uploads the SyncPack. The SyncPack is added to the SyncPacks page.
- Click to confirm the activation and installation. When the SyncPack is activated, the SyncPacks page displays a green check mark icon (
) appears.
- For more information about the activation and installation process, click the check mark icon (
The most common error that occurs when installing a SyncPack is that the SyncPack dependencies are not installed. If a SyncPack has a dependency on another specific SyncPack version, you will need to import and install that SyncPack version on the PowerFlow system before you can install the SyncPack with the dependency.
Review the "System Requirements" section of the release notes for that SyncPack to ensure that you have installed all of the required applications for that SyncPack.
To view a list of additional PowerFlow and SL1 products that are required by the various SyncPacks, see the SL1 PowerFlow Dependency Matrix page.
In addition, you can click the dropdown arrow next to the button to import or view dependencies for PowerFlowSyncPacks.
To view a list of available dependency files:
- Click the down arrow icon (
) next to the button and select View Dependencies. A devpi dependencies page appears. - To view more information about a dependency, click the link in the Info page column.
- To download a dependency file, click the link in the Releases column.
To import a dependency:
) next to the button and select Import Dependency. -
Click and select the relevant dependency file from the previous step.
You can also drag and drop a file onto the Import SyncPacks page.
- Click . The dependency file is added to the PowerFlow system .
Default SyncPacks
When you install PowerFlow, the following SyncPacks are added to the SyncPacks page by default:
If you need to install these SyncPacks, click the button () and select Activate & Install for each SyncPack.
Base Steps SyncPack
The "Base Steps" SyncPack contains a default set of steps that are used in a variety of different SyncPacks. You must install and activate this SyncPack before you can run any of the other SyncPacks.
This SyncPack also includes the Template App application, which you can use as a template for creating PowerFlow applications if you are a developer. For more information, see Creating an SL1 PowerFlow Application.
This SyncPack is included with the most recent release of the PowerFlow Platform.
Starting with version 1.5.0 of the "Base Steps" SyncPack, the "QueryREST" has been deprecated. ScienceLogic recommends that you use REST steps included in version 1.5.0 instead: "GetREST", "PostREST", "DeleteREST", and "PutREST".
To view the latest releases of this SyncPack, see SL1 PowerFlow SyncPack Release Notes.
You can download this SyncPack from the PowerPacks & SyncPacks page (Product Downloads > PowerPacks & SyncPacks) at the ScienceLogic Support Site.
Flow Control SyncPack
The "Flow Control" SyncPack contains just one item: the "IfStep" step that enables the logical branching used by the PowerFlow builder. The most recent version of this SyncPack is version 1.0.1, and it is included in the PowerFlow Platform release.
System Utils SyncPack
The "System Utils" SyncPack is a Standard SyncPack that contains applications, a configuration object, and steps. Version 1.1.5 of this SyncPack is included with PowerFlow version 2.6.0.
You must install the "Base Steps" SyncPack before you can install this SyncPack.
