What is Aruba Central?
Aruba Central is a cloud-based platform that provides management tools and built-in analytics for Aruba Instant Access Points (IAPs), switches, and gateways. In each Aruba network, one IAP acts as a virtual controller, which is a single configuration and management point for the network.
What Does the Aruba Central PowerPack Monitor?
To monitor Aruba Central using SL1, you must install the Aruba Central PowerPack. This PowerPack enables you to discover, model, and collect data about Aruba Central virtual controllers and their components.
The Aruba Central PowerPack includes:
- Dynamic Applications to discover and monitor Aruba Central virtual controllers and their component devices
- Device Classes for each of the Aruba Central components that the Aruba Central PowerPack can monitor
- Event Policies that are triggered when Aruba Central component devices meet certain status criteria
- Two samples of SOAP/XML Credential that you can use to create your own Aruba Central Credential
- A Device Template that aligns Dynamic Applications to the Aruba Central virtual controller and enables you to discover component devices for that virtual controller
- Device Dashboards that display information about Aruba Central component devices
Installing the Aruba Central PowerPack
If you are currently using a version prior to 103 of this PowerPack, a direct upgrade to version 200 is not supported and a fresh install and re-discovery of devices may be required with version 200. Versions 103, 104, and 104.1 can be upgraded directly to version 200 if there is only one DCM tree discovered per Aruba Central account. If separate API keys are being used to discover sites individually as their own DCM tree, a fresh install and re-discovery is also required. The steps for both methods can be found below. Follow those procedures to ensure accurate data collection post upgrade.
After upgrading the PowerPack to version 200, follow the steps below:
Disable the listed Dynamic Applications.
Aruba: Central AP Container Discovery
Aruba: Central SD-WAN Gateway Container Discovery
Aruba: Central Switch Container Discovery
For instructions on disabling Dynamic Applications, see the section on "Performing Other Tasks in the Dynamic Application Manager Page " in the
Disable the listed container device components.
AP Container
Switch Container
Apply the new Aruba template included in this version of the PowerPack to the root virtual device. This will cause devices to move from the container component devices to sites.
For instructions on applying a template, see the see the Aligning the Device Template to Your Aruba Central Virtual Device section.
Once all components have been migrated to sites, remove the empty container device components listed in step 2.
Delete the disabled Dynamic Applications listed in step 1.
To ensure accurate data collection after upgrading PowerPack from any of the previous versions, perform the additional steps to authenticate using Oauth Grant Mechanism:
- Go to the Credential Management page (System > Manage > Credentials). Identify your current credential and click on the credential’s name to edit.
- In the Embed Password [%P] field, type your Aruba Central client secret key.
- In the Embed Value [%1] field, type "AuthOauth2".
- In the Embed Value [%2] field, type your Aruba Central customer ID.
- In the Embed Value [%3] field, type your Aruba Central client ID.
- In the Embed Value [%4] field, set a page size between 1 and 1000.
- Remove all HTTP Headers.
- Remove any CURL Option and set the SSLVERIFYPEER Curl Option to 0 as the value and click Save.
To authenticate using the Offline Token Mechanism:
- Go to theCredential Management page (System > Manage > Credentials). Identify your current credential and click on the credential’s name to edit.
- In the Embed Value [%1] field, type "OfflineToken".
- In the Embed Value [%2] field, type the refresh token.
The following Dynamic Applications will be disabled by default, and all collection for them will stop. You should manually enable these Dynamic Applications to restart collection, being conscious of the number of APs in the field: "Aruba: Central AP Cache", "Aruba: Central AP Configuration", "Aruba: Central AP Discovery" and "Aruba: Central AP Performance". If the number of devices is higher than 8000, you must configure your scale settings appropriately. You can follow the steps outlined in the SL1 Scale Settings section.
