Configuring PowerFlow Applications for the Salesforce Service Cloud SyncPack
This section describes how to set up the run book automations in Skylar One and how to configure the PowerFlow applications in the "Salesforce Service Cloud" SyncPack.
The following workflows describe how to configure Skylar One and PowerFlow to work with the "Salesforce Service Cloud" SyncPack.
Configuring Skylar One
  2. Edit the Salesforce run book actions
  3. Enable the Salesforce run book automations
  2. Align the configuration object and configure the Salesforce PowerFlow applications
The following topics cover how to set up your Skylar One instance to work with the "Salesforce Service Cloud" SyncPack.
Creating a SOAP/XML Credential to Access Skylar One PowerFlow
You will need to create a SOAP/XML credential so that the action policies included in the "Salesforce Service Cloud: Synchronization Policies" PowerPack can access your PowerFlow system.
You can use "PowerFlow SF Service Cloud" sample credential from te "Salesforce Service Cloud: Synchronization Policies" PowerPackas a template for a SOAP/XML credential.
  2. Go to the Credentials page (Manage > Credentials). Locate the "PowerFlow SF Service Cloud" sample credential, click its Actions icon (), and then select Duplicate. A copy of the credential, called PowerFlow SF Service Cloud copy appears.
Editing the Salesforce Run Book Actions
The "Salesforce Service Cloud: Synchronization Policies" PowerPack includes six action policies that you will need to enable.
These action policies use the "Run Integration Service Application" action type to trigger the PowerFlow application that sends and receives data to Salesforce Service Cloud: Synchronization Policies. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
  1. In Skylar One, go to the Action Policy Manager page (Registry > Run Book > Actions).
  2. Locate the Salesforce run book action policy that you want to use, and then click its wrench icon (). The Editing Action page appears.
Enabling the Salesforce Run Book Automations
The "Salesforce Service Cloud: Synchronization Policies" PowerPack includes six standard automation policies that you can enable.
These policies update the Salesforce case or incident with the state of the event in Skylar One. When an event is detected in Skylar One, a case or incident is triggered in Salesforce. When an event is acknowledged in Skylar One, the associated case or incident is updated in Salesforce. When an event is resolved in Skylar One, the associated case or incident is resolved in Salesforce.
The following table shows the automation policy, its default aligned events, and the automation action that runs in response to the events.
Automation Policy Name Aligned Events Automation Action
Salesforce Service Cloud: Acknowledge Case All events Salesforce Service Cloud: Acknowledge Case
Salesforce Service Cloud: Acknowledge Incident All events Salesforce Service Cloud: Acknowledge Incident
Salesforce Service Cloud: Resolve Case All events Salesforce Service Cloud: Resolve Case
Salesforce Service Cloud: Resolve Incident All events Salesforce Service Cloud: Resolve Incident
Salesforce Service Cloud: Trigger Case All events Salesforce Service Cloud: Trigger Case
Salesforce Service Cloud: Trigger Incident All events Salesforce Service Cloud: Trigger Incident
  2. Locate a "Salesforce Service Cloud" automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the Ansible automation policy you selected in step 2, and click the arrows to move it to Aligned Actions.
  2. Repeat steps 2-4 for the remaining "Salesforce Service Cloud" run book automation policies.
The following topics cover how to set up your PowerFlow instance to work with the "Salesforce Service Cloud" SyncPack.
To integrate Salesforce and Skylar One, you must create or use an existing application for Skylar One to communicate with. When creating or editing the Salesforce application, ensure that OAuth Settings are enabled and add the following OAuth Scopes:
  • Access Lightning applications (lightning)
  • Access Visualforce applications (visualforce)
  • Access content resources (content)
  • Manage user data via APIs (api)
  • Perform requests at any time (refresh_token, offline_access)
For this SyncPack, you can make a copy of the "Base Salesforce Configuration" configuration object, which is the sample configuration file that was installed with the " Salesforce Service Cloud" SyncPack.
The "Base Salesforce Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Salesforce settings.
To create a configuration object based on the "Base Salesforce Configuration" configuration object:
  2. Click the Actions button () for the "Base Salesforce Configuration" configuration object and select Edit. The Configuration pane appears.
  • sl1_host. Type the hostname or IP address of your Skylar One system.
  • salesforce_client_id. Type the consumer key for your Salesforce application.
  • salesforce_client_secret. Type the consumer secret for your Salesforce application.
  • salesforce_username. Type the username for your Salesforce system.
  • salesforce_password. Type the password for your Salesforce system.
  • add_template. Toggle the JSON editor to define the template to translate Skylar One event information to the subject of the Salesforce case or incident.
  • summary_template. Toggle the JSON editor to define the template to translate Skylar One event information to the description of the Salesforce case or incident.
  • populate_external_url. The option to add a Salesforce case or incident URL to the corresponding Skylar One event. The default value is 'enabled'.
  • salesforce_instance_url. Type the URL for your Salesforce system.
  • default_ack_user. Type the API command for the default user to acknowledge Salesforce cases or incidents.
  • resolve_from_sf. The option to allow Skylar One events to be resolved if they are resolved in Salesforce. The default value is 'enabled'.
With this SyncPack, any status changes made to a Skylar One event is sent to Salesforce to update the corresponding case or incident. Any status changes to the Salesforce case or incident are synchronized back to the corresponding Skylar One event. You will need to align the Salesforce applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
To run this SyncPack, you must "align" the configuration object to run with the PowerFlow applications included in this SyncPack.
  1. On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click Configure. The Configurations pane for that application appears.
    The values for salesforce_client_id and the other parameters that appear in the Configuration pane with a padlock icon () are populated by the configuration object you aligned with the application. Do not modify these values. If you encounter an error, make sure your configuration object is configured properly.
  2. Click Save.
To create a schedule:
When either multiple Skylar One instances or multiple Salesforce instances are involved with PowerFlow, you should create an individual configuration object for each Skylar One or Salesforce instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or Salesforce instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
