Introduction
The following sections provide an overview of Cisco UCS standalone rack servers and the Cisco: UCS Standalone Rack Server PowerPack:
What Are Cisco UCS Standalone Rack Servers?
Cisco UCS standalone rack servers are rack-mounted Cisco UCS servers that are managed by the Cisco Integrated Management Controller (CIMC) rather than the Cisco UCS Manager. This currently includes Cisco UCS C-Series and E-Series servers.
What Does the Cisco: UCS Standalone Rack Server PowerPack Monitor?
To monitor Cisco UCS standalone rack servers using SL1, you must install the Cisco: UCS Standalone Rack Server PowerPack. This PowerPack includes:
  • An example Credential that you can use as a template to create SOAP/XML credentials to connect to the Cisco UCS standalone rack servers that you want to monitor
  • Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for Cisco UCS standalone rack servers
  • Device Classes for each type of Cisco UCS rack server that SL1 monitors
  • Event Policies and corresponding alerts that are triggered when Cisco UCS standalone rack servers meet certain status criteria
  • A Device Template that you can apply during discovery
  • A Device Dashboard that displays information about Cisco UCS standalone rack servers
  • A Run Book Action/Policy that assigns Cisco UCS rack servers to the correct Device Classes when they are discovered
The CIMC XML API provides inconsistent data to the Cisco: UCS Standalone Rack Server PowerPack for servers with firmware versions prior to 2.0(8d). Similarly, the PowerPack cannot collect server utilization metrics for servers with M3 architecture, but it can collect this information for M4 models.
Installing the Cisco: UCS Standalone Rack Server PowerPack
Before completing the steps in this section, you must import and install the latest version of the Cisco: UCS Standalone Rack Server PowerPack.
