Prerequisites for the Jira Service Management SyncPack
- The latest "Jira Service Management Automation Policies" PowerPack
- The latest "Skylar One Notifications Base" SyncPack
- Administrator access to Jira
- An IT Service Management Jira project to integrate with Skylar One
For the latest System Requirements, see the PowerFlow SyncPack Release Notes.
| Source IP | PowerFlow Destination | PowerFlow Source Port | Destination Port | Requirement |
| PowerFlow | Skylar One API | Any | TCP 443 | Skylar One API Access |
| PowerFlow | Jira API | Any | TCP 443 | Jira API Access |
| PowerFlow | Skylar One Database | Any | TCP 7706 | Skylar One Database Access |
Downloading and Installing the Jira Service Management SyncPack
Downloading the SyncPack
- Go to the SyncPacks page (Skylar Automation > SyncPacks).
- In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
- On the tab, click the down arrow next to the SyncPack version that you want to install, and select Show File Details. The Release File Details page appears.
- Click the button to download the SyncPack.
After you download the SyncPack, you can import it to your Skylar Automation system using the Skylar Automation user interface.
Importing the SyncPack
- On the SyncPacks page (
) of the Skylar Automation user interface, click . The Import SyncPack page appears.
- Click and select the .whl file for the SyncPack you want to install. You can also drag and drop a .whl file to the Import SyncPack page.
- Click . Skylar Automation registers and uploads the SyncPack. The SyncPack is added to the SyncPacks page.
- You will need to activate and install the SyncPack in Skylar Automation. For more information, see the following topic.
Installing the SyncPack
On the SyncPacks page of the Skylar Automation user interface, click the button (
If you do not see the SyncPack that you want to install, click the Filter icon (
- Click to confirm the activation and installation. When the SyncPack is activated, the SyncPacks page displays a green check mark icon (
) appears.
- For more information about the activation and installation process, click the highlighted version in the Installed SyncPack column for that SyncPack. For a successful installation, the "Activate & Install SyncPack" application appears, and you can view the Step Log for the steps. For a failed installation, go to the hidden "activate & Install SyncPack" application on the Applications page and check the step logs.
- If you have other versions of the same SyncPack on your Skylar Automation system, you can click the button (
Installing the Jira Service Management Automation Policies PowerPack
The "Jira Service Management Automation Policies" PowerPack includes automation policies and action policies that bidirectionally sync issues and events in Jira and Skylar One.
The " Jira Service Management Automation Policies" PowerPack requires Skylar One version 10.1.0 or later. For details on upgrading Skylar One, see the Skylar One Platform Release Notes.
- Search for and download the PowerPack from the PowerPacks page on the ScienceLogic Support Site (Skylar One > PowerPacks).
