Credentials for WMI and PowerShell Devices
This section describes how to configure credentials for WMI and PowerShell Dynamic Applications. It includes the following topics:
Configuring a WMI Credential
Although Skylar One supports WMI Dynamic Applications, ScienceLogic recommends that you use PowerShell Dynamic Applications where possible. PowerShell is the preferred management platform for Microsoft products.
If you configure your Windows system to respond to WMI requests from Skylar One, you can use WMI Dynamic Applications to collect information from your Windows system.
All of the WMI Dynamic Applications include a discovery object. If you include a credential for WMI Dynamic Applications in the discovery session that includes your Windows system, Skylar One will automatically align the appropriate WMI Dynamic Applications to the Windows system. For more information about creating a discovery session, see the Running a Discovery Session section.
To create a credential for a WMI Dynamic Application:
  2. Click the Create New button and then select Create Basic/Snippet Credential. The Create Credential modal page appears.
  • Timeout (ms). Time, in milliseconds, after which the platform will stop trying to communicate with the authenticating server.
  • Username. Username for a user account on the device. To specify a domain user, enter the username in the format DOMAIN\username. In most cases, you should use a domain user in the credential and use the format DOMAIN\username.
  • Password. Password for a user account on the device.
  • Hostname/IP. Hostname or IP address of the device from which you want to retrieve data. To use the same WMI default credential for multiple devices, enter the variable %D in this field.
  • Port. Port number associated with the data you want to retrieve. For WMI Dynamic Applications that perform WBEM requests, supply the port used by the WBEM service on the device. For WMI Dynamic Applications that perform WMI requests, which includes all default WMI Dynamic Applications in Skylar One, enter any valid port number in this field; the platform does not specify a port number when performing WMI requests.
Configuring a WMI Credential in the Classic Skylar One User Interface
You can create a credential for WMI Dynamic Applications from the Credential Management page.
To create a credential for a WMI Dynamic Application in the classic Skylar One user interface:
  2. Select the Create button in the upper right of the page. Select Basic/Snippet Credential.
  • Credential Name. Name of the credential. Can be any combination of alphanumeric characters.
  • Hostname/IP. Hostname or IP address of the device from which you want to retrieve data. To use the same WMI default credential for multiple devices, enter %D in this field.
  1. To save the credential, select the Save button. To clear the values you set, select the Reset button.
Configuring a PowerShell Credential
Configuring a PowerShell Credential in the Classic Skylar One User Interface
