Introduction to the Webex SyncPack
This section describes how you can use the "Webex" SyncPack to automatically create channels and trigger event messages from Skylar One to Webex. The integration is uni-directional between Skylar One and Webex.
This SyncPack uses the "Webex Automations" PowerPack.
The "Webex" SyncPack lets you create channels and trigger event messages from Skylar One to Webex. The integration is uni-directional between Skylar One and Webex.
This SyncPack includes the following integrations:
  • Create a Webex room from an event, and send a notification when a room has been created.
  • Synchronize an event update made in Webex with the event status in Skylar One.
  • Notify users of a "Major" event.
Contents of the SyncPack
This section lists the contents of the "Webex " SyncPack.
PowerFlow Applications
  • Create Room For Event. Creates a Webex room from an event.
  • Created Room Event Notification. Sends a notification when a room has been created.
  • Major Event Notification. Notifies users of a "Major" event.
  • Sync Event Status From Webex to Skylar One. This application synchronizes an event update made in Webex with the event status in Skylar One.
For more information about how to configure these applications, see Configuring the PowerFlow Applications for the Webex SyncPack.
Configuration Object
  • Sample Webex Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system.
Steps
  • Create Webex Room
  • Create Skylar One Payload
  • Delete Event From Skylar One
  • Fetch Room ID From Name
  • Fetch User Email
  • Fetch User Input
  • Invite Users To Room
  • Post Event Card To Webex
  • Post Update To Skylar One
