Configuring PowerFlow Applications for the PagerDuty SyncPack
This section describes how to set up the run book automations in Skylar One and how to configure the PowerFlow applications in the "PagerDuty" SyncPack.
The following workflows describe how to configure Skylar One and PowerFlow to work with the "PagerDuty" SyncPack.
Configuring Skylar One
  1. Create a Basic/Snippet credential to access PowerFlow
  2. Edit the PagerDuty run book actions
  3. Enable the PagerDuty run book automations
  2. Align the configuration object and configure the PagerDuty PowerFlow applications
The following topics cover how to set up your Skylar One instance to work with the "PagerDuty" SyncPack:
Creating a Basic/Snippet Credential to Access PowerFlow
You will need to create a Basic/Snippet credential in Skylar One so that the action policies included in the "PagerDuty Incident Integration" PowerPack can access your PowerFlow system.
  2. Click Create New and select Create Basic/Snippet  Credential. The Create Credential window appears.
  • Name. Name of the credential. Can be any combination of alphanumeric characters. This field is required.
  • Timeout (ms). Time, in milliseconds, after which Skylar One will stop trying to communicate with the authenticating server.
  • Hostname/IP. Hostname or IP address of your PowerFlow system. This field is required.
  • Port. Type "443". This field is required.
  • Username. Username for a user account on the PowerFlow system.
  • Password. Password for a user account on the PowerFlow system.
When you define a Basic/Snippet credential, the credential will automatically be aligned with the organization(s) where you are a member. To learn more about credentials and organizations, see  Credentials
Editing the PagerDuty Run Book Action
The "PagerDuty Incident Integration" PowerPack includes the "PagerDuty: Trigger/Acknowledge/Resolve Alert" run book action. This action uses the "Run Integration Service Application" action type to trigger thePowerFlow application that sends events to PagerDuty. You can specify the credential ID and an optional platform identifier in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
To edit the "PagerDuty: Trigger/Acknowledge/Resolve Alert" run book action:
  2. Locate the "PagerDuty: Trigger/Acknowledge/Resolve/Alert" automation action, and then click its wrench icon (). The Editing Action page appears.
  • application_name. Leave the value as "send_sl1_events_to_pagerduty".
  • platform_identifier. Change the value to the unique identifier you created for each event sent to PagerDuty. This value must match the "platform_identifier" parameter in the PowerFlow configuration object that you configured for this Skylar One platform.
For more information on configuring the platform_identifier field in your PowerFlow applications, see Scheduling the PowerFlow Applications.
Enabling the PagerDuty Run Book Automations
The "PagerDuty Incident Integration" PowerPack includes the following automation policies:
  • "PagerDuty": Acknowledge Alert
  • "PagerDuty": Resolve Alert
  • "PagerDuty": Trigger Alert
These policies update the PagerDuty incident with the state of the event in Skylar One. When the event is first detected in Skylar One, the "triggered" state is sent. When the event is acknowledged in Skylar One, the "acknowledged" state is sent. When the event is cleared in Skylar One, the "resolved" state is sent.
  2. Locate a PagerDuty automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select the "Run Integration Service Application" action and click the arrows to move it to Aligned Actions.
  2. Repeat steps 2-4 for the remaining PagerDuty run book automation policies.
The following topics cover how to set up your PowerFlow instance to work with the "PagerDuty" SyncPack:
For this SyncPack, you can make a copy of the "PagerDuty Base Config" configuration object, which is the sample configuration file that was installed with the "PagerDuty" SyncPack. Then you can integrate one PagerDuty instance with multiple Skylar One instances by creating a separate configuration for each Skylar One instance.
The "PagerDuty Base Config" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and PagerDuty settings.
To create a configuration object based on the "PagerDuty Base Config" configuration object:
  2. Click the Actions button () for the "PagerDuty Base Config" configuration object and select Edit. The Configuration pane appears.
    • event_api. The URL of the PagerDuty event API for all PagerDuty instances. The default value is "https://events.pagerduty.com/v2/enqueue". You do not need to update this field.
    • integration_key. The routing/integration key to use when sending events.
    • For information on creating a PagerDuty service and accessing the integration key, see https://support.pagerduty.com/docs/services-and-integrations#create-a-new-service.
    • pd_base_url. The base URL of the PagerDuty REST API for all PagerDuty instances. The default value is "https://api.pagerduty.com". You do not need to update this field.
    • rest_api_key. The api key to use when syncing information to Skylar One from PagerDuty.
    • For more information on generating a PagerDuty REST API key, see https://support.pagerduty.com/docs/generating-api-keys#generating-a-general-access-rest-api-key.
    • sl1_host. The hostname or IP address of the Skylar One system the incident states will synchronize to.
    • proxy_host. The hostname or IP address of the HTTP proxy that will be used when making an API request to PagerDuty.
    • platform_identifier. The parameter that is appended to the event ID to create the PagerDuty dedup key. When you configure your Skylar One system to send event data to PagerDuty via PowerFlow, the "platform_identifier" parameter in the Run Book Action must match this value.
    • summary_string. The string that reflects how the summery field is constructed before it is sent to PagerDuty. You can use Run Book Variables to dynamically include Skylar One event data in the summary field. For example, the default value, "%S: %X: %M", includes the severity, affected device, and event message in the summary string.
    • For more information on Run Book Variables, see Run Book Variables.
    • custom_details. A structure of "key:value" pairs that can be used to provide additional Skylar One event data to PagerDuty. You can use Run Book Variables to dynamically include Skylar One event data in this field.
    • resolve_events. A value to indicate whether events should be resolved in Skylar One when the incident is resolved in PagerDuty. The default value is "False". If the value is "False", Skylar One events will not be automatically cleared in Skylar One when the corresponding PagerDuty incident is resolved.
    • link_events. A value to indicate whether events should be updated with the incident URL from PagerDuty. The default value is "True". If the value is "True", the External Ticket ID field will be updated with the ID and URL of the PagerDuty incident.
    • Skylar One supports only one value in this field. To avoid conflicts with other integrations, set this value to 'False' if your Skylar One system has been integrated with another incident management system, e.g. ServiceNow.
In PowerFlow, you will need to align the PowerFlow applications for PagerDuty with the relevant configuration object, and, if needed, update any other fields on the Configuration pane for the applications.
To run this SyncPack, you must "align" the configuration object you just created with the following PowerFlow applications:
  • "Clear resolve event from ScienceLogic"
  • "Get PagerDuty log and incident data"
  • "Get resolve alert data from PagerDuty"
  • "Get trigger alert data from PagerDuty"
  • "Get alert and user data from PagerDuty and ScienceLogic"
  • "Post event updates to ScienceLogic"
  • "Create event in PagerDuty from Skylar One event"
  1. On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click Configure. The Configurations pane for that application appears.
  2. Click Save.
Using the "PagerDuty Incident Integration" PowerPack, you can optionally configure a single PowerFlow instance and single PagerDuty instance with multiple Skylar One instances using the automation actions included in the PowerPack.
To run the automation, you must create a configuration object for each Skylar One instance and schedule the "Get PagerDuty log and incident data" application.
To create a schedule:
When either multiple Skylar One instance or multiple PagerDuty instances are involved with PowerFlow, you should create an individual configuration object for each Skylar One or PagerDuty instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or PagerDuty instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
