This PowerPack requires the "Datacenter Automation Utilities" PowerPack, version 103 or later.
What is the Restorepoint Automation PowerPack?
The "Restorepoint Automation" PowerPack includes automation policies that enrich Skylar One events for Restorepoint devices (for example, from the "Restorepoint" PowerPack) by automatically running diagnostic commands. The command output is added to the Skylar One event log or associated incident.
The Restorepoint run book actions are executed on the Skylar One All-In-One Appliance or Data Collector.
In addition to using the standard content, you can use the content in the "Restorepoint Automation" PowerPack to:
- Create your own automation policies that include the pre-defined actions that run different sets of diagnostic commands.
- Use the supplied "Restorepoint: Generic Action type" custom action type to configure your own automation action by supplying a set of commands.
Installing the Restorepoint Automation PowerPack
You must install the"Datacenter Automation Utilities" PowerPack version 103 before using the "Restorepoint Automation" PowerPack.
- Search for and download the PowerPack from the PowerPacks page on the ScienceLogic Support Site (Skylar One > PowerPacks).
Downloading and Compiling the Restorepoint MIB Files
After installing the PowerPack, you will need to download the following MIB files from Restorepoint and compile the MIB files in Skylar One:
- RESTOREPOINT-APPLIANCE-MIB.txt
- RESTOREPOINT-MIB.txt
You can access the Restorepoint MIB files from your Restorepoint system.
To download the MIB files in Restorepoint:
- In your Restorepoint system, go to the Systems Settings page (Administration > System Settings).
- Click the tab and navigate to the Download MIBs field.
- Click both of the MIB file names to download them to your local drive.
To compile the Restorepoint MIB files in Skylar One:
- Go to the MIB Compiler page (System > Tools > MIB Compiler) and click the button.
- In the MIB Import modal page, navigate to the location of the MIB file on your local computer and click the button. The new MIB file appears in the list of MIB files in the MIB Compiler page.
- Repeat steps 1-2 to upload the second MIB file.
- You must compile both MIB files before Skylar One can use them. To compile a MIB, click its lightning bolt icon (
). - To enable Restorepoint to send trap events to Skylar One, go to Administration > System Settings > Logs/Alerts in the Restorepoint user interface and change the following:
- SNMP Traps: Check this checkbox.
- SNMP Server: Enter the IP address of the Skylar One All-In-One or Data Collector.
