Introduction to Dell EMC Unity Automations PowerPack
This section describes how to use the automation policies and run book actions found in the "Dell EMC Unity Automations" PowerPack.
Version 101 and later of the "Dell EMC Unity Automations" PowerPack includes updates for compatibility with Python 3. As a result, this version of the PowerPack runs only in a Python 3 execution environment.
What is the Dell EMC Unity Automations PowerPack?
The "Dell EMC Unity Automations" PowerPack includes automation policies that:
  • Enrich Skylar One events for Dell EMC devices (for example, from the "Dell: EMC Unity " PowerPack) by automatically running diagnostic commands from the Unisphere REST API and adding the output to the Skylar One event log or an associated incident.
The Dell EMC Unity Automations actions are executed on the Skylar One All-In-One Appliance or Data Collector.
Installing the Dell EMC Unity Automations PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Dell EMC Unity Automations" PowerPack.
Also, the following PowerPacks are prerequisites:
  • "Datacenter Automation Utilities" version 202 or later
  • "Dell EMC Unity" PowerPack version 103 or later
If you will have the " Dell EMC: Unity" PowerPack installed and are monitoring your Dell EMC devices, no other configuration is necessary. The automation policies in the "Dell EMC Unity Automations" PowerPack will run in response to aligned events.
