This chapter describes the different tools in SL1 that allow you to manage a restricted set of properties for your own account.
Account Preferences
The Account Preferences page allows you to change your SL1 password and customize some of the behavior and appearance of SL1. The customizations that you choose will appear each time you log in to SL1. They will not affect how SL1 appears to other users.
NOTE: To access the Account Preferences page, accounts of type "user" must be granted one or more access keys that includes the following access hook: MyPreferences. Accounts of type "user" will then be able to view and edit the settings in the Account Preferences page.
To access the Account Preferences page:
- Go to Preferences > Account > Preferences.
- In the Account Preferences page, you can edit one or more of the following fields:
- The Change Password pane allows you to change your password. The following fields appear:
- Existing Password. Your current password. This value must be at least four characters in length and can be up to 64 characters in length.
- New Password. The new password. This value must be at least four characters in length and can be up to 64 characters in length.
- Confirm Password. The new password again. This value must be at least four characters in length and can be up to 64 characters in length.
- . Click this button to save changes in the Change Password pane.
- The Interface Settings pane allows a you to define the appearance and behavior of some pages. The Interface Settings pane contains the following fields:
- Default Page. Displays a drop-down list of pages. The selected page will automatically appear when you log in. If you select None, the default page (the tab) will appear when you log in.
- Page Refresh Rate. Specifies how often Event, Ticket, and Views pages in SL1 will be refreshed. The possible choices are from 15 seconds to 60 minutes.
- Page Result Count. Specifies the number of results to be displayed on each page. The choices are 50 to 500.
- Table Row Height. Affects the row height of all pages that display a table in the main content pane. You can also change this setting in the Event Console Preferences page, the Ticket Console Preferences page, and the system Account Preferences page. Changing the setting for row height in this page, the Event Console Preferences page, the Ticket Console Preferences page, or the system Account Preferences page affects the row height in all pages that display a table in the main content pane. Choices are:
- Small. Sets row height to 17 px and font size to 11 px.
- Medium. Sets row height to 27 px and font size to 12 px.
- Large. Sets row height to 35 px and font size to 13 px.
- Default Severity Filter. When a severity is selected, you will see only events of the selected severity and greater in the Event Console page.
- Healthy. Will display all events, including events with a severity of Healthy.
- Notice. Will display all events with a severity of Notice, Major, Minor, and Critical.
- Minor. Will display all events with a severity of Minor, Major, and Critical.
- Major. Will display all events with a severity of Major and Critical.
- Critical. Will display all events with a severity of Critical
- Preferred IF Label. Specifies how interfaces will be labeled in all pages and reports that reference network interfaces.
- Interface Alias. Easy-to-remember, human-readable name for the network interface.
- Interface Name. The name of the network interface.
- Default Interface Graph Display. Specifies the default unit of measure for the Hourly Interface Usage graph in the Device Summary page. Choices are:
- Interface Default. The Hourly Interface Usage graph displays the amount traffic in the unit of measure specified in the Measurement field in the Interface Properties page for the interface.
- % Utilization. The Hourly Interface Usage graph displays utilization in percent.
- Default Date Format. Specifies the default date format that will be used throughout SL1. You can select from a list of possible formats.
- Date Format String. Specifies a user-defined date format that will be used throughout SL1. If defined, this date format overrides the default date format. Any date variables supported by the PHP date function can be used.
- Ad-hoc Report Email Preferences. Specifies whether the user will receive an email after an ad-hoc report (Reports > Create Report > Report Jobs > lightning bolt) is generated.
- In the Checkboxes pane, you can configure features that are toggled on and off.
- Disable Navbar Auto-hide. If you select this checkbox, the NavBar pane persists after you click a link. This option is selected by default.
- View Assigned Tickets Only. If you select this checkbox, by default, only tickets assigned to you are displayed in the Ticket Console page.
- Show Masked Events. If you select this checkbox, all events that have been grouped together under a single event description will be displayed in the Event Console page. The default behavior of SL1 is to roll up related events under a single description.
- Organizational Grouping Events. If you select this checkbox, events will be grouped by organization in the Event Console page. The filter-while-you-type fields and the advanced filter tool will appear for each organization grouping and will act only on the events in that organization grouping. You will not be able to apply a single filter to events in multiple organizations.
- Collapse Organization Events. If you select this checkbox, all organizations with assigned events will be displayed but will be contracted; the Event Console page will display only a list of contracted organizations, which can be expanded by clicking on the plus sign (+). The default behavior of SL1 is to expand each organization and display the list of events for each organization.
- Show Severity Badges. If you select this checkbox:
- The value in the Severity column will be displayed as a color-coded badge in the Event Console page and the Ticket Console page.
- The value in the Current State column will be displayed as a color-coded badge in the Device Manager page.
If you do not select the Show Severity Badges checkbox:
- In the Event Console page, the value in the Event Message column and the value in the Severity column will be painted with the severity color.
- In the Ticket Console page, the value in the Description column and the Severity column will be painted with the severity color.
- In the Device Manager page, the value in the Device Name column and the value in the Current State column will be painted with the severity color.
- Ticket Comment Reverse Sort. In the Notes section of a ticket, sort notes by newest first. If you do not select this checkbox, the user interface displays ticket notes from oldest to newest, with oldest displayed first.
- Disabled Ticket Comment Cloaking. When you add comments to a ticket, by default the comments are viewable by all (not cloaked).
- Scale Percent Graphs to 100%. Graphs that display percentage on the y-axis will display from 0% to 100%, regardless of the highest actual value. Default behavior is to display from 0% to highest actual value.
- Code Highlighting. If selected, enables syntax highlighting in areas of SL1 that display HTML, PHP, Python, and SQL code. If selected, syntax highlighting appears in:
- The Snippet Editor & Registry page for Dynamic Applications of type "snippet" (System > Manage > Applications > create/edit > Snippets).
- The Dashboard Widget Editor page (System > Customize > Dashboards > Widgets > create/edit).
- The Database Tool page (System > Tools > DB Tool).
- The Action Policy Editor page for actions of type "Snippet" and "SQL Query" (Registry > Run Book > Actions > create/edit).
- The Report Template Editor page (Reports > Management > Report Manager > create/edit).
- Hide Empty Networks. If you select this checkbox, the IPv4 Networks page hides networks that do not include any devices or interfaces.
The Database Tool page is available only in versions of SL1 prior to 12.2.1 and displays only for users that have sufficient permissions to access the page.
- In the Event Console Columns pane and the Ticket Console Columns pane, you specify the columns that will be displayed by default in the Event Console page and the Ticket Console page.
- Event Console Columns. In this list, you can select the default columns to be displayed in the Event Console page.
NOTE: From the Event Console page, you can also go to the Event Console Preferences modal page and edit the list of columns to be displayed in the Event Console page. When you edit the list of columns in the Event Console Preferencespage, the selected list of columns in the Account Preferences page is automatically updated. When you edit the list of columns in the Account Preferences page, the selected list of columns in the Event Console Preferences page is updated.
- Ticket Manager Columns. In this list, you can select the default columns to be displayed in the Ticket Console page.
From the Ticket Console page, you can also go to the Ticket Console Preferences modal page and edit the list of columns to be displayed in the Ticket Console page. When you edit the list of columns in the Ticket Console Preferences page, the selected list of columns in the Account Preferences page is automatically updated. When you edit the list of columns in the Account Preferences page, the selected list of columns in the Ticket Console Preferences page is updated.
Schedule Manager
The Schedule Manager page allows you to enter one-time or recurring appointments, meetings, and vacation leave. You can use the Schedule Manager page to specify the following:
- Your normal work schedule (for example, in the office on Monday – Friday, but out of the office on Saturday and Sunday)
- Vacation time
- Recurring meetings and appointments (for example, a weekly status meeting that occurs every Tuesday)
- One-time meetings and appointments (for example, a doctor's appointment)
The schedule information you enter in the Schedule Manager page is then visible to other users when they click the View User Account Details icon (
) for your account and then click the tab.
NOTE: To access the Schedule Manager page, accounts of type "user" must be granted one or more access keys that includes the following access hook: ACT_MY_SCHEDULE_PAGE. Accounts of type "user" will then be able to view and edit the settings in the Schedule Manager page.
You can also view and manage all scheduled processes from the Schedule Manager page (Registry > Schedules > Schedule Manager). For more information, see the
Viewing the Schedule Manager
The Schedule Manager page (Preferences > Account > Schedule) displays the following information about each scheduled or recurring calendar item:
To edit a scheduled or recurring calendar item, click its wrench icon (
) and update the calendar item as needed on the Schedule Editor modal page.
Defining a Scheduled or Recurring Calendar Item
You can add a scheduled or recurring meeting, appointment, vacation, or other calendar item for the user in SL1 from the Schedule Manager page.
To define a scheduled or recurring calendar item:
Go to the Schedule Manager page (Preferences > Account > Schedule).
Click . The Schedule Editor modal page appears.
On the Schedule Editor modal page, make entries in the following fields:
Basic Settings
Time Settings
If you want SL1 to automatically adjust for daylight savings time (if applicable), then you must select a named region (such as America/New York) in the Time Zone field. If you select a specific time zone (such as EST) or a specific time offset (such as GMT-5), then SL1 will not automatically adjust for daylight savings time. In addition, if you select a specific time zone, such as EST, that does not exist during daylight savings time observance, your schedules will be saved and execute at unexpected times.
Enabling or Disabling One or More Scheduled Calendar Items
You can enable or disable one or more scheduled or recurring calendar items from the Schedule Manager page (Preferences > Account > Schedule). To do this:
- Go to the Schedule Manager page (Preferences > Account > Schedule).
Deleting One or More Scheduled Calendar Items
You can delete one or more scheduled or recurring calendar items from the Schedule Manager page (Preferences > Account > Schedule). To do this:
My Contact Information
The My Contact Information page allows you to define or edit your contact information. The contact information you enter in this page is then visible to other users when they click the View User Account Details icon (
) associated with your account anywhere in SL1.
By default, the following fields will be automatically populated with values from your parent organization (if the values have been defined for your parent organization):
- Fax
- Address
- City
- State
- Postal Code
- Country
- Toll Free
- Time Zone
NOTE: To access the My Contact Information page, accounts of type "user" must be granted one or more access keys that includes the following access hook: MyInfo. Accounts of type "user" will then be able to view and edit the settings in the My Contact Information page.
To define or edit your contact information:
- Go to Preferences > Account > Information.
- In the My Contact Information page, position your cursor in the field you want to define or edit.
- You can edit one, multiple, or all of the following fields:
- First Name. Your first name.
- Last Name. Your last name.
- Title. Your title. This field can be up to 32 characters in length.
- Department. Your department. This field can be up to 36 characters in length.
- Phone. Your phone number at work. This field can be up to 24 characters in length.
- Fax. Your fax number. This field can be up to 24 characters in length.
- Mobile. Your cell phone number. This field can be up to 24 characters in length.
- Pager. Any other phone numbers for contacting you. This field can be up to 24 characters in length.
- Primary Email. Your primary email address. This field can be up to 64 characters in length.
- Secondary Email. Your mobile email address, for contacting you via cell-phone or mobile device. This field can be up to 64 characters in length.
- Alternate Email. Additional email address for contacting you. This field can be up to 64 characters in length.
- Pass Phrase. Questions that verify your account if you forget your password. SL1 does not use this field.
- Answer. This field contains the answer to the question selected in the Pass Phrase field. This field can be up to 64 characters in length.
- Street Address. Your street address at work. This field can be up to 64 characters in length.
- Suite/Building. Suite/Building for your location at work. This field can be up to 64 characters in length.
- City. City where you work. This field can be up to 64 characters in length.
- State. State where you work. You can select from a list of states.
- Postal Code. Postal code where you work. This field can be up to 12 characters in length.
- Country. Country where you work. You can select from a list of countries.
- Toll Free. Toll-free phone number for your work address. This field can be up to 24 characters in length.
- Time Zone. Time zone associated with your work address. Select from a list of time zones.
