The following sections provide an overview of ancillary Cisco UC devices and the Cisco: UC Ancillary PowerPack:
What are Ancillary Cisco UC Devices?
SL1 enables you to monitor ancillary Cisco UC devices, including Cisco Unified Border Element (CUBE)-enabled devices and Cisco Emergency Responder.
CUBE is a Session Border Controller that extends Session Initiation Protocol-based voice and video connectivity between networks. It can run on a variety of Cisco routers or can be deployed virtually.
Emergency Responder supplements the emergency 9-1-1 functionality offered by Cisco Unified Communications Manager (CUCM) by helping CUCM pinpoint the location of emergency callers.
What Does the Cisco: UC Ancillary PowerPack Monitor?
To monitor ancillary UC devices using SL1, you must install the Cisco: UC Ancillary PowerPack. The PowerPack includes:
- An example credential you can use as a template to create SSH/Key credentials to connect to the devices you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and/or collect configuration data for ancillary UC devices
- Device Classes for each of the ancillary UC devices that SL1 monitors
- Event Policies that are triggered when ancillary UC devices meet certain status criteria
- A device dashboard that displays host resource and interface information about ancillary UC devices
Installing the Cisco: UC Ancillary PowerPack
