The following sections provide an overview of Dell EMC XtremIO and the Dell EMC: XtremIO PowerPack:
What is Dell EMC XtremIO?
Dell EMC XtremIO storage arrays use all flash technology and a scale-out design to provide high performance and consistent low latency. XtremIO provides enterprise features for data reduction, high availability, snapshots, and clones.
What Does the Dell EMC: XtremIO PowerPack Monitor?
To monitor Dell EMC XtremIO storage devices with SL1, you must install the Dell EMC: XtremIO PowerPack. This PowerPack lets you discover, model, and collect data about XtremIO storage devices.
The Dell EMC: XtremIO PowerPack includes:
- An example credential you can use as a template to create a SOAP/XML credential to connect to the XtremIO storage devices you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for XtremIO storage devices
- Device Classes for each of the XtremIO storage devices that SL1 monitors
- Event Policies and corresponding alerts that are triggered when XtremIO storage devices meet certain status criteria
Installing the Dell EMC: XtremIO PowerPack
