Reports for User Accounts
Skylar One (formerly SL1) allows you to generate reports based on user accounts. You can generate two type of reports based on user accounts:
  • A report based on all or multiple user accounts.
  • A report based on a single user account.
This section describes how to generate each type of report.
Generating a Report for Multiple User Accounts
From the User Accounts page you can generate a report that displays information for all or multiple user accounts in Skylar One. The report will contain all the information displayed in the User Accounts page.
To generate a report on all or multiple user accounts:
  2. In the User Accounts page, click the Report button. The Export current view as a report modal page appears.
    NOTE: If you want to include only certain interfaces in the report, use the "search as you type" fields at the top of each column. You can filter the list by one or more column headings. You can then click the Report button, and only the user accounts displayed in the User Accounts page will appear in the report.
  1. In the Export current view as a report modal page, you must select the format in which Skylar One will generate the report. Your choices are:
  • Web page (.html)
  • Open Document Spreadsheet (.ods)
  • Excel spreadsheet (.xlsx)
  • Acrobat document (.pdf)
  1. Click the Generate button. The report will contain all the information displayed in the User Accounts page. You can immediately view the report or save it to a file for later viewing.
Generating a Report for a Single User Account
You can also generate a report that displays information for a single user account in Skylar One.
To generate a report on a single user account:
  2. In the User Accounts page, find the account for which you want to generate a report. Click the account's wrench icon () or its business card icon ().
  3. Click the Report tab:
  4. An HTML report appears, populated with data from the selected user account. You can print the report or right-click to save the HTML page.
