The following sections describe how to configure and discover Cisco Intersight devices for monitoring by SL1 using the Cisco: Intersight PowerPack:
Prerequisites for Monitoring Cisco Intersight
To configure the SL1 system to monitor Cisco Intersight devices using the Cisco: Intersight PowerPack, you must first have the following information about Cisco Intersight:
  • The username and password for your Cisco Intersight account.
  • A Cisco Intersight REST API key ID and Secret Key. See the Introduction to the Cisco Intersight REST API section of the Cisco Intersight documentation to view how to generate the REST API key ID and Secret Key.
Creating a "Universal" Type Credential for Cisco Intersight
To configure SL1 to monitor Cisco Intersight devices, you must create a "universal" type credential. This credential allows the Dynamic Applications in the Cisco: Intersight PowerPack to communicate with Cisco Intersight.
To define a "universal" type credential to access Cisco Intersight:
  2. Click Create New and select Create Cisco Intersight Credential. The Create Credential modal page appears.
  • URL. Keep the default URL (https://www.intersight.com/api/).
  • Authentication type. Keep the default value (IntersightHTTPKeyAuth).
  • Cisco Intersight API Key ID.Type your Cisco Intersight API key ID.
  • Cisco Intersight private PEM key. Type your Cisco Intersight secret key.
Proxy Settings
Toggle on this field if you are using a proxy server to communicate with your Cisco Intersight account, enter the values in the fields listed below:
  • Proxy scheme type. Select http or https from the drop-down field.
  • Proxy Hostname/IP. Enter the hostname or the IP address associated with your device.
There is not currently a credential test available for the Cisco: Intersight PowerPack.
  1. CIick Save & Close.
Cisco Intersight Guided Discovery
You can use the Guided Discovery Framework process in SL1to guide you through a variety of existing discovery types in addition to traditional SNMP discovery. This process, which is also called "guided discovery", lets you choose a discovery type based on the type of devices you want to monitor. The Guided Discovery workflow includes a button for Cisco Intersight.
To run a Guided Discovery:
  2. Select the Cisco button. Additional information about the requirements for device discovery appears in the General Information pane to the right.
  1. On the Credential Selection page of the guided discovery process, select the Cisco Intersight "universal" type credential that you configured, and then click Next. The Root Device Details page appears.
  • Root Device Name. Type the name of the root device for the Cisco Intersight root device you want to monitor.
  1. Click Next. SL1 creates the Cisco Intersight root device with the appropriate Device Class assigned to it and aligns the relevant Dynamic Applications. The Final Summary page appears.
  1. Click Close.
This PowerPack uses the snippet framework in order to function. Not all values returned in an API call in a Dynamic Application may have a collection object. For more information about how collections can be modified, added, or deleted using the snippet framework, see the Snippet Framework documentation.
Viewing Cisco Intersight Component Devices
In addition to the Devices page, you can view the Cisco Intersight system and all associated component devices in the following places in the user interface:
  • The Device Investigator Map page (click Map in the Device Investigator page) displays a map of a particular device and all of the devices with which it has parent-child relationships. Double-clicking any of the listed devices reloads the page to make the selected device the primary device
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by SL1 in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with a Kubernetes cluster, find the cluster device and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. SL1 automatically updates the Component Map as new component devices are discovered. SL1 also updates each map with the latest status and event information. To view the map for a Kubernetes cluster, go to Classic Maps > Device Maps > Components, and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Views.
Configuring Alerts to Receive Alarms from Cisco Intersight
The Cisco: Intersight PowerPack includes the "Cisco: Intersight Alarms Configuration" Dynamic Application that monitors Cisco Intersight alarms and associates the alarms with the appropriate component devices, if applicable. The Cisco Intersight API reports alarms regardless of whether or not they are acknowledged. You can choose to change your alert formulas in SL1 to ignore acknowledged alerts if you do not want to see them. To learn more about filtering alerts, see the section on Views.
If you expect that you will go 24 hours without collecting an alarm, ScienceLogic recommends toggling on the Disable Object Maintenance option on the Dynamic Application to avoid it being auto-disabled due to no collected data.
Troubleshooting Known Issues for Cisco Intersight
The following sections describe some issues you might encounter when monitoring Cisco Intersight.
Error when Running Dynamic Applications in Debug Mode
An error message similar to the one below displays when executing any Cisco: Intersight " Dynamic Application in debug mode.
WARNING:snippet_framework.internal.silo.low_code_steps.rest.authenticators:Error parsing time to next request from Credential. Setting to 5.
2023-10-30 18:32:43,752 - [a:896,d:27,c:9500,s:low_code] Successfully parsed the Snippet Argument
INFO:snippet_framework.step.generic_step_area:[a:896,d:27,c:9500,s:low_code] Successfully parsed the Snippet Argument
2023-10-30 18:32:43,752 - Error parsing time to next request from Credential. Setting to 5.
Current Limitations of the Cisco: Intersight PowerPack
The Cisco: Intersight PowerPack is currently limited due to the way that Cisco Intersight returns data from the API.
  • The Cisco Intersight API returns the last collected data when a device is disconnected and does not provide any indication that the device is disconnected. If a device is disconnected in Cisco Intersight, SL1 may continue to show the last collected data from Cisco Intersight.
  • Cisco Intersight does not publish rate limiting. Due to this, SL1 cannot provide scale numbers.
