Overview of the SL1 User Interface
SL1 offers you the capabilities to monitor your hybrid cloud infrastructure, improve service visibility, and automate your IT workflows. This section is intended for new users of SL1, and it covers features in both the new user interface that was released with version 8.12.0 of SL1 as well as the "classic " user interface of SL1 that was available before version 8.12.0.
Please note that the new user interface provides access to both new and "classic" user interface features.
The following video provides an overview of the SL1 user interface:
Prerequisites
This manual assumes that the initial installation and configuration (deployment) of SL1 version 8.12.0 or later has been completed. For details on the initial configuration of SL1, see the Installation section.
Logging In and Out of the SL1 User Interface
This topic covers how to access the different user interfaces for SL1: the default SL1 user interface ("AP2") and the "classic" user interface.
If you are upgrading from a version of SL1 prior to 11.1.0, the classic user interface might still be set as the default user interface. To change the default user interface (UI), go to the Behavior Settings page (System > Settings > Behavior) and select the New UI Default checkbox.
The SL1 User Interface
Starting with SL1 version 11.1.0, you no longer need to type /ap2 at the end of the URL or IP address, such as https://sl1.sciencelogic.com/ap2, to get to the SL1 user interface. The /ap2 is added to the IP address by default.
To log in to the SL1 user interface:
  1. In a browser, type the URL or IP address for your SL1 system. The login page for SL1 appears.
  2. Type the current user name and password you use with SL1 and click Log In. The SL1 login button displays a spinning status icon while you are being logged in.
  3. If your company uses Single Sign-On (SSO) for authentication, you will be redirected to your company's SSO page, where you can log in to SL1 with your SSO credentials. When you log out, the logout screen redirects you to an SSO page instead of the typical login screen.
  4. If you are logging in for the first time or you are using the default system password, you will be prompted to change your password. Type your username, your old password, and type your new password twice in the New Password and Confirm Password fields. Click Reset Password.
  5. If your SL1 system is a Military Unique Deployment (MUD) system, a Disclaimer modal appears, and you will need to click OK after reading the text to use SL1.
  6. For an Administrator user, the End User License Agreement (EULA) appears the first time the Administrator user logs in to SL1. The user must agree to the terms before using SL1.
    If you can still see the horizontal NavBar or other features of the classic user interface in the SL1 user interface, click Refresh in your browser.
    If you navigate to the classic SL1 user interface by typing /em7 in the URL, the top navigation might be missing. To address this issue, navigate back to the new user interface, log out, and then log in to the classic user interface.
To log out of the SL1 user interface:
  1. Click your user name in the navigation bar at the top of any SL1 page.
  2. Click Log off. You are logged out, and a logoff page appears with the option to log in again.
The Classic User Interface
To log in to the classic user interface for SL1:
  1. In a browser, type the URL or IP address for your SL1 system, followed by /em7. The login page for the classic user interface appears.
    You can log out of the classic user interface by typing /em7/logout.em7 at the end of the URL or IP address.
  3. If you are logging in for the first time or you are using the default system password, you will be prompted to change your password. Type your username, your old password, and type your new password twice in the New Password and Confirm Password fields. Click Reset Password.
  4. To switch to the default SL1 user interface while you are using the classic user interface, type / at the end of the URL or IP address for your SL1 system and press Enter. The login page of the SL1 user interface appears.
  5. To switch to the classic user interface while you are using the SL1 user interface, type /em7 at the end of the URL or IP address for your SL1 system and press Enter. The login page for the classic user interface appears.
  6. To make the classic user interface the default interface, go to the Behavior Settings page (System > Settings > Behavior) and unselect the New UI Default checkbox.
    If you need to run both the classic and SL1 user interfaces simultaneously, you can open the classic and the SL1 version in two different browsers, or you can open private or incognito browser windows and then log in to the two user interfaces.
Using the Navigation Menus
The SL1 user interface includes content from both the "new" user interface (also called "ap2") and the "classic" user interface (also called "em7"). This unified user interface provides a more streamlined method of navigation that uses two menus: a basic menu and an Advanced menu.
  • To view a pop-out list of menu options for the basic menu, click the menu icon () at the top left of any SL1 page. Use the up and down arrow buttons () to expand and contract the menu options.
  • To view the Advanced Menu page, which contains links to all of the menu options, click the Advanced menu icon () at the bottom left of any SL1 page. Use Ctrl+F in your browser to quickly find a page.
The basic menu and the Advanced menu displays links for only the pages for which you have access.
The Setup and Config Page
The Setup and Config page () displays all information relevant to getting started in SL1 for administrator-level users. Included on this page are a number of journeys, intuitive self-service workflows that will guide you through the most common SL1 system tasks. Click the name of a workflow to get started.
This page also contains informational cards that provide you with the proper resources for SL1 setup and configuration.
Image of the Setup and Config page
The informational cards on this page include:
  • Get Started. Displays a list of available user journeys and their journey status. Click the name of the journey to get started. The journeys include:
  • Take a Tour of SL1
  • Discover and Monitor Hybrid Cloud Infrastructure
  • Resources. Hosts additional external resources to help you with setup and configuration; these links include:
  • Training Portal
  • ScienceLogic Support
  • Overview. Provides links to the user journeys. These journeys include guided tours and interactive wizards that help you set up and refine your SL1 environment:
  • Next Steps. Contains links to other pages in SL1 where you can continue working after completing some or all of a journey:
  • Manage Devices
  • Manage Collector Groups
  • Manage Organizations
  • Manage Users
  • Manage Access Hooks
Setting a Home Page in SL1
The Dashboards page is the default home page when you first launch SL1. Starting with version 12.2.0 of SL1, you can set any of the top-level pages that display in the left-hand navigation bar as your landing page, including Events, Devices, Business Services, Maps, Machine Learning, and Setup and Config. You can also set a specific dashboard from the Dashboards page as your home page. If you lose permission to the page or dashboard you set as your landing page, the Events page will be automatically set as your home page. You can click the Your Home tab in the left-hand navigation bar to be redirected to your home page.
You cannot use any pages that display in the navigation bar below these pages as a landing page. This feature does not work with classic dashboards. For more information on what you can see and do on the default dashboards page, see the section on Default Dashboards.
To set your home page:
  1. In SL1, navigate to the page or the SL1 dashboard that you want to set as your home page.
  2. Click your user name in the navigation bar at the top of the page and select Set as Home Page. That page or dashboard will be your home page the next time you launch SL1.
    If the page you are currently on cannot be used as a home page, the Set as Home Page option will be grayed out.
Filtering Inventory Pages
In SL1, an inventory page is any page (or tab) that contains a table with a list of items that you work with, like the Events page or the Devices page. At the top of most inventory pages in the SL1 user interface are a set of filters for the columns in the table on that page.
In the following image, the user is filtering the Devices inventory page by typing part of an IP address in the filter for the IP Address column:
The Devices inventory page with the IP address filter filled in with "10.2.23.4"
Some filters, like the State filter, let you click a drop-down arrow to select search options from a drop-down menu. Also, any filters related to date and time let you click a calendar icon () to select a date or a date range, and a clock icon (), where relevant, to select a time or a time range.
If you were using a version of SL1 from before version 11.2.0, any list and column preferences you had configured will not be retained with the new features for inventory pages after you upgrade to 11.2.0 or later. This includes customizations such as which columns are visible, column widths, column order, and other customizations.
SL1 retains your search filters on pages in the SL1 user interface even after you refresh the browser or navigate to another page and then return to the page where you created your search.
On most inventory pages, you can use the Search field at the top of the inventory page to perform a Basic Search. For more information, see Using Basic Search. In addition, you can click the gear icon () and select Advanced to "translate" your basic search into an Advanced Search. For more information, see Performing an Advanced Search.
Filter Syntax
When searching for a string in the Filter field on an inventory page, SL1 matches sub-strings by default, even if you do not include any special characters. For example, searching for "hel" will match both "hello" and "helicopter".
When searching for a numeric value, SL1 will not match a sub-string unless you use a special character.
If you type invalid search terms or incorrect syntax in a filter on an updated inventory page, SL1 will highlight the headers in red. SL1 will ignore the incorrect input until you fix it.
You can use the following set of syntax and special characters to search and filter each column on an inventory page (except columns that display date and time):
String and Numeric
  • , (comma). Specifies an "OR" operation. Works for string and numeric values.
    For example: "dell, micro" matches all values that contain the string "dell" OR the string "micro".
  • & (ampersand). Specifies an "AND " operation. Works for string and numeric values.
    For example: "dell & micro" matches all values that contain both the string "dell" AND the string "micro", in any order.
  • ! (exclamation point). Specifies a "not" operation. Works for string and numeric values.
    For example: "!dell" matches all values that do not contain the string "dell".
You can also use the "!" character in combination with the arithmetical special characters (min-max, >, <, >=, <=, =) described below.
String
  • ^ (caret). For strings only. Specifies "match the beginning". Matches any string that begins with the specified string.
    For example: "^sci" matches "scientific" and "sciencelogic", but not "conscious".
  • $ (dollar sign). For strings only. Specifies "match the ending". Matches any string that ends with the specified string.
    For example: "ter$" matches the string "renter" but not the string "terrific".
Numeric
  • min-max. Matches numeric values only. Specifies any value between the minimum value and the maximum value, including the minimum and the maximum.
    For example: "1-5 "matches 1, 2, 3, 4, and 5.
  • - (dash). Matches numeric values only. A "half open" range. Specifies values including the minimum and greater or including the maximum and lesser.
    For example: "1-" matches 1 and greater. So matches 1, 2, 6, 345, etc. "-5" matches 5 and less. So matches 5, 3, 1, 0, etc.
  • > (greater than). Matches numeric values only. Specifies any value "greater than".
    For example: ">7" matches all values greater than 7.
"<12" matches all values less than 12.
  • >= (greater than or equal to). Matches numeric values only. Specifies any value "greater than or equal to".
    For example: "=>7" matches all values 7 and greater.
  • <= (less than or equal to). Matches numeric values only. Specifies any value "less than or equal to".
    For example: "=<12" matches all values 12 and less.
  • = (equal). Matches numeric values only. For numeric values, allows you to match a negative value.
    For example: "=-5 " matches "-5" instead of being evaluated as the "half open range" as described above.
Examples
  • "!fer$" matches all values that do not end with "fer".
  • "!". Matches null values, typically represented as "--" in most pages.
  • "!vol&!silo". Matches text that does not contain "vol" AND also does not contain "silo". For example, "volume" matches, because it contains "vol" but not "silo".
  • "!vol&02". Matches text that does not contain "vol" AND also contains "02". For example, "happy02" matches, because it does not contain "vol' and it does contain "02".
  • "aggr,!vol&02". Matches text that contains "aggr" OR text that does not contain "vol" AND also contains "02".
  • "aggr,!vol&!infra". Matches text that contains "aggr" OR text that does not contain "vol" AND does not contain "infra".
  • "3,7-8,11,24,50". Matches numbers 1, 2, 3, 7, 8, 11, 24, 50, and all numbers greater than 50.
  • "3,7-8,11,24,50,a". Matches numbers 1, 2, 3, 7, 8, 11, 24, 50, and all numbers greater than 50, and text that includes "a".
  • "!^$" matches all values that are not null.
  • "!^" matches null values.
  • "!$" matches null values.
  • "1-5" matches 1, 2, 3, 4, and 5.
  • "1-" matches 1 and greater. So matches 1, 2, 6, 345, etc.
  • "-5" matches 5 and less. So matches 5, 3, 1, 0, etc.
  • "=-5 " matches "-5" instead of being evaluated as the "half open range" as described above.
  • "<7" matches 1,2,3,4,5,6
  • ">=3" matches anything greater than or equal to 3
Editing the Settings for an Inventory Page
On an inventory page, you can perform the following actions:
To change how often SL1 updates this page, click Refresh and select a new timespan. You can also select Refresh Now to immediately update the page or select Pause to stop updating the page altogether.
Adjusting and Sorting Columns
You can adjust the columns on an inventory page in the following ways:
  • To rearrange the columns in the list, click and drag the column name to a new location.
  • To adjust the width of a column, click and drag the pipes (|) on either side of the column name.
  • To quickly sort a column in ascending or descending order, click the up arrow (ascending) or down arrow (descending) that appears when you hover over the column name.
  • To perform additional sorts and to hide or show columns, click the Menu icon () next to the column name and select an option from the drop-down menu.
    Hover over the column name to see the Menu icon ().
    Your options include:
    • Multi Sort. Creates multiple ascending or descending sorts, in order of importance. For more information, see Creating a Multi Sort.
    • Unsort. Clears the existing sort.
    • Sort by ASC. Sorts the column in ascending order: smallest to largest for numbers, or alphabetically for strings.
    • Sort by DESC. Sorts the column in descending order: largest to smallest for numbers, or reverse alphabetically for strings.
    • Hide. Removes that column from the inventory page.
    • Show columns. Opens the Find column menu, from which you can add hidden columns and hide columns as needed. You can also choose to show all columns, reset the columns to their default display settings, and clear any column filters on the inventory page. For more information, see Editing Column Preferences.
    If you use the check boxes to select one or more items in a list, the relevant buttons appear at the top of the page, above the column names.
On an inventory page, if you click the gear icon () to open the Grid Settings menu and select Multi Sort, you can create multiple ascending or descending sorts, in order of importance:
  • Click Add Sort to add one or more sorts.
  • Click Clear Sort to clear all of the existing sorts. You can also click the delete icon () next to a sort to remove that specific sort from the list.
  • Click Apply Sort to run the sort and show the results on the list page.
The Multi Sort settings are cleared if you sort a column from the inventory page.
On an inventory page, if you click the gear icon () to open the Grid Settings menu and select Column Preferences, the Find column menu appears. On the menu, you can update the display settings for that inventory page:
  • Select a column from the menu to add a hidden column.
  • De-select a column from the menu to hide that column.
  • Click Show All to show all columns.
  • Column widths, order, sort, refresh interval, and other column attributes will persist after you adjust them. You can click Reset to return the columns to their default display settings.
From the Grid Settings menu, click Clear Filters to remove any column filters on that page.
Adjusting the Row Density
On an inventory page, if you click the gear icon () to open the Grid Settings menu and select Density, you can change the size of the rows and the size of the text in the rows on that page by selecting:
  • Compact. Uses less padding between rows and a smaller font size to display more rows.
  • Comfortable. Use more padding between rows and a larger font size to display fewer rows, but with more spacing between rows.
You can toggle the highlighting of the Message column by clicking the gear icon () to open the Grid Settings menu and selecting Severity Highlighting Off or Severity Highlighting On.
Exporting to a CSV File
On an inventory page, if you click the gear icon () to open the Grid Settings menu and select Export (.csv), you can save the current list of items as a comma-separated list.
The list will include any column filters that you set up before clicking Export.
Viewing the Device Summary Modal from an Inventory Page
On the Events page and the Devices page, you can click the Open icon () next to an event or device to open a new Device Summary modal:
  • The Tools pane enables you to run a set of diagnostic tools or user-initiated actions in the Activity Center, or to click on custom links that will open in a separate browser window. Click the search bar to search for tools, actions, or custom links that are available for the device.
  • The Vitals pane displays graph data for the past four hours of CPU usage, memory usage, and latency for that device, where relevant. You can zoom in on a shorter time frame in the Vitals graph by clicking and dragging, and you can go back to the original time span by clicking the Reset zoom button.
Using Basic Search
At the top of most lists in the SL1 user interface, the Search field lets you look for specific elements in that list. The Search field contains a magnifying glass icon (Image of the magnifying glass icon) next to the words "Type to search" or "Search".
SL1 retains your search criteria on pages in the SL1 user interface even after you refresh the browser or navigate to another page and then return to the search page using the Back button in the browser.
After you type search commands in the Search field, you can click the gear icon () and select Advanced to "translate" your basic search into an Advanced Search. For more information, see Performing an Advanced Search.
To use the Search field:
  1. Click the Search field and start typing search text. As you type, SL1 provides potential matching values in a drop-down menu and starts filtering the list with your search text.
    For example, if you start searching for "database" by typing data, a drop-down list appears with a list of columns that might contain that word, and the list is filtered by items that have "data" in one of their fields.
  1. If you select one of the suggested search criteria from the list, such as message, a criteria button displays under the Search field. You can click the criteria button and edit the search text under the button, if needed.
    The Message search criterion, with the "contains" option set to "data".
    If you select the ANY option from the drop-down menu, the search looks through all relevant columns for matches to your search text. If you select the ANY option for multiple search terms, this can cause issues with search queries, as every term has to be searched against every column in the database. SL1 uses different search criteria for an "ANY" search based on the page you are currently on in SL1. ScienceLogic recommends that you do not use Basic Search in these situations, and instead use the Advanced Search feature. For more information, see Fields Used by an "ANY" Basic Search.
    If you are unable to paste a copied string of text in the Search field, make sure that your copied text does not contain any hidden special characters.
  1. To edit the search criteria for your current search even further, click the criteria button and click the contains field. You can choose from additional search operators in the drop-down that appears, such as begins with, is null, equal to, and not equal to.
  2. You can add another set of search criteria to an existing search by typing additional text in the Search field, and then selecting additional fields from the drop-down list. The new search terms are added to a second criteria button.
    Two Smart Search criteria selected: the Message field (set to "data") and the Severity field (set to "major")
    The search criteria button under the Search field also displays the search operator and value for the search as hovertext.
  1. Alternately, you can click the menu icon () to the right of the Search field to open a menu containing related search criteria. Select an element from the list of criteria and type additional search information in the criteria button that appears under the Search field:
    The Name search criterion, with the "contains" option set to "sl1"
    If you select a date-related search criteria from the list of criteria, you can use a drop-down calendar to select a specific date and time.
  1. To remove a search criteria, click the close icon () on the criteria button under the Search field.
  1. To switch to an Advanced Search, click the gear icon () to the right of the Search field and select Advanced. For more information, see Advanced Search.
  2. To quickly clear a search, click the gear icon () to the right of the Search field and select Clear.
  3. To save a search so you can use it again, see Saving a Basic Search.
If you type search criteria into a Search field at the top of a page in SL1 and then select the ANY option from the drop-down menu, the search looks through all relevant columns for matches to your search text.
If you select the ANY option for multiple search terms, this can cause issues with search queries, as every term has to be searched against every column in the database. ScienceLogic recommends that you do not use Basic Search in these situations, and instead use the Advanced Search feature.
SL1 uses different search criteria for an "ANY" search, depending on the page you are currently on in SL1. For example, an "ANY" search on the Dashboards page searches for the search criteria in the Dashboard ID or Dashboard Name fields, while an "ANY" search on the Devices page searches for the search criteria in the Device Name, Hostname, Device Class, Collector Group, Organization, and additional fields. See the table below for details.
To see which fields SL1 is using for a search, click the gear icon () to the right of the Search field and select Advanced. The syntax of the Basic Search is converted into an Advanced Search, which lists the relevant fields being searched by SL1.
The following table lists the fields that are used by an "ANY" search, based on the page you are on in SL1:
Page in SL1 user interface Fields searched by SL1 for that page
Main Pages
Dashboards Dashboard ID, Dashboard Name
Events Event Message, Aligned Resource Name, Aligned Organization, Aligned Sub-entity Name, Device Name, Hostname, Device Class Logical Name, Device Class Description, Device Collector Group, Device Class, Device Group ID, Device Group Name, Device Class Category
Devices, Machine Learning, Device Services Device Name, Hostname, Device Class Logical Name, Device Class Description, Device Class, Device Group, Device Class Category Name, Collector Group ID, Collector Group Name, Aligned Organization, Machine Learning Policy
Business Services and IT Services Service Type, Service ID, Service Name, Service Label, Service Policy Name, Aligned Organization
Maps Map Name, Map Description
Secondary Pages
Agents Agent Nickname, Agent Operating System, Hostname
Business Service Templates Business Service Template Name, Business Service Template Descriptions
Credentials Credential Name
Custom Attributes Custom Attribute Label, Custom Attribute Name
Device Categories Device Category Name
Device Classes Device Class Name, Device Class Description, Virtual Type, Logical Name, Device Category Name
Discovery Sessions Discovery Session Name, Aligned Collector Name, Aligned Organization
Event Policies Event Policy Name
Subscription Usage (Current License Usage) License Type, Device Name, Aligned Organization, Device Class Category Name
If a page from the SL1 user interface is not listed in the above table, then SL1 only uses the relevant Name field on that page for an "ANY" search.
If you are creating a complicated search using Basic Search or Advanced Search, or if you have a search that you use on a regular basis, you can save that search criteria so you can quickly use it again later.
To save a search:
  1. After you have created a Basic or Advanced Search, click the gear icon () to the right of the Search field and select Save. A Save Search window appears.
  2. In the Search Name field, type the name of your search and click Save. The search is added to the list of saved searches.
To use a saved search:
  1. Click the gear icon () to the right of the Search field and select Saved Searches. An Apply Search window appears.
  2. From the Select a search drop-down, select the search you want to use and click Apply. That search is applied to the current list.
By default, saved searches apply only to your user profile, and they are not shared with other users.
To share a saved search:
  1. Create a Basic Search and change it to an Advanced Search by clicking the gear icon () to the right of the Search field and selecting Advanced.
  2. Copy the Advanced Search code from the Search field and paste it into the relevant documentation so you can share the search with other users.
  • A field. The general type of data for which you are searching, such as a device name or an event message.
  • An operator. A word or symbol that specifies the relationship between the field and the value, such as equals or less than.
  • A value. A specific aspect or version of the field, such as a name or an amount.  If a value is a string, it should be surrounded by "quotation marks" or 'apostrophes'.
As you type your Advanced Search, a red icon (Image of the Exclamation Mark icon) or a green icon (Image of the Green Exclamation Mark icon) appears at the end of the text field to show that your search is incorrectly or correctly formatted.
To view a list of all possible search commands in an Advanced Search, press Ctrl + Space.
The Advanced Search fields and values vary based on the page you are on in the SL1 user interface. For more information about fields, operators, and values, see Components of an Advanced Search.
Below are simple examples of Advanced Search syntax:
For additional examples, including examples with more complex syntax, see Examples of Advanced Searches.
You can type search commands in the Search field for a Basic Search, and then click the gear icon () and select Advanced to "translate" your basic search into an Advanced Search. You cannot go from an Advanced Search back to a Basic Search, however, without losing your search criteria.
To create an Advanced Search:
  1. Click the gear icon () to the right of the Search field and select Advanced. The search type changes from Basic to Advanced (note the change in font style).
  1. Start typing a field name for your search. As you type, SL1 displays a list of available fields in a drop-down menu:
    The Advanced Search bar containing "me" with matching field options listed in a drop-down.
  2. Select or type a field name.
  3. To view a list of all possible search commands at any point in an Advanced Search, press Ctrl+Space. For example, the following operator options appear if you press Ctrl+Space after typing "message" and inserting a space:
    The Message field selected in Advanced Search with operator options listed in a drop-down.
  4. Select or type an operator name. If you are typing, SL1 provides a list of available options.
    Advanced Search with the "message" field selected and "con" typed with matching operator options listed in a drop-down.
    As you type your search command, a red icon (Image of the Exclamation Mark icon) appears at the end of the text field if your command is incorrectly formatted or incomplete. Click the red icon to view additional details.
  1. Type a value to complete your search, and type additional search commands as needed. When your search is complete and formatted correctly, a green icon (Image of the Green Exclamation Mark icon) appears at the end of the text field:
    An example of a complete Advanced Search, in this case "message contains 'preview'"
  1. Click the Search button. The results of your search appear.
    Even if you have correct search syntax, SL1 will save your search query only after you click Search. For example, some pages, such as a Device Service search, might not show all of the search results until you click Search.
  2. To clear a search, click the gear icon () to the right of the Search field and select Clear.
  3. You can save an Advanced Search to use later. By default, saved searches apply only to your user profile, and they are not shared with other users. For more information, see Saving a Search.
At the minimum, an Advanced Search requires the following components, in the following order:
  • A field. The general type of data for which you are searching, such as a device name or event message.
  • A value. A specific aspect or version of the field, such as a name or an amount. You must use either "quotation marks" or 'apostrophes' for your search strings, and strings are not case-sensitive.
You can also include the operators "and" or "or" to your search command. Basic Search in SL1 uses only "AND" searches, unless you specify "Any" in your Basic Search.
When SL1 evaluates an Advanced Search command, it evaluates the "OR" expressions first, followed by the "AND" filters.
For example, the following search command looks for events that have a status of Critical and contain a message with the word "error":
status = critical and message contains 'error'
The following search command looks for devices with a name of "device-name" or messages containing the word "error":
name = "device-name" or message contains "error"
You can use parentheses ( ) to group expressions and to ensure that the expressions are evaluated in the correct order. The following search command looks for either devices with a name of "device-name" and a status of Critical, or devices with a name of "device-name" and a status of Major:
(name = "device-name" and status = critical) or (name = "device-name" and status = Major)
Searches in SL1 are not case-sensitive, so you can use any combination of upper-case and lower-case letters.
Fields
For most searches, you start your search command with a field name. When you start typing in an Advanced Search field, SL1 provides a list of potential fields in a drop-down menu that you can select for your search command:
The Advanced Search drop-down in the Devices page for fields that appear with "na" typed
The list of potential fields depends upon the page you are currently on in SL1. The example above is from the Advanced Search field on the Devices page. If you typed the same letters in the Advanced Search field on the Events page, the drop-down menu would look like this:
The Advanced Search drop-down on the Events page for fields that appear with "na" typed.
The following table lists some of the more common fields, along with how to use them and examples of search commands that use those fields:
Field name Purpose Example
alignedResourceName Search for the name of a device aligned with an event. alignedResourceName contains "lab"
asset Search for an asset aligned with a device. asset has (assetTag contains 1)
attribute Search for devices based on custom attributes. In the example, the custom attribute is "year" and the value is "2021". attribute has (id = year and value = 2021)
dateCreated Search for the date and time a device was created. dateCreated isNotNull
deviceClass Search for devices belonging to a device class. deviceClass has (class contains 'Cisco')
deviceGroup Search for devices belonging to a device group. deviceGroup has (name contains "Network")
hostname Search for a device hostname   device has (hostname = "srv")
id Search for the unique numeric ID assigned by SL1. id contains "10"
isAcknowledged Search for events that have or have not been acknowledged. isAcknowledged = true
message Search for details about an event message. message contains "problem"
name Search for the name of the device. name = "server"
organization Search for the organization to which the device is assigned. organization has (company = "System")
organization has (company doesNotContain 'ABC Systems')
severity Search for the severity of an event; severities range from 0 to 4, from Healthy to Critical.
severity in 3,4
Searches for all Major and Critical events.
state Search for the state of a device; states range from 0 to 4: Healthy, Notice, Minor, Major, and Critical.
state in 0,1,2
Searches for all devices with a state of Healthy, Notice, and Minor.
suppressGroup Hide data related to the specified group. suppressGroup = sciencelogic
Operators
For most searches, you follow a field with an operator. The operator establishes a relationship between the field and the value that comes after the operator.
The list of available operators changes based on the page where you are making your search.
The following table lists some of the more common operators, along with how to use them and examples of search commands that use those operators:
Operator name Purpose Example
and Include two or more search criteria before producing search results deviceClass has (description contains 'rds instance') and name contains 'wordpress'
or Include at least one of multiple search criteria. name = "server" or message contains "error"
=, ==, eq The field and the value are equal. name == 'ECS 23' and ip doesNotContain '.'
<>, !=, neq The field and the search value are not equal. field != abc
<, lt The field is less than the search value. state < 2
>, gt The field is greater than the search value. severity > 3
<=, lte The field is less than or equal to the search value. state lte 2
>=, gte The field is greater than or equal to the search value. severity gte 3
contains The field includes the specified string. deviceClass has (description contains 'em7 admin portal')
doesNotContain The field does not include the specified string. name contains 'SL1 Classic' or (description contains 'PowerFlow' and description doesNotContain 'Not Deployed') or (description contains 'Extended Architecture' and description doesNotContain 'Not Deployed')
has The field contains a specific value. The value following "has" must be enclosed in parentheses.
deviceClass has (deviceCategory has (name contains 'Server')) and deviceClass has (description doesNotContain 'vcenter')
in The field must be part of a specific set of values. severity in 2,3,4
not Opposite values; this operator precedes the field name. not field = abc
isNull The field is empty. extTicketRef isNull
isNotNull The field is not empty. counter isNotNull
Values
The value you type at the end of a search command depends on the field name and the operator you use. For most searches, you can type the value instead of picking it from the drop-down menu that lists possible search options.
In the following example, the first search value is a string (red text) and the second search value is a numeric value (blue text):
A complete Advanced Search field menu, displaying the text "name contains 'np' and ip beginsWith 192.168"
You must use either "quotation marks" or 'apostrophes' for search strings, and strings are not case-sensitive.
Strings
You can create a search command that searches for a specific set of words in a string. You must use either "quotation marks" or 'apostrophes' for your search strings, and strings are not case-sensitive.
The following table lists some of the more common string operators, along with how to use them and examples of search commands that use those string operators:
String operator name Purpose Example
beginsWith Search for strings beginning with a specified value message beginsWith "Host Resource"
endsWith Search for strings ending with a specified value message endsWith 'shutdown'
contains Search for strings containing a specified value message contains "problem"
doesNotBeginWith Search for strings that do not begin with a specified value message doesNotBeginWith "front"
doesNotEndWith Search for strings that do not end with a specified value message doesNotEndWith 'warning'
doesNotContain Search for strings that do not contain a specified value message doesNotContain "codec"
Escape characters
In double-quoted strings (strings surrounded by quotation marks), you can include quotation marks in the search by escaping the quotation marks. To escape those characters, add a backslash before each quotation mark, such as \".
"Error in \"process x\""
In single-quoted strings, you can include the single-quote character by escaping it with a backslash, such as \'.
'Eric\'s Laptop'
'Error in "process x"'
You do not need to add quotes around strings in your search commands. However, if your string contains only numbers, you might want to add quotes around it to ensure that SL1 interprets it as a string.
If you do not include quotes around strings in your search commands, you must escape the following characters with a backslash:
  • all empty spaces or white spaces
  • comma
  • end parenthesis
Examples:
Eric's\ Laptop
Error\ in\ "process\ x"
devices\ \(system\,\ server\)
Other than the escape characters mentioned above, you can escape any character. You must escape the backslash character if you want to use it in a string, such as \\.
The normal whitespace escape sequences can be used: \t (tab), \n (new line), \b (backspace), \r (carriage return), and \f (form feed).
You can also use four-digit Unicode hex escape codes in the form \uXXXX.
Because the search commands differ for each page in SL1, this section contains a set of search examples based on context.
Advanced Search Examples on the Events Page
The following table contains a set of sample Advanced Searches for the Events page:
Purpose of Advanced Search on Events Page Advanced Search Syntax
Search for events on devices by Device ID of 1, 2, or 3. device has (id in 1,2,3)
Search for all events that contains the word "error" message contains "error"
Search for all events on devices with a Device Category Name of "xtremio". device has (deviceClass has (deviceCategory has (name contains 'xtremio')))
Advanced Search Examples for Dynamic Component Mapping (DCM) Scenarios
Dynamic Component Mapping (DCM) allows SL1 to collect data from a single management system, such as a VMware ESX server, and then use that data to create multiple device records for the entities managed by that single management system. For example, the managed entities for a VMware ESX server would be the Guest VMs hosted by that ESX server.
The following table contains a set of sample Advanced Searches for DCM devices on the Devices page:
Purpose of Advanced Search Advanced Search Syntax
Search for all host devices from a specific vCenter and add those devices to a Device Service componentRoot has (name contains "VCSA") and (componentParent has (deviceClass has (description contains 'Host Server')) or componentParent has (deviceClass has (description contains 'ESX')))
Search for SQL servers than run as the master.
deviceClass has (description contains 'SQL Instance') and componentRoot has (attribute has (id == 'DB_Role'and value contains 'Master'))
The following sections contain more details about these two Advanced Searches and how they work.
Scenario 1: vCenters
An SL1 system has multiple vCenters, each of which has multiple host servers. You want to include in a Device Service all Virtual Machines (VMs) from just one of the vCenters. This scenario includes the following elements:
  • The vCenter has a host name of VCSA hayward-hq.loc
  • One of the hosts has a Device Class of Host Server, and it contains four VMs
  • One of the hosts has a Device Class of ESX, and it contains 16 VMs
The VCSA hayward-hq.loc vCenter and its host servers
Search 1a
componentRoot has (name contains "VCSA") and deviceClass has (description contains "Virtual Machine")
This search works, but it only returns seven devices instead of the 16 devices you might have expected:
A query for the right set of devices and its preview of 7 devices
How the query works:
This part of the query returns a list of all devices that have a root with a name that includes VCSA.
This part of the query filters the results of the first part of the query to isolate the devices with Device Class of Virtual Machine
The reason why this Advanced Search does not result in the 16 VMs that we can see are hosted by both hosts is that some of the VMs have been merged. As a result, their Device Class has been reset to that of the operating system they are running.
Search 1b
This search successfully returns all 16 VMs:
A query for the right set of devices and its preview of 16 devices
This part of the query filters the results of the first part of the query to isolate the devices that have a parent of the Device Class Host Server.
This part of the query then does a second search of the results of the first query, looking for devices with parents that have a Device Class of ESX.
Scenario 2: SQL Servers
A DB Cluster has two SQL Servers than run as the master and two SQL servers that run as the slave:
The Device Components page with 4 devices found
Four times a year the master and slave is swapped between the two pairs. As this is a planned, infrequent, and manual activity, you can manually swap a custom attribute on the four hosting devices to designate if a device is acting as master or slave:
The attributes of a device with its value set to Master
The attributes of a device with its value set to Slave
For production or higher frequency and automated swapping, making the switch of the custom attributes could be embedded into a switching script and use the API or GQL interfaces to change the value of the custom attributes.
Searches
This search returns the two SQL instances that are running on the two SQL hosts designated as the master pair:
A query for the right set of devices with the text "value contains 'Master'" with a preview of 2 devices
This search returns the two SQL instances that are running on the two SQL hosts designated as the slave pair:
A query for the right set of devices with the text "value contains 'Slave'" with a preview of 2 devices
This part of the query returns a list of all devices that have a Device Class of SQL Instance.
and componentRoot has (attribute has (id == 'DB_Role'and value contains 'Slave'))
This second part of the query then filters the results of the first query to isolate the devices that have a root device with a custom attribute of DB_Role set to Slave.
Performing Bulk Actions
If an inventory page in SL1 displays a list of items, and that page contains a checkbox () to the left of each item in the list, you can select two or more items to perform bulk actions on all of the selected items at the same time.
When you use the checkbox to select one or more items in a list, a set of relevant buttons appear at the top of the page. If there are many bulk actions available, the Actions button appears, and you can search or click the down arrow to select an action. Select an action or click the relevant button to run that action on all of the selected items.
For example, on the Devices page, you can select two, twenty, or all of the devices on the page, and then you can click the Actions button and select from a number of actions to run on all of the selected devices.
The Events page with the bottom of the page noting 10 Events Selected with buttons to Acknowledge or Clear them
To select a series of adjacent rows, you can hold down the Shift key as you click the first item and then click the last item in the series.
Customizing the SL1 User Interface
A theme is a graphic template this is applied to the user interface. SL1 includes one System Default theme, but you can completely customize the look and feel of your SL1 system by creating new themes.
For example, you could create a theme that replaces the SL1 logo with your company's logo and updates the colors used in the user interface to match those used in your company's branding. You can also choose between a light theme or a dark theme for the user interface.
For more information about customizing the user interface using themes, see the section on Theme Customization.
Getting Help and More Information
For product documentation about any page in SL1, click the Help button at the top right of any page in SL1.
The Help menu appears in a new pane on the right side of the SL1 window:
The Help menu from the Events page.
If you click the View Product Documentation link at the bottom of the Help menu, a product documentation topic specific to the current page appears in a new browser window:
The Performing an Advanced Search page on the ScienceLogic Product Documentation website.
The product documentation includes a Search field at the top of the page that you can use to find additional topics related to the SL1 user interface. To find a specific topic that is longer than one word, enclose all of the key words in parentheses, such as "business services".
Click the Feedback button on the right side of the product documentation window to send comments directly to the ScienceLogic Documentation team, such as reporting typos, inaccuracies, questions, or other comments about that specific page in the Product Documentation.
As of version 8.12.2 of SL1, ScienceLogic no longer updates the content that appears when you click the Guide button in the classic user interface. All help content is maintained in the Help menu and the online product documentation, which is located at https://docs.sciencelogic.com.
The About Page
For more information about the components used by SL1, click your user name in the navigation bar at the top of any SL1 page and select About. The About ScienceLogic page appears:
The About ScienceLogic page with the ap2 number listed as 6.34.0
The current version number of the SL1 user interface displays in the ap2 row at the top of the list of components in the right-hand pane, along with the current version of GraphQL used by SL1. The Platform section lists SL1 version information for the various components in SL1, including Application Server, Collector Unit, and Database details, and All-In-One configurations (AO) where relevant.
In the left-hand pane, click any of the components in the Open Source Components pane to view licensing information about those components, along with links to relevant websites where relevant.
To search for a specific open-source component, type the name of that component in the Search field at the top of the page. The list of components is filtered by your search terms.
In addition, every page in SL1 contains a footer that displays the SL1 version, the build number, and the copyright date on the right side of the footer. You can click the SL1 version text to go to the About page:
The SL1 footer
If you select the Display Previous Login In Footer option on the Behavior Settings page (System > Settings > Behavior), the footer will also display the date and time of the previous login or the last failed login (if applicable) on the left side of the footer:
The SL1 footer with login date and time.
Tips and Best Practices for Using the Product Documentation
Use the following tips and best practices when using the ScienceLogic Help menu and product documentation:
General
  • To ensure that you are always using the most recent version of the product documentation, check the URL for this site to make sure you are using https://docs.sciencelogic.com/latest/.
  • The documentation at this site contains all manuals for the various features of SL1 and SL1 PowerFlow. You can click the Download manual as PDF link at the top of each chapter to download the PDF version of the manual.
  • The documentation at this site is the same documentation that appears when you click the Help button at the top of any SL1 page. When you click Help, the Help Menu appears:
    • The content in the Help Menu is based on your current page in SL1, and it is a condensed version of what appears at this site.
    • If you click the View Product Documentation link at the bottom of the Help Menu, a product documentation topic specific to the current page appears in a new browser window:
  • If you use the Version drop-down to navigate to a previous version of the product release notes or product documentation, the Version drop-down on the older version might contain links to archived, end-of-life versions of the site that display a 404 error.
  • To hide the Table of Contents that displays at the left of the Help window, click the Hide Table of Contents button (). To show the Contents again, click the Show Table of Contents button ().
Searching the Site
  • To search for a specific item in the product documentation, type the relevant information in the Search bar at the top of the page. After you select a document from the search results page, type the same search into your browser's Search (Ctrl+F).
  • If you are using a multiple-word search for a specific term, enclose those words in quotation marks ("").
    • For example: "business services".
    • If you do not use quotes around a term, the online docs assume you want to search for any of those terms, such as business OR services, as opposed to a search for business AND services with quotes.
  • Use the following command to search the product documentation via the SL1 API: https://docs.sciencelogic.com/latest/#search-<your-query-here>. For example: https://docs.sciencelogic.com/latest/#search-business services.
  • After you click a link to a page from the search results, your search term or terms display as one or more highlighted colors. To get rid of the highlights, click the Remove Highlights button () on the toolbar at top right of the Help content pane.
  • If you want to share or save a link to specific location in the documentation, click the link icon () to the right of the heading for a topic or sub-topic. That topic moves to the top of the reading pane, and you can copy the URL in the Address bar of the browser to share or save that location.
  • If a link to an external site does not open properly in a new browser window or tab, right-click the link in the product release notes and select the option to open the link in a new tab or window.
Images
  • An image in the product documentation might appear slightly blurry until you click that image to expand it in a pop-up window.
  • If you clicked to expand an image in a pop-up window, you will need to click the expanded image in its pop-up window to return it to its regular size before you can click another image or link in the product documentation.
  • You can also right-click an image and select Open Image in New Tab from the pop-up menu to make the image display at full size in the new browser tab.
Guides from the "Classic" User Interface
  • As of version 8.12.2 of SL1, ScienceLogic is no longer updating the help content that appears when you click the Guide button in the user interface. All help content will be updated and maintained here at https://docs.sciencelogic.com.
Filtering the Items on a Classic Page
Many pages in the classic user interface for SL1 that display data in tabular format include a "filter-while-you-type" filter above each table column. For example, the following filters appear on the Device Manager page (Devices > Device Manager or Devices > Classic Devices, or Registry > Devices > Device Manager in the classic SL1 user interface in the classic user interface).
You can filter the list of items on a page by entering values in one or more filters. The list of items is dynamically updated as you enter values. By default, the cursor is placed in the first Filter-While-You-Type field. You can use the <Tab> key or your mouse to move your cursor through the fields. There are two general types of filter:
  • Text filters, where you enter text to match against. SL1 will search for the items that contain the text you entered, including partial matches. For example, if you enter "server" in the Device Name filter in the Device Manager page, the list of devices will be filtered to include only the devices that include "server" in the device name. Most text filters support the following special characters:
"^micro" would match all strings that start with "micro," like "microsoft".
  • Drop-down list filters, where you select a value from a list of pre-defined values. SL1 will search the items that match the value you selected. For example, if you select ">=Notice" in the Current State filter in the Device Manager page, the list of devices will be filtered to include only the devices that have a current state of "Notice" or above.
If you select multiple filters, the list of values will be filtered to include only items that meet all the filter criteria.
Not all pages include "filter-while-you-type" filters and not all filters support all special characters.
Tool Tips
Some pages in SL1 include question-mark icons next to one or more fields. These question-mark icons are called Tool Tips. When you move your mouse over a Tool Tip, SL1 displays a brief description of the corresponding field.
Creating and Using Bookmarks
The Administer Bookmarks page (Misc > Bookmarks) allows you to create bookmarks in the classic user interface and quickly navigate to a selected page or to a selected result.
You can bookmark:
  • The current page (classic user interface only)
  • The results of a search, such as a search for all devices where the name begins with "cisco" (classic user interface only)
  • A filtered list, such as a list of all tickets in the "Engineering" queue (classic user interface only)
  • An editor page, with drop-down lists already selected. For example, you could bookmark the Dynamic Applications Create New Application page, with the Application Type of "XML Performance" already selected. The selected drop-down determines the other fields that appear in the subsequent pages.
To create a new bookmark:
  1. In SL1, navigate to the page and/or results you want to bookmark (classic user interface only).
  2. Use the shortcut keys Ctrl + Alt + B to display the Administer Bookmarks page.
  3. In the Administer Bookmarks page (Misc > Bookmarks), supply a value in the Save Current Page field. SL1 automatically supplies the page name in this field. You can edit the field to include more descriptive text.
  4. Click the Save button to save the new bookmark. The new bookmark appears at the bottom of the Administer Bookmarks page.
To access an existing bookmark, click its star icon (). SL1 will display the bookmarked page.
To delete a bookmark, click its bomb icon ().
The Finder Tool
The Finder tool (Misc > Finder) allows you to easily find one or multiple elements in SL1. This prevents you from having to navigate through multiple pages to find the element you are interested in.
The Finder tool allows you to search for one or more of the following types of elements:
  • Organizations
  • Devices
  • Assets
  • IP networks
  • Interfaces
  • Vendors
  • User Accounts
  • Virtual Interfaces
  • Device Groups
NOTE: To access the Finder page, accounts of type "user" must be granted one or more access keys that includes the following access hook: Finder. Accounts of type "user" will then be able to view the Finder tool.
  • To search organizations, the user must be granted the access hook Org:View.
  • To search for device, the user must be granted the access hook Dev:View.
  • To search asset records, the user must be granted the access hook Asset:View.
  • To search IPv4 Networks, the user must be granted the access hook Networks:IPv4:View.
  • To search interfaces, the user must be granted the access hook networks:Interfaces:View.
  • Top search vendor records, the user must be granted the access hook Vendor:View.
  • To search user accounts, the user must be granted the access hook User:View.
  • To search virtual interfaces, the user must be granted the access hook Networks:Interfaces:View.
Searching for One or More Elements
To use the Finder tool to search for one or more elements:
  1. From any page in SL1, press Ctrl + Alt + F. The Finder tool appears.
  2. In the Finder modal page, select the checkboxes for the element types you want to search. Choices are:
  • Organizations
  • Devices
  • Assets
  • IP networks
  • Interfaces
  • Vendors
  • User Accounts
  1. In the Search field, type the whole string of text or a partial string of text for which you want to search.
  2. You can include the asterisk (*) wildcard in the Search field.
  • If placed at the beginning of a string, the asterisk says "match on this string, preceded by any number of any characters".
  • If placed at the end of a string, the asterisk says "match on this string, followed by any number of any characters."
  2. The elements that match the search requirements are displayed at the bottom of the Finder page.
Viewing a List of All Elements in SL1
To use the Finder page to view a list of all elements in SL1:
  1. From any page in SL1, enter Ctrl + Alt + F.
  2. On the Finder page, select all the checkboxes.
  3. In the Search field, type "%" (percent).
  4. Click the Search button. A list of all elements in SL1 is displayed at the bottom of the Finder page.
Viewing the Results Table
After clicking the Search button, SL1 will display a list of elements that match the selected element type and search string.
From this list of results, you can:
  • View an element's properties. To do this, click on its icon (the icon will vary, depending upon the element).
  • View reports for some elements. To do this, click on the bar graph icon ().
  • Create a ticket about an element. To do this, click on the life ring icon ().
The Toolbox
The Toolbox appears in the upper right of the window in the classic user interface of SL1.
The Toolbox displays the following:
  • Logged in. Displays the name of the current user. When you hover over the username, the IP address for the current session appears.
  • Finder. If you enter a string in this field and click the Go button, SL1 uses the Finder tool to search all possible element types. The results are returned in the Finder tool page.
  • Toolbox. Clicking the Toolbox button displays a set of links to commonly accessed pages and the shortcut keys for those pages. The Toolbox button also displays links for License Information and SL1 Version Information.
  • The License Information link leads to a pop-up page with a list of all third-party licenses included in SL1.
  • The SL1 Information link leads to a pop-up page with information about the current version of SL1.
You can also access the following Toolbox options from the menu bar on the left () and from the Advanced menu (), under the Misc heading:
  • Bookmarks (Misc > Bookmarks). Displays the Administer Bookmarks page for saved and saving bookmarked SL1 pages.
  • Finder (Misc > Finder). Displays the Finder search tool for searching for specific SL1 features.
  • Guides (Misc > Guides). Displays the Guide Browser, which you can search to find more information about the classic user interface. The Guides are no longer being updated. For the most recent Help information, click the Help button at the top right of any page in SL1.
  • Clear SL1 Cache (Misc > Clear SL1 Cache). Removes cached items from SL1.
  • Regular Expression Tester (Misc > Regular Expression Tester). Lets you type regular expressions and search text into fields and then test them without impacting anything in SL1.
  • SL1 License Info (Misc > SL1 License Info). Displays a page of licensed software used by SL1.
