The following sections provide an overview of Cisco HyperFlex and the Cisco HyperFlex PowerPack:
NOTE: The Cisco: Hyperflex PowerPack supports only HyperFlex API version 4.5 and later.
What Does the Cisco: HyperFlex PowerPack Monitor?
To monitor HyperFlex data clusters using SL1, you must install the Cisco: Hyperflex PowerPack. This PowerPack enables you to discover, model, and collect data about HyperFlex data clusters.
The Cisco: Hyperflex PowerPack includes:
- An example credential you can use to create SOAP/XML credentials to connect to HyperFlex data clusters
- Dynamic Applications to discover and monitor HyperFlex data clusters
- A Device Class for HyperFlex data clusters
- Event Policies and corresponding alerts that are triggered when HyperFlex data clusters meet certain status criteria
- A Run Book Action and Policy to ensure that HyperFlex devices are classified to the appropriate Device Class
Installing the Cisco: HyperFlex PowerPack
