- To view a pop-out list of menu options, click the menu icon ( ). ).
- To view a page containing all of the menu options, click the Advanced menu icon ( ). ).
The following sections provide an overview of Cisco UCS Director and the Cisco: UCS Director PowerPack:
What Does the Cisco: UCS Director PowerPack Monitor?
The Dynamic Applications in the Cisco: UCS Director PowerPack can monitor performance metrics and/or collect configuration data for the following UCS Director components:
- ACI Applications
- ACI Tenants
- Application Containers
- Cloud Services
- Pods
- Servers
- Sites
Installing the Cisco UCS DirectorPowerPack
Before completing the steps to this
