What is Scheduled Maintenance?
Scheduled Maintenance is a date and time when a device is put into "maintenance mode". During maintenance mode, for the selected devices SL1 will generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. By default, no events are generated during maintenance. You can choose to enable or disable polling during maintenance mode. Even if polling is enabled, SL1 will collect information from the selected devices but will not generate applicable events for the devices.
SL1 includes tools that allow you to view, edit, and define scheduled maintenance for one or more devices. The Schedule Manager page allows you to schedule one-time and recurring maintenance tasks and downtime for a device. You can use the scheduled maintenance to:
- Specify a recurring downtime for routine maintenance (such as a database backup that occurs weekly every Tuesday at 3 AM).
- Specify a monthly schedule based on day of the week (such as a backup that occurs every third Sunday of the month at 11 PM)
- Specify one-time downtime (such as a specific day for upgrading software or hardware).
When a device is in maintenance, SL1 will generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. By default, no events are generated during maintenance. You can choose to enable or disable polling during maintenance mode. Even if polling is enabled during maintenance, SL1 will collect information from the device but will not generate applicable events for the device.
You can specify a "patch window" within the larger maintenance period. The "patch window" allows SL1 to limit the suppression events to a small time-frame within the larger maintenance window. For example:
Suppose you have to patch a server that is monitored by SL1. Suppose you know you will perform this task sometime between midnight and 6:00 AM. Suppose you know that the actual patch process will require only 15 minutes of downtime for the server. In SL1, you would define a maintenance window of 24:00 - 6:00 and a patch window of 15 minutes.
- At 24:00, SL1 generates an event saying that the server is going into maintenance mode. Because you have defined a patch window, SL1 continues to monitor this server as normal.
- At 3:00, you apply the patch to the server. The server reboots, and SL1 generates an event saying that the server is offline. This first event within the larger maintenance window triggers the start of the patch maintenance window.
- SL1 suppresses the event that triggered the patch maintenance window and instead generates an event "Patch Maintenance Window Opened".
- For the next 15 minutes, SL1 will suppress all events for the device.
- At 3:15, SL1 will generate an event for "Patch Maintenance Window Closed". This event clears the previous event "Patch Maintenance Window Opened".
- SL1 will now generate events for the device, even though the maintenance window extends until 6:00.
NOTE: If the patch was applied at 5:50, the server was rebooted, and SL1 generated an event saying that the server is offline, events would be suppressed only until the end of the maintenance window, 6:00, even though the patch window is 15 minutes.
NOTE: If you disable an active maintenance schedule, the device will be pulled out of maintenance mode; if you re-enable the schedule during the scheduled time window, the device will return to maintenance mode.
What is User Maintenance?
User maintenance is an option that allows a user to manually put a device in to "maintenance mode". During maintenance mode, for the selected devices SL1 will generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. By default, no events are generated during maintenance. You can choose to enable or disable polling during maintenance mode. Even if polling is enabled, SL1 will collect information from the selected devices but will not generate applicable events for the devices.
User maintenance mode is not scheduled. That is, a user must manually enable user maintenance to put a device into this mode and a user must manually disable user maintenance to turn off this mode for a device. User maintenance mode overrides scheduled maintenance for a device.
User maintenance can be enabled and disabled in the user interface or through the API.
The Maintenance Minimum Severity Setting
The global Maintenance Minimum Severity setting specifies the minimum severity required for an event to be suppressed during device maintenance and user maintenance. The default value is Healthy, which causes all events to be suppressed. To change this setting:
- In the Behavior Settings page, select a value in the Maintenance Minimum Severity drop-down list. The choices are Healthy, Notice, Minor, Major, or Critical.
- Select the button. Events with a severity lower than the severity you chose will now be generated for all devices in scheduled maintenance mode and user maintenance mode.
Enabling and Disabling User Maintenance for a Single Device
You can enable and disable user maintenance mode in the Device Properties page.
To enable or disable user maintenance mode for a device:
Go to the Device Manager page (Devices > Device Manager).
- In the Device Manager page, find the device for which you want to enable or disable user maintenance. Select its wrench icon (
). The Device Properties page is displayed.
- In the Device Properties page, edit the following fields:
- User Maintenance. Specifies whether the device is in user maintenance mode. During maintenance mode, for the selected devices SL1 will generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. By default, no events are generated during maintenance. You can choose to enable or disable polling during maintenance mode. Even if polling is enabled, SL1 will collect information from the selected devices but will not generate applicable events for the devices. Choices are:
- Enabled. Device will be put in user maintenance mode. The device will remain in this state until you or another user disables user maintenance mode.
- Disabled. User maintenance mode will be disabled for this device.
- User Maintenance Collection. The drop-down list to the right of the User Maintenance field specifies whether SL1 will poll the device during user maintenance mode. Choices are:
- Enabled. The device will be polled during user maintenance mode.
- Disabled. The device will not be polled during user maintenance mode.
Enabling and Disabling User Maintenance for One or More Devices
The Device Manager page contains a drop-down field in the lower right called Select Action. This field allows you to apply an action to multiple devices at once. From the Select Action menu, you can enable or disable user maintenance mode for multiple devices, simultaneously.
To enable or disable user maintenance mode for multiple devices:
- In the Device Manager page, select the checkbox for each device to which you want to apply the action. To select all checkboxes for all devices, select the red checkbox (
) at the top of the page. - In the Select Action drop-down list, select one of the following:
- Change User Maintenance Mode: Enabled with Collection. This option puts the selected devices into user maintenance mode with collection enabled. The devices will remain in this state until you or another user disables user maintenance mode.
- Change User Maintenance Mode: Enabled without Collection. This option puts the selected devices into user maintenance mode with collection disabled. The devices will remain in this state until you or another user disables user maintenance mode.
- Change User Maintenance Mode: Disabled. This option disables user maintenance mode for the selected devices.
- The changes are applied to each selected device.
Scheduling Maintenance for a Single Device
You can schedule maintenance and downtime for a device on the Schedules tab of the Device Investigator (or on the Schedule Manager page in the Device Administration panel in the classic SL1 user interface).
You can also view and manage all scheduled processes from the Schedule Manager page (Registry > Schedules > Schedule Manager). For more information, see the
Viewing the Schedule Manager
The Schedules tab of the Device Investigator (or the Schedule Manager page in the Device Administration panel in the classic SL1 user interface) displays the following information about each scheduled or recurring device maintenance window:
To edit a scheduled or recurring device maintenance window, click its wrench icon (
) and update the settings as needed on the Schedule Editor modal page. (For more information, see the section Defining a Scheduled or Recurring Device Maintenance Window for a Single Device.)
You can schedule a device maintenance window in SL1 from the Schedules tab of the Device Investigator (or the Schedule Manager page in the Device Administration panel in the classic SL1 user interface). SL1 will automatically set the status of the device to "maintenance" at the scheduled time.
To define a scheduled or recurring device maintenance window:
- Go to the Schedules tab of the Device Investigator. (Alternatively, in the classic SL1 user interface, go to the Schedule Manager page (Devices > Device Manager > wrench icon > Schedule)).
- Click . The Schedule Editor modal page appears.
On the Schedule Editor modal page, enter values in the following fields:
Basic Settings
Time Settings
If you want SL1 to automatically adjust for daylight savings time (if applicable), then you must select a named region (such as America/New York) in the Time Zone field. If you select a specific time zone (such as EST) or a specific time offset (such as GMT-5), then SL1 will not automatically adjust for daylight savings time. In addition, if you select a specific time zone, such as EST, that does not exist during daylight savings time observance, your schedules will be saved and execute at unexpected times.
Action Settings
- Collection Polling. Specifies whether SL1 should perform collection on the device during the scheduled maintenance. Choices are:
Enabled. During scheduled maintenance, SL1 will collect data from the device, but no events will be triggered for the device.
Disabled. During scheduled maintenance, SL1 will not collect data from the device. No events will be triggered for the device.
- Patch Window. You can specify a "patch window" within the larger maintenance period. The "patch window" allows SL1 to limit the suppression of events to a small time-frame within the larger maintenance window. Your choices are:
- None
Suppose you have to apply a patch to a server that is monitored by SL1. Suppose you know you will perform this task sometime between midnight and 6:00 AM. Suppose you know that the actual patch process requires only 15 minutes of downtime for the server. In SL1, you would define a maintenance window of 24:00 - 6:00 and a patch window of 15 minutes. In this scenario:
- At 3:00, you apply the patch to the server. The server reboots, and SL1 generates an event saying that the server is offline. The first event that both matches or exceeds the Patch Maintenance Minimum Severity in the Behavior Settings page (System > Settings > Behavior) and occurs within the larger maintenance window triggers the start of the patch window.
Scheduling Maintenance for One or More Devices
The Device Manager page contains a drop-down field in the lower right called Select Action. This field allows you to apply an action to multiple devices at once. From the Select Action menu, you can schedule maintenance for multiple devices, simultaneously.
To schedule maintenance for multiple devices:
- In the Device Manager page, select the checkbox for each device for which you want to schedule maintenance. To select all checkboxes for all devices, select the red checkbox (
) at the top of the page. - In the Select Action drop-down list, select Schedule Maintenance, and then click . The Schedule Editor modal page appears.
- To schedule maintenance for the selected devices, follow the steps described in the section Defining a Scheduled or Recurring Device Maintenance Window for a Single Device. The values you supply in the Schedule Editor modal page are applied to each selected device.
Enabling or Disabling Scheduled Maintenance for One or More Devices
You can enable or disable one or more scheduled or recurring device maintenance windows from the Schedules tab of the Device Investigator (or the Schedule Manager page in the Device Administration panel in the classic SL1 user interface).
To do this:
Deleting Scheduled Maintenance for One or More Devices
You can delete one or more scheduled or recurring device maintenance windows from the Schedules tab of the Device Investigator (or the Schedule Manager page in the Device Administration panel in the classic SL1 user interface).
To delete maintenance windows:
