The following sections provide an overview of Cisco Intersight and the Cisco: Intersight PowerPack:
What is Cisco Intersight?
Cisco Intersight is a cloud operations platform allowing for advanced infrastructure, workload optimization, and Kubernetes services. Cisco Intersight infrastructure services include the deployment, monitoring, management, and support of physical and virtual infrastructure.
What Does the Cisco: Intersight PowerPack Monitor?
To monitor Cisco Intersight using SL1, you must install the Cisco: Intersight PowerPack. This PowerPack enables you to discover, model, and collect data about Cisco:Intersight devices.
The Cisco: Intersight PowerPack includes:
- Dynamic Applications that enable SL1 to discover, model, and monitor Cisco Intersight devices
- Event Policies that are triggered when Cisco Intersight devices meet certain status criteria
- Device Classes for each type of Cisco Intersight device monitored
Installing the Cisco: Intersight PowerPack
