Introduction to the Cisco UCS Manager PowerPack
The following sections provide an overview of Cisco UCS Manager and the Cisco: UCS PowerPack:
What is Cisco UCS Manager?
Cisco UCS Manager is a management system for all of the components in Cisco's Unified Computing System. Cisco UCS combines computing, network, and storage technologies, including fabric interconnects, blade servers, server chassis, and other components.
What Does the Cisco: UCS PowerPack Monitor?
To monitor Cisco UCS Manager using SL1, you must install the Cisco: UCS PowerPack. This PowerPack enables you to discover, model, and collect data about a UCS Manager and its component devices.
The Cisco: UCS PowerPack includes:
  • Dynamic Applications that enable SL1 to discover, model, and monitor Cisco UCS Manager devices
  • Event Policies that are triggered when Cisco UCS Manager component devices meet certain status criteria
  • Device Classes for each type of Cisco UCS Manager component device monitored
  • A sample credential for discovering Cisco UCS Manager component devices
Installing the Cisco: UCS PowerPack
Before completing the steps in this section, you must import and install the latest version of the Cisco: UCS PowerPack.
