The following sections provide an overview of Cisco
What is Cisco ESA?
Cisco Email Security Appliance (ESA) is a virtual, all-in-one appliance that provides protection against spam, malware, viruses, and other inbound and outbound email threats and annoyances.
What Does the Cisco: ESA PowerPack Monitor?
To monitor Cisco Email Security Appliances devices using SL1, you must install the Cisco: ESA PowerPack. This PowerPack enables you to discover and collect data about Cisco Email Security Appliances.
The Cisco: ESA PowerPack includes:
- Dynamic Applications to discover and monitor performance and configuration data for Cisco ESA devices
- Device Classes for each of the Cisco ESA devices that SL1 monitors
- Event Policies that are triggered when Cisco ESA devices meet certain status criteria
- A device dashboard that displays performance data about Cisco ESA devices
Installing the Cisco: ESA PowerPack
