The following sections describe how to configure and discover Cisco Cloud Services Platform (CSP) clusters for monitoring by SL1 using the Cisco: Cloud Services Platform PowerPack:
Prerequisites for Monitoring CSP Clusters
To configure the SL1 system to monitor CSP clusters using the Cisco: Cloud Services Platform PowerPack, you must have the following information about the clusters that you want to monitor:
  • Username and password of a user with REST API read access and a role of operator-group or admin-group
  • SNMP community string with read privileges and the port set to 161
For more information about these requirements, see http://www.cisco.com/c/en/us/td/docs/switches/datacenter/csp_2100/config_guide/b_Cisco_CSP_2100_Config_Guide.html.
Additionally, you must establish a Net-SNMP public community string with the port set to 1610. To do so:
  1. Log in to the command line of the CSP device as an administrative user.
  2. Run the following commands:
netsnmp agent port 1610
netsnmp community public
Creating SNMP Credentials for CSP Clusters
Before you can discover and monitor Cloud Services Platform (CSP) clusters in SL1, you must first create two SNMP credentials (one for port 161 and another for port 1610) in SL1. These credentials, along with a Basic/Snippet credential and SSH/Key credential that you must also create, enable SL1 to collect data from the clusters. Two example SNMP credentials that you can edit for your own use are included in the Cisco: Cloud Services Platform PowerPack.
For more information about the configuration required for the two SNMP credentials, see the Prerequisites section.
To configure the port 161 SNMP credential for CSP:
  1. Locate the Cisco: CSP SNMP Port 161 Example credential, click its Actions icon () and select Duplicate. A copy of the credential, called Cisco: CSP SNMP Port 161 Example copy appears.
  1. Click the Actions icon () for the Cisco: CSP SNMP Port 161 Example copy credential and select Edit/Test.The Edit Credential page appears. Enter values in the following fields:
  • Name. Enter a new name for the credential.
  • SNMP Community (Read Only). Enter the port 161 community string for the CSP cluster.
  1. Use the default values for the other fields on this page.
To configure the port 1610 SNMP credential for CSP:
  1. Locate the Cisco: CSP SNMP Port 1610 Example credential, click its Actions icon () and select Duplicate. A copy of the credential, called Cisco: CSP SNMP Port 1610 Example copy appears.
  1. Click the Actions icon () for the Cisco: CSP SNMP Port 1610 Example copy credential and select Edit/Test.The Edit Credential page appears. Enter values in the following fields:
  • SNMP Community (Read Only). Enter the port 1610 community string for the CSP cluster.
  2. Click the Save & Close button.
Creating SNMP Credentials for CSP Clusters in the SL1 Classic User Interface
  1. Locate the Cisco: CSP SNMP Port 161 Example credential, then click its wrench icon (). The Edit SNMP Credential modal page appears.
  1. Make entries in the following fields:
  2. Click the Save As button.
  3. When the confirmation message appears, click OK.
  1. Locate the Cisco: CSP SNMP Port 1610 Example credential, then click its wrench icon (). The Edit SNMP Credential modal page appears.
Creating a Basic/Snippet Credential for CSP Clusters
Some Dynamic Applications in the Cisco: Cloud Services Platform PowerPack collect data from CSP clusters using the REST API. These Dynamic Applications require a Basic/Snippet credential to enable SL1 to communicate with the cluster. An example Basic/Snippet credential that you can edit for your own use is included in the Cisco: Cloud Services Platform PowerPack.
For more information about the configuration required for the Basic/Snippet credential, see the Prerequisites section.
To create a Basic/Snippet credential to monitor CSP:
  1. Locate the Cisco: CSP Example credential, click its Actions icon () and select Duplicate. A copy of the credential, called Cisco: CSP Example copy appears.
  2. Click the Actions icon () for the Cisco: CSP Example copy credential and select Edit/Test.The Edit Credential page appears. Enter values in the following fields:
  • Username. Enter the username for a user with REST API read access to the CSP cluster and a role of operator-group or admin-group.
  • Password. Enter the password for the REST API user.
Creating a Basic/Snippet Credential for CSP Clusters in the SL1 Classic User Interface
  1. Locate the Cisco: CSP Example credential, and then click its wrench icon (). The Edit Basic/Snippet Credential modal page appears.
Creating an SSH/Key Credential for CSP Clusters
Some Dynamic Applications in the Cisco: Cloud Services Platform PowerPack collect data from CSP clusters from the command line interface instead of the API. These Dynamic Applications require an SSH/Key credential to enable SL1 to communicate with the cluster. An example SSH/Key credential that you can edit for your own use is included in the Cisco: Cloud Services Platform PowerPack.
This functionality utilizes MD5 password encryption. As such, it is not currently available for use in Federal Information Processing Standard (FIPS)-compliant installations of SL1. If you attempt to discover CSP cluster data using an SSH/Key credential in FIPS-compliant installations of SL1, the cluster component device will not be created and an exception error message appears in the system log.
To create an SSH/Key credential to monitor CSP:
  1. Locate the Cisco: CSP 2100 CLI Example credential, click its Actions icon () and select Duplicate. A copy of the credential, called Cisco: CSP 2100 CLI Example copy appears.
  2. Click the Actions icon () for the Cisco: CSP 2100 CLI Example copy credential and select Edit/Test.The Edit Credential page appears. Enter values in the following fields:
  • Timeout(ms). Keep the default setting.
  • Hostname/IP. Type the IP address or hostname of the CSP cluster you want to monitor.
  • Port. Type the SSH port number for the CSP cluster you want to monitor.
  • Username. Type the username for a user with administrator access to the CSP cluster command line interface.
  • Password. Type the user's password.
  • Private Key (PEM Format). Keep this field blank.
The private key can have a maximum of 64 characters per line. Therefore, you cannot use keys in the OpenSSH format, because that format uses 70 characters per line. When you attempt to save the credential, SL1 will validate that the private key entered is in the correct format. You will be able to save the credential only if the private key is correctly formatted.
Creating an SSH/Key Credential for CSP Clusters in the SL1 Classic User Interface
  1. Locate the Cisco: CSP 2100 CLI Example credential, and then click its wrench icon (). The Edit SSH/Key Credential modal page appears.
  1. Click the Save As button.
Discovering CSP Clusters
When you discover your Cloud Services Platform (CSP) cluster with SL1, SL1 auto-aligns a series of Dynamic Applications to discover, configure, and monitor the CSP cluster and all of its associated component devices.
To discover your CSP cluster, perform the following steps:
  1. On the Credentials page, locate and select the two SNMP credentials that you created (one for port 161 and the other for port 1610), and the Basic/Snippet credential and the SSH/Key credential for each of the CSP nodes you want to discover.
You must include a minimum of three credentials (one SNMP credential and two Basic/Snippet credentials) for each CSP node with unique credential information.
  • List of IPs/Hostnames. Type the IP address of each CSP node you want to discover.
Discovering CSP Clusters in the SL1 Classic User Interface
  1. Click the Create button. The Discovery Session Editor page appears.
  • IP Address/Hostname Discovery List. Enter the IP address of each CSP node you want to discover.
  • SNMP Credentials. Select the two SNMP credentials that you created (one for port 161 and the other for port 1610) for each of the CSP nodes you want to discover.
  • Other Credentials. Select the Basic/Snippet credential and the SSH/Key credential for each of the CSP nodes you want to discover.
  2. Click the Save button.
  3. The Discovery Control Panel page will refresh. Click the lightning bolt icon () for the discovery session you created.
Viewing CSP Component Devices
When SL1 discovers your CSP cluster, SL1 creates component devices that represent each component in the cluster.
In addition to the Devices page, you can view all associated component devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by SL1. The Device Components page displays all root devices and component devices in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with your CSP cluster, find the root device and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. SL1 automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for your CSP cluster, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Maps.
In addition to parent/child relationships between component devices, SL1 also creates relationships between CSP-2100 nodes and Cisco UCS Standalone servers.
