Introduction
The following sections provide an overview of Dell EMC Isilon and the Dell EMC: Isilon PowerPack:
What is Dell EMC Isilon?
Dell EMC Isilon is a clustered, scale-out Network Attached Storage (NAS) array. The Dell EMC: Isilon PowerPack uses the Isilon API to discover the storage array and collect health, configuration, performance, and capacity information.
What Does the Dell EMC: IsilonPowerPack Monitor?
To monitor Dell EMC Isilon storage devices with SL1, you must install the Dell EMC: Isilon PowerPack. This PowerPack lets you discover, model, and collect data about Isilon storage devices.
The Dell EMC: Isilon PowerPack includes:
  • Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for Dell EMC Isilon devices
  • Device Classes for each type of Isilon device monitored
  • Example credentials that you can use as templates to create a SOAP/XML credential for connecting to Isilon devices and an SNMP credential for device class alignment
Installing the PowerPack
Before completing the steps in this section, you must import and install the latest version of the Dell EMC: Isilon PowerPack.
