Configuring PowerFlow Applications for the xMatters SyncPack
This section describes how to set up the run book automations in Skylar One and how to configure the PowerFlow applications in the "xMatters" SyncPack.
The following workflows describe how to configure Skylar One and PowerFlow to work with the "xMatters" SyncPack.
Configuring Skylar One
  2. Edit the xMatters run book actions
  3. Enable the xMatters run book automations
  2. Align the configuration object and configure the xMatters PowerFlow applications
The following topics cover how to set up your Skylar One instance to work with the "xMatters" SyncPack.
You will need to create a SOAP/XML credential so that the run book actions included in the "xMatters Incident Integration" PowerPack can access your PowerFlow system. The "xMatters Incident Integration" PowerPack includes the "PowerFlow xMatters" credential, which you can use as a template for the SOAP/XML credential.
  • In Skylar One, go to the Credentials page (Manage > Credentials).
  • Click the wrench icon () for the "PowerFlow xMatters" credential. The Credential Editor modal window appears.
  • Complete the following fields:
Editing the xMatters Run Book Actions
The "xMatters Incident Integration" PowerPack includes four run book actions that you will need to enable.
These actions use the "Run Integration Service Application" action type to trigger the PowerFlow applications that send and receive data to and from xMatters. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
  2. Locate the xMatters run book action that you want to use, and then click its wrench icon (). The Editing Action page appears.
Enabling the xMatters Run Book Automations
The "xMatters Incident Integration" PowerPack includes four run book automation policies that you will need to enable.
These policies update the xMatters alert or Skylar One events with the state of the associated event or alert or populates Skylar One with on-call details. When the event is first detected in Skylar One or xMatters, the "triggered" state is sent. When the event is acknowledged in Skylar One or xMatters, the "acknowledged" state is sent. When the event is cleared in Skylar One or xMatters, the "resolved" state is sent. When on-call is triggered, the on-call details are added to the Skylar One event notes.
If you enable the "xMatters: Acknowledge Event", "xMatters: Resolve", and "xMatters: Trigger" automation policies, it is best practice to align the same devices for all three policies.
xMatters: Acknowledge Event All events xMatters: Acknowledgment
xMatters: Oncall All events xMatters: Resolve
xMatters: Resolve All events xMatters: Resolve
xMatters: Trigger All events xMatters: Trigger
  2. Locate the xMatters run book automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the xMatters run book automation policy that you selected in step 2, and click the arrows to move it to Aligned Actions.
  2. Repeat steps 2-4 for the remaining xMatters run book automation policies.
The following topics cover how to set up your PowerFlow instance to work with the "xMatters" SyncPack.
For this SyncPack, you can make a copy of the "Xmatters Config Template" configuration object, which is the sample configuration file that was installed with the " xMatters" SyncPack. Next, you need to align that configuration object to the relevant applications.
The "Xmatters Config Template" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and xMatters settings.
To create a configuration object based on the "Xmatters Config Template" configuration object:
  2. Click the Actions button () for the "Xmatters Config Template" configuration object and select Edit. The Configuration pane appears.
  • sl1_host. The hostname or IP address of the Skylar One system the alerts will synchronize to.
  • xmatters_alert_api_webhook. To send events to xMatters, you must configure a generic webhook workflow in xMatters. Enter the integration URL for that workflow.
  • xmatters_instance_url. The URL to use for links to the xMatters user interface. Enter the base URL you navigate to. This URL will be displayed in Skylar One and will open your xMatters instance in a browser.
  • proxy_host. The hostname or IP address of the HTTP proxy that will be used when making an API request to xMatters.
  • xm_user. The username for your xMatters system.
  • xm_password. The password for your xMatters system.
  • xm_group_id. The xMatters group ID you want to use.
  • resolve_from_xm. The option to resolve events from xMatters.
  • populate_external_url. The option to add an xMatters incident URL to the corresponding Skylar One event.
  • default_ack_user. The default user to acknowledge events in Skylar One.
With this SyncPack, any status changes made to a Skylar One event is sent to xMatters to update the corresponding incident. Any status changes to the xMatters incident are synced back to the corresponding Skylar One event. You will need to align the xMatters applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
  • "Bulk Resolve Skylar One Events"
  • "Get Acknowledged Incidents And Post Data To Skylar One"
  • "Get Oncall Details And Post Oncall List To Skylar One"
  • "Pass Acknowledgment details from Skylar One to Xmatters"
  • "Pass Resolution to Xmatters from RBA"
  • "Save Accounts to Cache"
  • "Get Event Details And Post Incident URL to Skylar One"
  1. On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click Configure. The Configurations pane for that application appears.
  2. Click Save.
To trigger some applications in this SyncPack, you must schedule the application. You must schedule the following applications if you want to trigger them:
  • "Get Acknowledged Incidents and Post Data to Skylar One"
  • "Save Accounts To Cache"
To create a schedule:
