The following sections provide an overview of Cisco Tetration Analytics and the Cisco: Tetration PowerPack:
What is Cisco Tetration Analytics?
Cisco Tetration Analytics provides complete visibility into data center applications. It uses unsupervised machine learning techniques to generate application behavior insights and automated white-list policies for granular segmentation.
What Does the Cisco: Tetration PowerPack Monitor?
To monitor Tetration Analytics using SL1, you must install the Cisco: Tetration PowerPack. This PowerPack includes:
- A sample credential you can use to create credentials to connect to Tetration Analytics clusters
- Dynamic Applications to discover, model, and collect configuration data for Tetration Analytics clusters and component devices
- Device Classes for each of the Tetration Analytics components SL1 monitors
Installing the Cisco: Tetration PowerPack
