A SOAP/XML transaction policy can monitor any server-to-server transaction that uses HTTP and can post files or forms (most commonly SOAP or XML but also Email or RSS feeds). SL1 sends a request and some data and then examines the result of the transaction and compares it to a specified expression match.
For each SOAP/XML policy, SL1 will collect data and create trend reports about availability, page size, download speed, lookup time, connection time, and transaction time.
Viewing the SOAP/XML Transaction Monitoring Policies
You can view a list of SOAP/XML transaction monitoring policies from the SOAP/XML Transaction Monitoring page. The SOAP/XML Transaction Monitoring page displays the following information on each policy:
- SOAP/XML Policy Name. Name of the policy.
- Policy URL. URL to which the policy sends test transactions.
Filtering the List of SOAP/XSL Transaction Policies
You can filter the list of policies on the SOAP/XML Transaction Monitoring page by one or more parameters. Only policies that meet all the filter criteria will be displayed in the SOAP/XML Transaction Monitoring page.
To filter by parameter, enter text into the desired filter-while-you-type field. The SOAP/XML Transaction Monitoring page searches for policies that match the text, including partial matches. By default, the cursor is placed in the left-most filter-while-you-type field. You can use the <Tab> key or your mouse to move your cursor through the fields. The list is dynamically updated as you type.Text matches are not case-sensitive.
- Policy Name. You can enter text to match, including special characters, and the SOAP/XML Transaction Monitoring page will display only policies that have a matching name.
- Policy URL. You can enter text to match, including special characters, and the SOAP/XML Transaction Monitoring page will display only policies that act on a matching URL.
- Policy ID. You can enter text to match, including special characters, and the SOAP/XML Transaction Monitoring page will display only policies that have a matching policy ID.
- Device Name. You can enter text to match, including special characters, and the SOAP/XML Transaction Monitoring page will display only policies aligned with a device with a matching device name.
- IP Address. You can enter text to match, including special characters, and the SOAP/XML Transaction Monitoring page will display only policies aligned with a device with a matching IP address.
- Device Category. You can enter text to match, including special characters, and the SOAP/XML Transaction Monitoring page will display only policies aligned with a device with a matching device category.
- Organization. You can enter text to match, including special characters, and the SOAP/XML Transaction Monitoring page will display only policies that have a matching organization.
Defining a SOAP/XML Transaction Monitoring Policy
You can define a SOAP/XML transaction monitoring policy for a device on the tab of the Device Investigator.
To define a SOAP/XML transaction monitoring policy:
- Go to the Devices page and click the Device Name of the device for which you want to define a SOAP/XML transaction monitoring policy. The Device Investigator displays.
- Click the tab.
- Click , and then select Create System Process Policy. The SOAP/XML Transaction Policy modal appears.
- In the SOAP/XML Transaction Policy modal, supply a value in each of the following fields:
- Select Device. Select a device from this drop-down list to align with this policy. By default, the current device is selected in this field.
NOTE: Before you can define a SOAP/XML policy, you must decide which managed device you want to associate with the policy. You might want to associate the policy with the device where the SOAP server or XML datastore resides, but you aren't required to do so. Alternately, you might want to create a virtual device to associate with a SOAP/XML transaction policy. Although SL1 will not use the device name to determine where to send the policy data, the reports that result from the policy will be aligned with the device you specify in the Select Device field.
- Enabled. SL1 will collect the data specified in this policy, from the device, at the frequency specified in the Process Manager page (System > Settings > Processes) for the Data Collection: Web Transaction Verifier process.
- Port. Port on web-server to which SL1 will send queries. This is usually port 80 (the HTTP port), or port 443 (the HTTPS port).
- Timeout. After the specified number of seconds, SL1 should stop trying to connect to the server. If the timeout period elapses before SL1 can connect to the server, an event is generated.
URL:port_number
- Proxy Account:Password. For companies or organizations that use proxy servers, enter the username and password for the proxy server in this field. Use the format:
username:password
- Default. By default, no authentication parameters are sent. Use this option for proxy servers that do not require authentication. However, if you supply a value in another field that requires authentication, such as Proxy Username:Password, the Any authentication parameter will be used.
- Post File Name. Some server-to-server transactions require data to be uploaded or sent as a Post File. For example, such a file may contain an XML or RSS feed. To send a Post File, specify a name, such as "myrss.xml" in this field. Supply the deliverable data in the Post Data Content field.
- Uniform Resource Locator (URL). URL or URI of the server to send the transaction to.
- Post String. If the URL is very long or requires data that cannot be transferred with a standard "GET" request (that is, data that cannot be included in the URL), you can enter a POST string in this field. The format is:
var1=val1&var2=val2&var3=val3
Birthyear=1980&Value=OK
- Content Encoding. Specifies the encoding method used for the request. Choices are:
- text/xml
- application/x-www-form-urlencoded
- multipart/form-data
- application/soap+xml
- text/xml;charset=utf-8
- Request Method. Specifies whether the request will be sent as an HTTP POST or an HTTP GET request.
- Post Data / Content. Data to send to the remote server, such as the body of a SOAP request. If you entered a value in the Post File Name field, enter the deliverable data in this field.
- Auth Account:Password. For websites that pop-up a dialog box asking for user name and password, use this field. Enter the username and password in this field. Use the format username:password.
- Default. By default, no authentication parameters are sent. Use this option for websites that do not require authentication. However, if you supply a value in another field that requires authentication, such as HTTP Auth Username:Password, the Any authentication parameter will be used.
- SSL Mode. Specifies whether SL1 should use SSL when communicating with the httpd service.
- Expression Check #1. Regular expression to search for. This can be any alphanumeric value, up to 128 characters in length.
- Expression Check #2. Another regular expression to search for. Can be any alphanumeric value, up to 128 characters in length.
- Custom Header Elements. Allows you to include a custom header with your transaction. Enter the header in this field.
- Compatibility. Specifies the type of application SL1 will be communicating with on the server. Choices are:
- Default. Standard HTTP/HTTPS.
- SOAP. SOAP-based requests.
- Cisco AXL. Cisco AXL interface.
Defining a SOAP/XML Transaction Monitoring Policy in the Classic SL1 User Interface
There are two places in SL1 from which you can define a monitoring policy for SOAP/XML transactions:
) for the device. - In the Device Administration panel, click the tab.
- From the menu in the upper right, clickCreate SOAP/XML Transaction Policy.
Or:
- In the SOAP/XML Transaction Monitoring page, click the button.
- The SOAP/XML Transaction Policy modal appears.
For information about completing the fields in the SOAP/XML Transaction Policy modal, see the section on Defining a SOAP/XML Transaction Policy.
Editing a SOAP/XML Transaction Monitoring Policy
To edit a SOAP/XML transaction monitoring policy:
- Click the tab.
). The SOAP/XML Transaction Policy modal appears. - In the SOAP/XML Transaction Policy modal, you can change the values in one or more of the fields described in the section on Defining a SOAP/XML Transaction Policy.
Editing a SOAP/XML Transaction Monitoring Policy in the Classic SL1 User Interface
There are two places in SL1 from which you can edit a monitoring policy for SOAP/XML transactions:
Or:
- In the SOAP/XML Transaction Monitoring page, find the policy you want to edit and click its wrench icon (
- In the SOAP/XML Transaction Policy modal, you can change the values in one or more of the fields described in the section on Defining a SOAP/XML Transaction Monitoring Policy.
Executing a SOAP/XML Transaction Monitoring Policy
After creating or editing a SOAP/XML transaction policy, you can manually execute the policy and view detailed logs of each step during the execution.
NOTE: After you define a SOAP/XML transaction monitoring policy and enable the policy, SL1 will automatically execute the policy every five minutes. However, you can use the steps in this section to execute the policy immediately and see debug information about the execution of the policy.
- Click the tab.
). - The Session Logs modal opens while the policy is executing. The Session Logs page provides detailed descriptions of each step during the execution. This is very helpful for diagnosing possible problems with a policy.
Executing a SOAP/XML Transaction Monitoring Policy in the Classic SL1 User Interface
To execute a SOAP/XML transaction monitoring policy in the classic SL1 user interface:
- In the SOAP/XML Transaction Monitoring page, find the policy you want to run manually.
) to manually execute the policy. - While the policy is executing, SL1 spawns a modal called Session Logs. The Session Logs page provides detailed descriptions of each step during the execution. This is very helpful for diagnosing possible problems with a policy.
Deleting a SOAP/XML Transaction Monitoring Policy
You can delete a SOAP/XML policy from the tab of the Device Investigator. When you delete a monitoring policy, SL1 no longer uses the policy to collect data from the aligned device. Deleting a monitoring policy will also remove all data that was previously collected by the policy.
To delete a SOAP/XML transaction monitoring policy:
- Click the tab.
Deleting a SOAP/XML Transaction Monitoring Policy in the Classic SL1 User Interface
You can delete one or more SOAP/XML transaction monitoring policies from the SOAP/XML Transaction Monitoring page. When you delete a monitoring policy, SL1 no longer uses the policy to collect data from the aligned device. Deleting a monitoring policy will also remove all data that was previously collected by the policy.
To delete a SOAP/XML transaction monitoring policy in the classic SL1 user interface:
- Go to the SOAP/XML Transaction Monitoring page (Registry > Monitors > SOAP-XML Transactions).
- In the SOAP/XML Transaction Monitoring page, select the checkbox(es) for each SOAP/XML policy you want to delete. Click the checkmark icon (
) to select all of the SOAP/XML policies. - In the Select Action menu in the bottom right of the page, select Delete Monitors.
- Click the button to delete the selected SOAP/XML monitoring policies.
Viewing Reports on a SOAP/XML Transaction Policy
See the section on Viewing Performance Graphs for information and examples of reports for monitoring SOAP/XML transactions.
Viewing Raw Data from a SOAP/XML Policy
You can view the raw data sent from SL1 to the external URL and the raw data returned to SL1. This feature can be helpful when troubleshooting a policy.
To view raw data from a SOAP/XML policy:
- In the SOAP/XML Transaction Monitoring page, find the policy you want to view raw data for.
- Click the page icon (
) to the far left in the table. - The Results Page Dump modal appears. This page displays the raw data sent to the external URL and the raw data returned to SL1.
