The Skylar Connector (formerly called the Zebrium Connector), is also called the ze_connector service, and it continually checks your Skylar Automated RCA instance for suggestions and alerts. The Connector then looks for an SL1 device that matches the Skylar Automated RCA alerts, and sends the Skylar Automated RCA suggestions and alerts to that device in SL1.
As a result, the Skylar Connector lets you view Skylar Automated RCA suggestions and alerts in the following locations in SL1:
- The Events page
- The Event Investigatorpage for a Skylar Automated RCA suggestion or alert
- The tab and the tab of the Device Investigator page
- The Timeline widget and the tab of the Service Investigator page
The Skylar Connector requires SL1 12.2.0 or later.
Workflow for Configuring the Connector
Before you can view Skylar Automated RCA data on these SL1 pages, you will need to complete the following configuration steps in Skylar Automated RCA and SL1:
- Configure Skylar Automated RCA:
- Configure SL1:
- Configure the Skylar Connector:
Creating an Authentication Token in Skylar Automated RCA
You first need to access the Skylar Automated RCA user interface to get an authorization token, which you will use in the SL1 setup.
To create an authorization token in Skylar Automated RCA:
- In the Skylar Automated RCA user interface, go to the Access Tokens page (Settings (
) > Access Tokens). - Click . The Add Access Token dialog appears.
- Name. Type a name for this token.
- Role. Select Viewer.
- Deployment. Select the deployment that you want to monitor.
- Make sure the Enabled button is selected, and then click . The new token is added to the Access Tokens page. The token is in the format "Bearer <token>", such as Bearer abcdefghijk.
- Hover over the Name/Token column of the new token and click the button that appears.
- Save the access token for the next set of steps.
Configuring SL1
Complete the following steps to configure SL1 so it can use the Skylar Automated RCA Connector.
Create a Service Connection in SL1
To create a service connection in SL1:
- In SL1, go to the Service Connections page (Manage > Service Connections).
- Click Add Service Connection and select Skylar AI Engine. The Create Connection window appears.
- Name. Type a name for this new service connection.
- API Key. Paste the API key for Skylar AI into this field. Ask your ScienceLogic contact for this value.
- Skylar AI Engine URL. Add the endpoint URL for your Skylar AI instance. Ask your ScienceLogic contact for this value.
- Share data with. Select the All Organizations toggle (turn it blue) to share this connection with all existing and newly created organizations. Alternately, you deselect the All Organizations toggle (turn it gray) and select one or more organizations from the Selected Organizations drop-down to limit access to this connection to only those organizations.
- Click . The service connection is added to the Service Connections page.
Create an SL1 Authentication Token
Next, you will need to encode your SL1 credentials to create an SL1 authentication token:
Go to a Base64 encoding site like https://www.base64encode.org and paste your SL1 username and password in the text box. Use the following format:
<username>:<password>
For example: myuser:mypassword
Use the default settings and click . Your encoded credentials will look like the following:
bXl1c2VyOm15cGFzc3dvcmQ=
The authentication token is in the format "Basic <token>".
Copy the newly encoded credentials, which will work as your SL1 authentication token.
Create a Default Virtual Device (optional)
The Skylar Automated RCA Connector can send Skylar Automated RCA suggestions and alerts to any device in SL1. If you do not have a specific device that you want to use for this purpose, you can optionally configure a "default" SL1 device. The Connector will send any Skylar Automated RCA suggestions and alerts that do not map to existing SL1 devices to this default device.
For this purpose, you can create a virtual device in SL1 to receive all of these unassigned suggestions and alerts.
To create a default virtual device in SL1:
- Ensure that SL1 includes a device class for virtual devices. These device classes must have a device category of "virtual" and a collection type of "virtual".
- On the Device Manager page (Devices > Device Manager), click the button and select Create Virtual Device. The Create Virtual Device modal appears.
- Device Name. Name of the virtual device.
- Organization. Organization to associate with the virtual device. Select from the drop-down list of all organizations in SL1.
- Device Class. The device class to associate with the virtual device. Select from the drop-down list of device classes. Only device classes with a device category of "virtual" and a collection type of "virtual" appear in the list.
- Collector. Specifies which instance of SL1 will perform auto-discovery and gather data from the device. Can also specify a "virtual" connector. Select from the drop-down list of all collectors in SL1.
- Click to save the new virtual device. SL1 displays the new device ID after the text Device Added.
- Before you close the modal, make a note of the ID for your new virtual device. You can sort for this ID on the Devices page in SL1 to quickly locate this new virtual device.
Install the Skylar Automated RCA Event Policies PowerPack
To convert the API alerts sent by the Skylar Automated RCA Connector into SL1 events, you will need the Skylar Automated RCA event policies, which are available in the "Skylar (Zebrium) Event Policies" PowerPack. The event policies will be automatically enabled when you install the PowerPack.
To configure the Skylar (Zebrium) event policies:
- Download and install the "Skylar (Zebrium) Event Policies" PowerPack. For more information, see Importing and Installing a PowerPack.
- Go to the Event Policies page (Events > Event Policies) and sort by "Skylar (Zebrium)" in the Name column.
- Make sure all of the event policies from the PowerPack have a Status of Enabled. If not, check the boxes for the policies that are not enabled and click .
Configuring the Skylar (Zebrium) Connector
The Skylar Connector, also called the ze_connector service, continually checks your Skylar Automated RCA instance for suggestions and alerts. The Connector then looks for an SL1 device that match the Skylar alerts, and sends the suggestions and alerts to that device in SL1.
You will need to install the Skylar Connector RPM file on the SL1 server that you want to connect with Skylar Automated RCA.
System Requirements
The SL1 server where you install this service must have the following:
- systemd
- Python 3.8
- sudo access to the server
- SL1 version 12.2.0 or later, running Oracle Linux 8 or later, with the "Skylar (Zebrium) Event Policies" PowerPack installed
ScienceLogic strongly recommends that you create a separate SL1 account for the Skylar Automated RCA integration instead of using the default "em7admin" user account. For more information, see Manually Creating a New User Account in the SL1 Product Documentation.
Download and Install the RPM file for the Connector
You will need to download the RPM file from the ScienceLogic Support site, and then upload it to your SL1 system.
To download and install the RPM file:
Go to the ScienceLogic Support site at https://support.sciencelogic.com/s/.
Click the tab and select SL1 Platform. The Platform Downloads page appears.
Click the link for SL1 Hollywood Platform 12.2. The Release Version page appears.
In the Release Files section, click the RPM link for the Skylar Automated RCA Connector RPM file. A Release File page appears.
Click at the bottom of the Release File page.
SSH to the server where you are installing the RPM and run the following command to install the RPM:
sudo dnf install ze_connector-0.0.2-1.el8.noarch.rpm -y
Configure the config.yaml file as needed:
sudo vi /usr/bin/ze_connector/config.yaml
Restart the service and verify:
sudo systemctl restart zeconnector
sudo systemctl status zeconnector
sudo journalctl -u zeconnector
tail /usr/bin/ze_connector/out.log
The /usr/bin/ze_connector/config.yaml file is supplied as part of the RPM install. You can use this sample configuration file to set up new jobs. This section explains the structure of the config.yaml file. You can copy this file and update it for the connector jobs.
This schema will be overwritten to track the most recent Skylar Automated RCA event found, specifically the poll_timing.poll_start_time_iso field.
Configuration Schema
- jobs: (array, required) - polling jobs to run
- name: (str, required) - unique name of this job for log message readability
- sl1_api_config: (obj, required)
- api_url: (str, required) - URL endpoint for the SL1 API to query; do not include a "trailing slash" (/) at the end of the URL. Example: api_url: https://127.0.0.1
- api_auth: (str, required) - Basic authentication token for the SL1 API (see Create an SL1 Authentication Token for format)
- poll_timing: (obj, optional)
- poll_sleep_seconds: (int, optional default:60) - number of seconds to sleep between polling requests
- poll_start_time_iso: (str, optional default:now) - ISO 8601 timestamp for when to start querying for Skylar Automated RCA alerts
- sl1_default_device_ids: (array[str], optional default:[]) - list of SL1 device IDs to send alerts to if no device is matched automatically; omit to not send an alert if no device is matched
- ze_deployment_id: (str, required) - Deployment ID of the Skylar Automated RCA deployment to query. You can find this value in the Deployment ID column on the Deployments (Settings (
) > Deployments) page of the Skylar Automated RCA user interface. - ze_service_groups: (array[str], optional default:[]) - list of Skylar Automated RCA service groups to query. You can view a list of service groups by clicking the button on the Alerts page of the Skylar Automated RCA user interface. The Selected Filter dialog contains a list of service groups in the Service Groups filter. If you want to enable sample alerts, add "integration_test" under ze_service_groups in the config.yaml file.
- sl1_override_event_time: (bool, optional default:False) - overrides using the Skylar Automated RCA alert timestamp and instead uses now as when the alert occurred
Example Configuration
The following configuration will run two polling jobs:
- Job 1 will query my1.sl1.com using the defaults: poll every 60 seconds, starting from now
- Job 2 will query my2.sl1.com using overrides: poll every 120 seconds, starting from 09/05/2023, only query for Skylar Automated RCA service groups sg-1 and sg-2, send any unmatched events to SL1 device_id 1.
jobs:
# minimal config required job
# will default to all Skylar Service Groups
# will drop all alerts that don't match an SL1 device
# polling will occur every 60s, starting from now
- name: example_job_1
ze_deployment_id: "sciencelogic_default"
sl1_api_config:
api_url: https://my1.sl1.com
api_auth: "Basic dXNlcjpwYXNz"
# maximal config job
# will query only the 2 service groups provided
# will send any alerts that don't match an SL1 device to device/1
# will poll every 120 seconds from 9/5/2023 00:00:00 GMT to now
- name: example_job_2
- "1"
ze_service_groups:
- "sg-1"
- "sg-2"
- "integration_test"
ze_deployment_id: "some_other_deployment"
sl1_api_config:
api_url: https://my2.sl1.com
poll_timing:
poll_sleep_seconds: 120
poll_start_time_iso: "2023-09-05 00:00:00"
sl1_override_event_time: false
