Installing the Restorepoint SyncPack
This section describes how to install the "Restorepoint" SyncPack and the "Restorepoint" PowerPack.
PowerFlow Skylar One API Any TCP 443 Skylar One API Access
PowerFlow Restorepoint API Any TCP 443 Restorepoint API Access
PowerFlow Skylar One Database Any TCP 7706 Skylar One Database Access
Installing the SyncPack
If you are upgrading to this version of the SyncPack from a previous version, make a note of any settings you made on the Configuration pane of the various integration applications in this SyncPack, as these settings are not retained when you upgrade.
Downloading the SyncPack
  2. Go to the SyncPacks page (Skylar Automation > SyncPacks).
  3. In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
After you download the SyncPack, you can import it to your Skylar Automation system using the Skylar Automation user interface.
Importing the SyncPack
  1. On the SyncPacks page () of the Skylar Automation user interface, click Import SyncPack. The Import SyncPack page appears.
  3. Click Import. Skylar Automation registers and uploads the SyncPack. The SyncPack is added to the SyncPacks page.
  4. You will need to activate and install the SyncPack in Skylar Automation. For more information, see the following topic.
Activating and Installing the SyncPack
  1. On the SyncPacks page of the Skylar Automation user interface, click the Actions button () for the SyncPack you want to install and select Activate & Install. The Activate & Install SyncPack modal appears.
    If you do not see the SyncPack that you want to install, click the Filter icon () on the SyncPacks page and select Toggle Inactive SyncPacks to see a list of the imported PowerPacks.
  2. For more information about the activation and installation process, click the highlighted version in the Installed SyncPack column for that SyncPack. For a successful installation, the "Activate & Install SyncPack" application appears, and you can view the Step Log for the steps. For a failed installation, go to the hidden "activate & Install SyncPack" application on the Applications page and check the step logs.
  3. If you have other versions of the same SyncPack on your Skylar Automation system, you can click the Actions button () for that SyncPack and select Change active version to activate a different version other than the version that is currently running.
Installing and Configuring the PowerPack
The following topics describe how to install and configure the "Restorepoint" PowerPack to work with the "RestorepointSyncPack.
Installing the PowerPack
The "RestorepointPowerPack includes the following tools, which you will use with the  "RestorepointSyncPack:
  • The "Restorepoint Connectivity" Dynamic Application, which tests SSH connectivity and indicates devices to be onboarded in Restorepoint.
  • The "Restorepoint Second Password" Dynamic Application, which allows you to align a second credential to a device. For example, if you are a Cisco user, you can configure the privileged password for your device.
  • Event policies for Restorepoint.
  • A "Restorepoint" device class.
  • A device group called "Restorepoint Devices", which includes a dynamic rule that matches devices with aligned Dynamic Applications, including the "Restorepoint Connectivity" Dynamic Application.
  • The Restorepoint MIB is available in your Restorepoint system. The MIB must be loaded before you can use the PowerPack. For more information, see Downloading and Compiling the Restorepoint MIB Files.
