Changing Name Servers on a Skylar One Appliance
Skylar One appliances include a local Domain Name Server (DNS) cache to improve performance. You can use the /etc/dnsmasq-resolv.conf file to change the DNS server information for the following Skylar One appliance types:
Database Servers
Data Collectors
Message Collectors
All-In-One Appliances
You do not need to edit the /etc/resolv.conf file, which should have a single entry of nameserver 127.0.0.1.
The following change procedure does not apply if you are running Skylar One on a cloud-based service like AWS or Azure. In that scenario, the DNS settings are provided automatically by DHCP, and configuration changes must be made in the DHCP provider’s settings.
Additionally, the following procedure does not apply to Administration Portals.
To update the name servers on most Skylar One appliance types:
Edit the /etc/dnsmasq-resolv.conf file by entering the following command:
sudo vi /etc/dnsmasq-resolv.conf
Change the nameserver entry in the file to the IP address of the new DNS or add new DNS entries to the file.
Save and quit to commit the changes. This change immediately causes the OS to use the new DNS, with no reboot or service restarts required. If you have multiple nameservers listed in the file, the system will try each entry in the list until it gets a response or runs out of nameservers.
Changing Name Servers on Administration Portals
For Skylar One Administration Portals, the Domain Name Server (DNS) server settings are configured at installation. You cannot adjust the DNS settings later through the Web Configurator. Instead, you must use the command line interface (CLI) to change the DNS server information. This action requires no downtime.
If you are running Skylar One on a cloud-based service like AWS or Azure, the following change procedures do not apply. The DNS settings are provided automatically by DHCP, and configuration changes must be made in the DHCP provider’s settings.
To change the DNS settings for Skylar One Administration Portals:
Edit the /etc/resolv.conf file by entering the following command:
sudo vi /etc/resolv.conf
Change the nameserver entry to the IP address of the new DNS or add new DNS entries to the file.
Next, add the DNS to the interface configuration file so that the change will persist if the network service is restarted or the Administration Portal is rebooted.
To add one or more domain name servers to the interface configuration file:
Either go to the console of the Administration Portal or use SSH to access it.
Log in as user em7admin with the appropriate password.
Determine the name of your primary interface (not the "lo" interface) by running the following command:
ip addr
Edit the corresponding interface configuration file in the /etc/sysconfig/network-scripts directory:
sudo vi /etc/sysconfig/network-scripts/ifcfg-{interface name}
Find the "DNS1" entry and change the IP address to the IP address of the new DNS.
You can enter additional DNS servers and define them as DNS2, DNS3, and so on.
- Save and quit to commit the changes.
Changing Hostnames on a Skylar One Appliance
To change hostnames on a Skylar One appliance:
Either go to the console of the Skylar One appliance or use SSH to access the server.
Set the hostname by running the following command:
sudo hostnamectl set-hostname <host.example.com>
Verify that the hostname was set:
hostnamectl hostnamectl Static hostname: host.example.com Icon name: computer-vm Chassis: vm Machine ID: 59013338cba643ec8ed2ec9883dfddf4 Boot ID: dde124fbc75c484ea7d71443277af659 Virtualization: vmware Operating System: Oracle Linux Server 7.9 CPE OS Name: cpe:/o:oracle:linux:7:9:server Kernel: Linux 3.10.0-1160.36.2.el7.x86_64 Architecture: x86-64The em7 service will notice this change and update the Appliances page (System > Settings > Appliances) in a few minutes.
Edit the /etc/hosts file to replace the old hostname with the new one:
sudo vi /etc/hosts
Restart the mysql service to update the database @@hostname, which is how the command-line Message of the Day (MOTB) pulls the active Database Server:
sudo systemctl restart mysql
You can also restart the task manager service to get the changes picked up more quickly:
sudo systemctl restart em7.service
