Introduction to Dell EMC Unity Automation PowerPack
This section describes how to use the automation policies and automation actions found in the Dell EMC Unity Automation PowerPack.
This PowerPack is available with a ScienceLogic SL1 Standard solution. Contact your ScienceLogic Customer Success Manager or Customer Support to learn more.
What is the Dell EMC Unity Automation PowerPack?
The Dell EMC Unity AutomationPowerPack includes automation policies that:
  • Enrich SL1 events for Dell EMC devices (for example, from the Dell: EMC Unity PowerPack) by automatically running diagnostic commands from the Unisphere REST API and adding the output to the SL1 event log or an associated incident.
The Dell EMC Unity Automation actions are executed on the SL1 All-In-One Appliance or Data Collector.
Installing the Dell EMC Unity Automation PowerPack
Before completing the steps in this section, you must import and install the latest version of the Dell EMC Unity Automation PowerPack.
IMPORTANT: You must install the Datacenter Automation Utilities PowerPack before using the Dell EMC Unity Automation PowerPack.
The Dell EMC Unity Automation PowerPack requires SL1 version 8.10.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
If you will have the Dell EMC: Unity PowerPack installed and are monitoring your Dell EMC devices, no other configuration is necessary. The automation policies in the Dell EMC Unity Automation PowerPack will run in response to aligned events.
