Introduction
This section describes how to monitor Dell EMC VMAX devices in SL1 using the EMC: VMAX PowerPack.
The "EMC: VMAX" PowerPack uses an older VMAX protocol. For newer VMAX releases, see the "Dell EMC: VMAX and PowerMax Unisphere API" PowerPack.
Overview of the EMC: VMAX PowerPack
To monitor Dell EMC VMAX storage systems using SL1, you must install the EMC: VMAX PowerPack, which enables you to discover, model, and collect data about VMAX storage arrays and their components.
The EMC: VMAX PowerPack includes:
  • An example credential you can use to create Basic/Snippet credentials to connect to the Dell EMC VMAX system
  • Dynamic Applications to discover and monitor the VMAX system
  • Device Classes for each type of device in the VMAX system monitored by SL1
  • Event Policies and corresponding alerts that are triggered when devices in the VMAX system meet particular criteria
The EMC: VMAX PowerPack is installed by default in SL1.
Installing the EMC: VMAX PowerPack
Before completing the steps in this section, you must import and install the latest version of the EMC: VMAX PowerPack.
