Discovery
The following sections describe how to discover Cisco Unified Contact Center Enterprise devices for monitoring by SL1 using the Cisco: Contact Center Enterprise PowerPack:
Discovering Component Devices in Cisco Unified Contact Center Enterprise
When you discover your Cisco Unified Contact Center Enterprise (UCCE) instance with SL1, SL1 auto-aligns a series of Dynamic Applications to discover, configure, and monitor UCCE, Customer Voice Portal (CVP), Cisco Unified Intelligence Center (CUIC), and/or Finesse services, and all the associated component devices.
To discover your UCCE instance, perform the following steps:
  1. On the Credentials page, locate and select:
  • List of IPs/Hostnames. Enter the IP address(es) or the range of IP addresses for the UCCE, CVP, CUIC, and/or Finesse services you want to discover.
It can take several minutes after the discovery session has completed for Dynamic Applications to appear on the Dynamic Application Collections page.
Discovering Component Devices in Cisco Unified Contact Center Enterprise in the SL1 Classic User Interface
  1. Click the Create button. The Discovery Session Editor page appears.
  2. Click the Save button.
  3. The Discovery Control Panel page refreshes. Click the lightning bolt icon () for the discovery session you created.
Viewing Cisco Unified Contact Center Enterprise Component Devices
When SL1 discovers your Cisco Unified Contact Center Enterprise (UCCE), Customer Voice Portal (CVP), Cisco Unified Intelligence Center (CUIC), or Finesse services, SL1 creates component devices that represent each component in those services.
You can view all associated component devices in the following places in the user interface:
  • The Device Investigator Map page (click Map in the Device Investigator page) displays a map of a particular device and all of the devices with which it has parent-child relationships. Double-clicking any of the listed devices reloads the page to make the selected device the primary device:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by SL1, in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with your service, find the UCCE, CVP, CUIC, or Finesse device and click its plus icon (+):
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This view makes it easy to visualize and manage root nodes and their components. SL1 automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for your UCCE, CVP, CUIC, or Finesse service, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Maps.
