The following sections provide an overview of Cisco Cloud Services Platform (CSP) devices and the Cisco: Cloud Services Platform PowerPack.
What is Cisco Cloud Services Platform?
Cisco Cloud Services Platform is a platform for virtualizing data center network functions. The hardware and software platform includes REST APIs, a command-line interface, and a web user interface for creating and managing virtual machines.
What Does the Cisco: Cloud Services Platform PowerPack Monitor?
To monitor Cloud Servies Platform (CSP) devices using SL1, you must install the Cisco: Cloud Services Platform PowerPack. This PowerPack enables you to discover, model, and collect data about CSP clusters, nodes, and services.
The Cisco: Cloud Services Platform PowerPack includes:
- Four example credentials (two SNMP credentials, a Basic/Snippet credential, and an SSH/Key credential) you can use to create the credentials that enable you to collect data from CSP devices
- Dynamic Applications to discover and monitor the CSP component devices
- Device Classes for each type of CSP component device SL1 monitors
- Event Policies and corresponding alerts that are triggered when CSP component devices meet certain status criteria
- Run Book Actions and Policies that align the correct device class to CSP component devices based on GUID and that merge CSP component devices with the appropriate physical components
- Device dashboards for each type of discovered CSP component device
Installing the Cisco: Cloud Services Platform PowerPack
