Installing the Events SyncPack
This section describes how to install the "ServiceNow Events" SyncPack and the other applications needed to use the SyncPack, including the "ScienceLogic Skylar One: Event Integration" application and the "ServiceNow Base Pack" PowerPack.
Skylar One and ServiceNow Terminology
The following table lists the different names for the shared elements in Skylar One and ServiceNow:
Skylar One ServiceNow
Asset, Custom Attribute
Asset (ITAM)
Device
CI (Configuration Item)
Discovery Session
Service Request, Catalog Request
Event
Incident, Event, or Case (depending on the SyncPack you are using)
Alert
Event
Organization
Company, Domain
Schedule, Maintenance Schedule
Change Request, Change Schedule
Topology, Relationships, Dynamic Component Mapping and Relationships (DCM+R)
Dependency View, Affected CIs
Dependency Map for ServiceNow SyncPacks
The following graphic describes which SyncPacks depend on other SyncPacks:
For more information about the "Base Steps" SyncPack, see Default SyncPacks.
Prerequisites for ServiceNow SyncPacks
This section describes the prerequisites for the ServiceNow SyncPacks. For more information about the specific software versions required by a ServiceNow SyncPack, see the latest release notes for this SyncPack on the Skylar Automation SyncPack Release Notes page.
To install any of the ScienceLogic ServiceNow SyncPacks, you must have administrator access to both Skylar One and ServiceNow. Specifically, you will need:
  • ScienceLogic administrator access to the Administration Portal
  • ServiceNow administrator access
If you want to upload and install multiple ServiceNow SyncPacks at the same time, you should upload all of the SyncPacks first, and then install them to address any dependencies between the SyncPacks.
The following table lists the port access required by Skylar Automation and this SyncPack:
Source IP Skylar Automation Destination Skylar Automation Source Port Destination Port Requirement
Skylar Automation Skylar One API Any TCP 443 Skylar One API Access
Skylar Automation ServiceNow API Any TCP 443 ServiceNow API Access
Downloading and Installing the SyncPack
  2. Go to the SyncPacks page (Skylar Automation > SyncPacks).
  3. In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
After you download the SyncPack, you can import it to your Skylar Automation system using the Skylar Automation user interface.
Importing the SyncPack
You must import and install the "ServiceNow Base" SyncPack before uploading and installing this SyncPack.
  1. On the SyncPacks page () of the Skylar Automation user interface, click Import SyncPack. The Import SyncPack page appears.
  3. Click Import. Skylar Automation registers and uploads the SyncPack. The SyncPack is added to the SyncPacks page.
  4. You will need to activate and install the SyncPack in Skylar Automation. For more information, see the following topic.
If you are upgrading to this version of the SyncPack from a previous version, make a note of any settings you made on the Configuration pane of the various PowerFlow applications in this SyncPack, as these settings are not retained when you upgrade.
  1. On the SyncPacks page of the Skylar Automation user interface, click the Actions button () for the SyncPack you want to install and select Activate & Install. The Activate & Install SyncPack modal appears.
    If you do not see the SyncPack that you want to install, click the Filter icon () on the SyncPacks page and select Toggle Inactive SyncPacks to see a list of the imported PowerPacks.
  2. For more information about the activation and installation process, click the highlighted version in the Installed SyncPack column for that SyncPack. For a successful installation, the "Activate & Install SyncPack" application appears, and you can view the Step Log for the steps. For a failed installation, go to the hidden "activate & Install SyncPack" application on the Applications page and check the step logs.
  3. If you have other versions of the same SyncPack on your Skylar Automation system, you can click the Actions button () for that SyncPack and select Change active version to activate a different version other than the version that is currently running.
Installing the ServiceNow Base Pack PowerPack in Skylar One
The "ServiceNow Base" Pack PowerPack version 103 or later contains run book automations that you use to integrate with the ServiceNow Events module.
By default, installing a new version of a PowerPack overwrites all content in that PowerPack that has already been installed on the target system. You can use the Enable Selective PowerPack Field Protection setting in the Behavior Settings page (System > Settings > Behavior) to prevent new PowerPacks from overwriting local changes for some commonly customized fields. For more information, see the section on Global Settings.
To install the "ServiceNow Base Pack" PowerPack:
  1. Search for and download the "ServiceNow Base Pack" PowerPack from the SyncPacks page on the ScienceLogic Support Site (Skylar Automation > SyncPacks).
  3. Click the Actions menu and choose Import PowerPack. The Import PowerPack modal appears.
  4. Click Browse and navigate to the "ServiceNow Base Pack" PowerPack file from step 1.
  5. Select the PowerPack file and click Import. The PowerPack Installer modal page displays a list of the PowerPack contents.
  6. Click Install. After the installation is complete, the "ServiceNow Base Pack" PowerPack appears on the PowerPacks page.
