Introduction to Microsoft Hyper-V Automations
This section describes how to use the run book automation policies, run book actions, and custom action types found in the "Microsoft Hyper-V Automations" PowerPack. Installation of the "Windows PowerShell Automations" PowerPack is required before using the "Microsoft Hyper-V Automations" PowerPack.
Version 102 and later of the "Microsoft Hyper-V Automations" PowerPack includes updates for compatibility with Python 3. As a result, this version of the PowerPack runs only in a Python 3 execution environment.
What is the Microsoft Hyper-V Automations PowerPack?
The "Microsoft Hyper-V Automations" PowerPack includes:
  • A set of run book actions that run diagnostic commands on Hyper-V systems via PowerShell
  • A set of run book automation policies that tie events from monitoring PowerPacks to the automation actions
  • A dynamic device group for Hyper-V devices that is used to scope the automation policies
The run book actions in this PowerPack are executed on the Skylar One All-In-One Appliance or Data Collector.
In addition to using the standard content, you can use the content in the "Microsoft Hyper-V Automations" PowerPack to create your own automation policies that include the pre-defined actions that run different sets of diagnostic commands.
The "Microsoft Hyper-V Automations" PowerPack uses the supplied "Execute PowerShell Request" custom action type included with the "Windows PowerShell Automations" PowerPack.
Prerequisites
Before installing the "Microsoft Hyper-V Automations" PowerPack, you must perform the following actions:
  • Install version 202 or later of the "Datacenter Automation Utilities" PowerPack.
  • Install the "Microsoft: Hyper-V Server" PowerPack version 100 or later and configure it to monitor your Hyper-V devices.
  • Install version 105 or later of the "Windows PowerShell Automations" PowerPack .
Upgrading from a Previous Version of This PowerPack
If you are upgrading from a previous version of this PowerPack, you will need to execute the following SQL query on your Skylar One system to ensure that any run book actions on the Skylar One system from the previous versions of this PowerPack can receive updates after upgrading to this release.
To upgrade from a previous release:
  1. In Skylar One, go to the Database Tool page (System > Tools > DB Tool).
  2. Execute the following queries:
    UPDATE master.policies_actions SET action_guid ="DA83E56F17CD08430B91F64C5AAA345D" WHERE action_guid IN
    ("7EEE6230C4050096564969938AD9F07E")
    UPDATE master.policies_actions SET action_guid ="1C5EA01D9D944FEE3C7C2E196C5D162F" WHERE action_guid IN
    ("86324AFDAE1081C3A13ECEC93F6197FA");
Installing the PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Microsoft Hyper-V Automations" PowerPack.
Creating a Credential for Hyper-V Automation
The "Microsoft Hyper-V Automations" PowerPack uses the same credential that you created for the "Windows PowerShell Automations" PowerPack. Refer to the Creating a Credential section in the PowerShell Automations manual for more information.
If you have the "Microsoft: Windows Server" PowerPack installed and configured, you may skip this section.
For more information about configuring credentials in Skylar One, see Credentials.
