Configuring PowerFlow Applications for the ELK Stack SyncPack
This section describes how to set up the run book automations in Skylar One, and how to set up the PowerFlow applications for the "ELK Stack" SyncPack.
Configuring Skylar One
  1. Enable the ELK Stack event policies
  2. Create a SOAP/XML credential to access PowerFlow
  3. Edit the ELK Stack run book actions
  4. Enable the ELK Stack run book automations
  1. Create a PowerFlow configuration object
  2. Align and configure the ELK Stack PowerFlow applications
Enabling the ELK Stack Event Policies
The "ELK Stack Automation" PowerPack includes the following event policies that you can enable to trigger the events detected by the applications included in the "ELK Stack" SyncPack:
  • "ELK ExternalLog"
  • "ELK: Sync Skylar One Log"
  • "ELK: Search"
To enable the event policies:
  1. Go to the Event Policies page (Events > Event Policies, or Registry > Events > Event Manager in the classic SL1 user interface).
  2. Click the check boxes for all three event policies. A row of buttons appear at the top of the list.
  3. Click Enable. The Status for all three policies is updated to "Enabled".
You will need to create a SOAP/XML credential so that the action policies included in the "ELK Stack Automation" PowerPack can access your PowerFlow system.
  2. Locate the "ELK PowerFlow" sample credential, then click its Actions icon () and select Duplicate. A copy of the credential, called ELK PowerFlow copy appears.
  3. Select the new credential and complete the following fields:
  1. Click Save & Close .
  2. Take note of the Skylar One-assigned ID number for the new credential on the Credentials page, in the ID column. You will need the ID number when editing the input parameters of the run book actions included in the "ELK Stack Automation" PowerPack, below.
Editing the ELK Stack Run Book Actions
The "ELK Stack Automation" PowerPack includes three action policies:
  • "ELK: ExtLog"
  • "ELK: Index Create"
  • "ELK: Search"
These action policies use the corresponding "Run Integration Service Application" action type to trigger the PowerFlow application that collects data from the ELK Stack.
  2. Locate the ELK action policy that you want to use and click its wrench icon (). The Editing Action page appears.
Enabling the ELK Stack Run Book Automations
The "ELK Stack Automation" PowerPack includes the following run book automation policies that you can enable:
  • "ELK: ExtLog"
  • "ELK: Search"
These run book automation policies update the Skylar One event with the state of the associated ELK job. When a node is offline, a failure occurs, or a major event is detected in ELK, a Skylar One event is created and the associated event is updated with any job details.
  2. Locate an ELK automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the ELK automation policy you selected in step 2, and click the arrows to move it to Aligned Actions.
  2. Repeat steps 2-4 for the remaining ELK run book automation policies.
For this SyncPack, you should make a copy of the "ElasticSearch Logstash Kibana Configuration" configuration object, which is the sample configuration file that was installed with the  "ELK Stack" SyncPack.
The "ElasticSearch Logstash Kibana Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and ELK settings.
To create a configuration object based on the "ElasticSearch Logstash Kibana Configuration" configuration object:
  2. Click the Actions button () for the "ElasticSearch Logstash Kibana Configuration" configuration object and select Edit. The Configuration pane appears.
  1. In the Configuration Data field, include the required block of code to ensure that the applications aligned to the ELK configuration object is successful:
  • sl1_host. Type the hostname or IP address of the Skylar One system the alerts will synchronize with.
  • elk_username. Type the username for your ELK system.
  • elk_password. Type the password for your ELK system.
  • elk_document_url. Enter the URL for your ELK document.
  • ELK_Cloud_id. Type the ELK Cloud ID for login.
  • create_index_name. Type the name of the log data.
  • URI_for_log_data. Type the Log Data URL.
  • from_date. Type the start date in dd-mm-yyyy hh:mm:ss.
  • to_date. Type the end date in dd-mm-yyyy hh:mm:ss.
The following fields are required only if you choose to manually create a virtual device for your ELK instance:
  • device_class_id. Type the device class ID for your ELK instance.
  • collector_group_id. Type the collector group ID for your ELK instance.
  • device_id.Type the device ID for your ELK instance.
With this SyncPack, you can create Skylar One events based on ELK jobs. You will need to align the PowerFlow applications from the "ELK Stack" SyncPack with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
  1. On the Applications page of the PowerFlow user interface, open an ELK Stack PowerFlow application and click Configure. The Configurations pane for that application appears.
  1. Update the remaining fields on the Configurations pane as needed.
  2. Click Save to align that configuration with the application.
To create a schedule:
When either multiple Skylar One instances or multiple ELK instances are involved with PowerFlow, you should create an individual configuration object for each Skylar One or ELK instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or ELK instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
