The following workflows describe how to configure SL1 and PowerFlow to work with the "Webex" SyncPack.
Configuring Webex
Configuring SL1
- Edit the Webex run book actions
- Enable the Webex run book automations
Configuring PowerFlow
- Align the configuration object and configure the Webex PowerFlow applications
Configuring Webex
The following topics cover how to set up Webex to work with the SyncPack.
Creating a Bot in Webex
Create a bot in Webex:
- Log in to developer.webex.com.
- Select your profile, and then select My Webex Apps.
- Select Create a New App, and then select Create a Bot.
- When you have created the bot, save the access token from the bot. This will be used for posting messages and creating rooms.
- Add the bot that you created to the appropriate team.
Creating a Webhook
Next, you will need to create an API Key in PowerFlow and a webhook in Webex:
- In PowerFlow, go to the API Keys page.
- Select Create API Key and copy the key when it is generated.
- Create the following URL, inserting your PowerFlow IP address and the API key from step 2 where indicated:
- Go to Webhooks - Create a Webhook | Webex for Developers.
- Use the Bot token in Authorization while creating the webhook using the API.
- Add the following parameter values:
https://<Your PowerFlow IP Address>/api/v1/applications/sync_event_status_from_webex_to_sl1/run?PF-APIKEY=<API Key>
- targetUrl. Use the URL you created using your API key.
- resource. attachmentActions
- event. created
Configuring SL1
The following topics cover how to set up your SL1 instance to work with the "Webex" SyncPack.
You will need to create a SOAP/XML credential so that the automation actions included in the "Webex Automation" PowerPack can access your PowerFlow system. The "Webex Automation" PowerPack includes the "PowerFlow Webex Teams" credential, which you can use as a template for the SOAP/XML credential.
- Click the wrench icon (
) for the "PowerFlow WebexTeams" credential. The Credential Editor modal window appears: - Complete the following fields:
Editing the Webex Run Book Actions
The "Webex Automation" PowerPack includes run book actions that use the "Run Integration Service Application" action type to trigger the PowerFlow applications that send and receive data to and from Webex. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
Enabling the Webex Run Book Automations
The "Webex Automation" PowerPack includes six standard automation policies that you will need to enable. These policies create Webex channels, acknowledge or clear Webex room notifications, and update SL1 events created from Webex.
The following table shows the run book automation policy, its aligned events, and the run book action that runs in response to the events.
| Webex: Create Channel |
All Events |
Webex: Create Room |
| Webex: Created Room Notification - Acknowledge |
All Events |
| Webex: Created Room Notification - Clear |
All Events |
| Webex: [Events] - Acknowledge |
All Events |
Webex: Acknowledge |
| Webex: [Events] - Add/Update |
All Events |
Webex: Add/Update |
| Webex: [Events] - Cleared |
All Events |
Webex: Clear |
- Locate a Webex run book automation policy and click its wrench icon (
- Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the Webex automation policy you selected in step 2, and click the arrows to move it to Aligned Actions.
- Repeat steps 2-4 for the remaining Webex run book automation policies.
The following topics cover how to set up your PowerFlow instance to work with the "Webex" SyncPack.
For this SyncPack, you can make a copy of the " Config" configuration object, which is the sample configuration file that was installed with the Webex SyncPack. Then you need to align that configuration object to the relevant applications.
The "Sample Webex Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Webex settings.
To create a configuration object based on the "Sample Webex Config" configuration object:
Click the button (
) for the "Sample Webex Config" configuration object and select Edit. The Configuration pane appears.
- sl1_host. The hostname or IP address of the SL1 system the alerts will synchronize to.
- token. Webex bot token.
- default_ack_user. The default user to acknowledge events and alerts.
- team_id. ID of the team to create the channel for.
- users. Comma-separted list of Webex user emails to invite to the created channel.
- room_id. ID of the room to post messages in.
With this SyncPack, any status changes made to an SL1 event is sent to Webex to update the corresponding alert. Any status changes to the Webex alert are synced back to the corresponding SL1 event.
- Create Room For Event"
- "Created Room Event Notification"
- "Major Event Notification"
- "Sync Event Status From Webex To SL1"
) are populated either by the configuration object you aligned with the application or by the run book action. Do not modify these values. If you encounter an error, make sure your run book action is configured properly.
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple SL1 instance or multiple Webex instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Webex instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Webex instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
