The following sections provide an overview of Dell EMC VNX and the EMC: VNX PowerPack:
What is Dell EMC VNX?
The Dell EMC VNX series is a family of unified hybrid flash storage arrays that combine block-based and file-based storage solutions in a single platform. VNX arrays use the EMC SMI-S Provider open storage management interface.
What Does the EMC: VNX PowerPack Monitor?
To monitor Dell EMC VNX systems using SL1, you must install the EMC: VNX PowerPack, which enables you to discover, model, and collect data about VNX storage arrays and file systems.
The EMC: VNX PowerPack requires EMC SMI-S Provider version 4.6.2 and higher, but less than version 8.0.
Monitoring VNX file systems is optional. If you choose to monitor file systems in addition to storage arrays, you must run a second discovery session to discover and model the file systems. For more information, see the section on Discovering Dell EMC VNX Devices.
The EMC: VNX PowerPack includes:
- An example credential you can use to create Basic/Snippet credentials to connect to Dell EMC VNX devices
- Dynamic Applications to discover and monitor VNX devices
- Device Classes for each type of VNX device monitored by SL1
- Event Policies and corresponding alerts that are triggered when VNX devices exceed thresholds for file system utilization.
- Dashboards that present summary information for VNX component devices
Installing the EMC: VNX PowerPack
