The following workflows describe how to configure SL1 and PowerFlow to work with the "xMatters" SyncPack.
Configuring SL1
- Edit the xMatters run book actions
- Enable the xMatters run book automations
Configuring PowerFlow
- Align the configuration object and configure the xMatters PowerFlow applications
Configuring SL1
The following topics cover how to set up your SL1 instance to work with the "xMatters" SyncPack.
You will need to create a SOAP/XML credential so that the run book actions included in the "xMatters Incident Integration" PowerPack can access your PowerFlow system. The "xMatters Incident Integration" PowerPack includes the "PowerFlow xMatters" credential, which you can use as a template for the SOAP/XML credential.
- Click the wrench icon (
) for the "PowerFlow xMatters" credential. The Credential Editor modal window appears. - Complete the following fields:
Editing the xMatters Run Book Actions
The "xMatters Incident Integration" PowerPack includes four run book actions that you will need to enable.
These actions use the "Run Integration Service Application" action type to trigger the PowerFlow applications that send and receive data to and from xMatters. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
- Locate the xMatters run book action that you want to use, and then click its wrench icon (
Enabling the xMatters Run Book Automations
The "xMatters Incident Integration" PowerPack includes four run book automation policies that you will need to enable.
These policies update the xMatters alert or SL1 events with the state of the associated event or alert or populates SL1 with on-call details. When the event is first detected in SL1 or xMatters, the "triggered" state is sent. When the event is acknowledged in SL1 or xMatters, the "acknowledged" state is sent. When the event is cleared in SL1 or xMatters, the "resolved" state is sent. When on-call is triggered, the on-call details are added to the SL1 event notes.
If you enable the "xMatters: Acknowledge Event", "xMatters: Resolve", and "xMatters: Trigger" automation policies, it is best practice to align the same devices for all three policies.
| xMatters: Acknowledge Event | All events | xMatters: Acknowledgment |
| xMatters: Oncall | All events | xMatters: Resolve |
| xMatters: Resolve | All events | xMatters: Resolve |
| xMatters: Trigger | All events | xMatters: Trigger |
- Locate the xMatters run book automation policy and click its wrench icon (
- Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the xMatters run book automation policy that you selected in step 2, and click the arrows to move it to Aligned Actions.
- Repeat steps 2-4 for the remaining xMatters run book automation policies.
The following topics cover how to set up your PowerFlow instance to work with the "xMatters" SyncPack.
For this SyncPack, you can make a copy of the "Xmatters Config Template" configuration object, which is the sample configuration file that was installed with the " xMatters" SyncPack. Next, you need to align that configuration object to the relevant applications.
The "Xmatters Config Template" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and xMatters settings.
To create a configuration object based on the "Xmatters Config Template" configuration object:
Click the button (
) for the "Xmatters Config Template" configuration object and select Edit. The Configuration pane appears.
- sl1_host. The hostname or IP address of the SL1 system the alerts will synchronize to.
- xmatters_alert_api_webhook. To send events to xMatters, you must configure a generic webhook workflow in xMatters. Enter the integration URL for that workflow.
- xmatters_instance_url. The URL to use for links to the xMatters user interface. Enter the base URL you navigate to. This URL will be displayed in SL1 and will open your xMatters instance in a browser.
- proxy_host. The hostname or IP address of the HTTP proxy that will be used when making an API request to xMatters.
- xm_user. The username for your xMatters system.
- xm_password. The password for your xMatters system.
- xm_group_id. The xMatters group ID you want to use.
- resolve_from_xm. The option to resolve events from xMatters.
- populate_external_url. The option to add an xMatters incident URL to the corresponding SL1 event.
- default_ack_user. The default user to acknowledge events in SL1.
With this SyncPack, any status changes made to an SL1 event is sent to xMatters to update the corresponding incident. Any status changes to the xMatters incident are synced back to the corresponding SL1 event. You will need to align the xMatters applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- "Bulk Resolve SL1 Events"
- "Get Acknowledged Incidents And Post Data To SL1"
- "Get Oncall Details And Post Oncall List To SL1"
- "Pass Acknowledgment details from SL1 to Xmatters"
- "Pass Resolution to Xmatters from RBA"
- "Save Accounts to Cache"
- "Get Event Details And Post Incident URL to SL1"
To trigger some applications in this SyncPack, you must schedule the application. You must schedule the following applications if you want to trigger them:
- "Get Acknowledged Incidents and Post Data to SL1"
- "Save Accounts To Cache"
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
