Introduction
The following sections provide an overview of the Dell EMC: VMAX and PowerMax Unisphere API PowerPack:
What Does theDell EMC: VMAX and PowerMax Unisphere API PowerPack Monitor?
To monitor Dell EMC VMAX and PowerMax storage systems using SL1, you must install the Dell EMC: VMAX and PowerMax Unisphere API PowerPack, which enables you to discover, model, and collect data about VMAX and PowerMax storage arrays and their components using the Unisphere REST API.
For information about the EMC: VMAX PowerPack, which uses a Dell EMC SMI-S Provider to monitor VMAX systems, see the section on Monitoring Dell EMC VMAX.
The Dell EMC: VMAX and PowerMax Unisphere API PowerPack includes:
  • An example Credential you can use to create SOAP/XML credentials to connect to your Dell EMC VMAX or PowerMax system
  • Dynamic Applications to discover and monitor your VMAX or PowerMax system
  • Device Classes for each type of device in your VMAX or PowerMax system monitored by SL1
  • Event Policies and corresponding alerts that are triggered when devices in your VMAX or PowerMax system meet particular criteria
Installing the Dell EMC: VMAX and PowerMax Unisphere API PowerPack
Before completing the steps in this section, you must import and install the latest version of the Dell EMC: VMAX and PowerMax Unisphere API PowerPack.
