Change the IP Address for a Skylar One Appliance While Retaining the License
The IP address for an appliance is configured at installation. To change the IP address for an appliance after installation and preserve your Skylar One (formerly SL1) license, use the procedures in this section.
If you are running Skylar One on a cloud-based service like AWS or Azure, the following change procedures do not apply. The IP settings are provided automatically by DHCP, and configuration changes must be made in the DHCP provider’s settings.
Moving a Skylar One appliance to a new network requires pre-planning. If your Skylar One configuration includes one or more Administration Portals, PhoneHome Collectors, or is configured for High Availability or Disaster Recovery, you must perform additional steps after changing IP addresses. The steps in this section allow you to change the IP address for a Skylar One appliance with minimal downtime.
This procedure requires downtime, so plan to perform this procedure during a maintenance window.
Ensure console access to the appliance you are migrating in case of typographical or other errors that might prevent network access when changing IP addresses.
Changing the IP Address on an All-In-One Appliance
To change the primary IP address of an All-In-One Appliance :
Step 1. Stop the EM7 Service
Before changing the IP address, you must stop the EM7 service. To stop the EM7 service:
  1. Either go to the console of the Skylar One appliance or use SSH to access the server.
  2. Login as user em7admin with the appropriate password.
  4. sudo systemctl stop em7
Step 2. Change the IP Address in the silo.conf File
You must change the ipaddress value in the silo.conf configuration file.
  2. Type the following at the command line:
    sudo visilo
  1. Change the following line in the [LOCAL] section of the file to specify the new IP address:
    ipaddress = new_IP_address
  1. Save and quit the file (:wq).
Step 3. Change the IP Address in the /etc/hosts File
If the /etc/hosts file includes an entry for the appliance, update the entry with the new IP address.
    sudo vi /etc/hosts
  3. If you see an IP address for the All-In-One Appliance, change the IP address to the new IP address.
  4. Updating the /etc/hosts/ file automatically restarts the dnsmasq service to ensure the service can read the updated file.
Step 4. Change the IP Address in the Network Interface Configuration File
Be sure to set the IPADDR, PREFIX, GATEWAY and DNS# variables to the appropriate values for the new network. The PREFIX is the subnet mask in CIDR notation.
To change the IP address, Netmask, Gateway address, and DNS Server for an appliance in the ifconfig file:
    sudo ifconfig
  1. Your output will look like this:
    inet6 fe80::250:56ff:fe84:455f  prefixlen 64  scopeid 0x20<link>
    ether 00:50:56:84:45:5f  txqueuelen 1000  (Ethernet)
    RX packets 1774927  bytes 161985469 (154.4 MiB)
    RX errors 0  dropped 861  overruns 0  frame 0
    TX packets 1586042  bytes 158898786 (151.5 MiB)
    TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
    inet 127.0.0.1  netmask 255.0.0.0
    inet6 ::1  prefixlen 128  scopeid 0x10<host>
    loop  txqueuelen 0  (Local Loopback)
    RX packets 13406577  bytes 4201274223 (3.9 GiB)
    RX errors 0  dropped 0  overruns 0  frame 0
    TX packets 13406577  bytes 4201274223 (3.9 GiB)
  1. Examine the output, find the interface that uses the old IP address, and note its name.
  1. Use the vi editor to edit the settings for the interface. To do this, enter the following at the command line:
    sudo vi /etc/sysconfig/network-scripts/ifcfg-interface name you noted in step #5
    For example, from our output, we could enter:
    sudo vi /etc/sysconfig/network-scripts/ifcfg-ens32
  1. The ifcfg file will look like this:
    TYPE=Ethernet
    BOOTPROTO=none
    DNS1=10.64.20.33
    DEFROUTE=yes
    IPV4_FAILURE_FATAL=no
    IPV6INIT=yes
    IPV6_AUTOCONF=yes
    IPV6_DEFROUTE=yes
    IPV6_FAILURE_FATAL=no
    NAME=ens32
    UUID=d471435d-9adf-47c9-b3f3-32f61dccbad8
    DEVICE=ens32
    ONBOOT=yes
    IPADDR=10.64.68.20
    PREFIX=24
    GATEWAY=10.64.68.1
    IPV6_PEERDNS=yes
    IPV6_PEERROUTES=yes
  1. You can edit one or more of the following settings:
  • DNS1=IP address of the DNS server that will be used by the Skylar One appliance.
  • IPADDR=New IP address of the Skylar One appliance.
  • PREFIX=netmask for the Skylar One appliance.
  • GATEWAY=IP address of the network gateway that will be used by the Skylar One appliance.
  1. Save your changes and exit the file (:wq)
  2. At the command line, enter the following:
    service network restart
Step 5. Update the IP Address in the MySQL Database
In this step, you must set the new IP address in the master.system_settings_licenses table so that when Skylar One is restarted, the new IP address is recognized as licensed.
  3. Enter the following at the command line:
    silo_mysql
  4. At the mysql prompt, enter the following query:
    UPDATE master.system_settings_licenses SET ip="[new IP address]" WHERE ip="[old IP address]" LIMIT 1;
    [em7admin@hostname ~]$ silo_mysql
    MariaDB [(none)]> UPDATE master.system_settings_licenses SET ip="192.168.10.22" WHERE ip="10.1.1.240";
    Query OK, 1 row affected (0.01 sec)
    Rows matched: 1 Changed: 1 Warnings: 0
    MariaDB[(none)]>
  5. Type "exit" to exit the MySQL session.
Step 6. Reboot the Appliance
Reboot the appliance to apply all of the changes you made.
The system will boot up and will start the interface with the new IP address. Skylar One will start up and will learn from the database that the new IP address matches its configuration file and the value in the database table. Therefore, Skylar One will keep the current license for the appliance.
Step 7. Confirm the Change in Skylar One
After changing the IP address for your Skylar One appliance, go to the Appliance Manager page (System > Settings > Appliances) and confirm that the correct IP address for that appliance appears in the IP Address column. If it does not, you must update it.
Changing the IP Address on a Database Server
Changing the primary IP address of a Database Server requires additional steps if:
  • the Database Server resides in a High Availability configuration or a Disaster Recovery configuration
  • the Database Server might connect to Data Collectors configured for PhoneHome
In addition, when you change the primary IP address of a Database Server, you must update the configurations for any Data Collectors, Message Collectors and Administration Portals that communicate with that Database Server.
For Clustered Database Appliances (using HA, DR, or HA+DR), ScienceLogic recommends that you place the cluster into maintenance mode. Also, ScienceLogic recommends that you wait to wait to change the virtual IP address until all of the Database Servers have been moved to its new location, if applicable.
To change the IP address of a Database Server:
  1. Either go to the console of the Database Server or use SSH to access the server.
You must change the ipaddress value in the silo.conf configuration file. To do so:
  2. Enter the following at the command line:
  3. sudo visilo
  4. Change the following line in the [LOCAL] section of the file to specify the new IP address:
  5. Save and quit the file (:wq).
If the /etc/hosts file contains an entry for the appliance, update the entry with the new IP address.
    sudo vi /etc/hosts
  3. If you see an IP address for the Database Server, change the IP address to the new IP address.
    sudo ifconfig
  4. Your output will look like this:
    ens32: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500inet 10.64.68.20  netmask 255.255.255.0  broadcast 10.64.68.255
  5. Examine the output, find the interface that uses the old IP address, and note its name.
  6. Use the vi editor to edit the settings for the interface. To do this, enter the following at the command line:
  7. The ifcfg file will look like this:
    TYPE=Ethernet
    BOOTPROTO=none
    DNS1=10.64.20.33
    DEFROUTE=yes
    IPV6INIT=yes
    IPV6_AUTOCONF=yes
    IPV6_DEFROUTE=yes
    NAME=ens32
    DEVICE=ens32
    ONBOOT=yes
    IPADDR=10.64.68.20
    PREFIX=24
    GATEWAY=10.64.68.1
    IPV6_PEERDNS=yes
    IPV6_PEERROUTES=yes
  8. You can edit one or more of the following settings:
  • DNS1=IP address of the DNS server that will be used by the Database Server.
  • IPADDR=New IP address of the Database Server.
  • PREFIX=netmask for the Database Server.
  • GATEWAY=IP address of the network gateway that will be used by the Database Server.
    sudo service network restart
In this step, you must set the new IP address in the master.system_settings_licenses table so that when the Database Server is restarted, Skylar One recognizes the new IP address as licensed.
    silo_mysql
  1. At the mysql prompt, enter the following query:
    UPDATE master.system_settings_licenses SET ip="[new IP address]" WHERE ip="[old IP address] LIMIT 1"
    MariaDB[(none)]>
  2. Enter "exit" to exit the MySQL session.
Step 5a: For Database Servers Configured with PhoneHome
If your Database Server is configured with PhoneHome, perform the following additional steps to change the IP address of the Database Server.
If you add additional Database Servers with new IP addressees, wait for the Database Servers to migrate, and then the PhoneHome collectors will attempt to connect using the new Database Server IP addresses. After the databases reconnect, you can remove database entries with old IP addresses from the PhoneHome configuration.
    sudo phonehome status
    If you are planning to change the IP address of multiple Database Servers, you will want to update all of the relevant IP addresses in PhoneHome in this step.
  3. A table displaying the status of all PhoneHome collectors against all available databases appears. Note the Device ID for the Database Server.
  4. Run the phonehome destination add command to change the IP address for the device ID that corresponds to the Database Server. To do this, enter the following:
    sudo phonehome destination add <device_id> <new_ip_address>
  5. where:
    • <device_id> is the device ID you noted in step 3.
    • <new_ip_address> is the new IP address.
    Addresses should be in the format <host>:<port>. Host addresses can be IPv4 addresses or DNS names.
    sudo phonehome destination add 2 192.168.0.13:7705
  6. Repeat step 4 for every Database Server for which you want to change the IP address.
For more information about changing IP addresses for PhoneHome devices, see the section on Managing PhoneHome Destinations.
Step 5b For Clustered Database Appliances (using HA, DR, or HA+DR)
If your Database Servers are clustered for High Availability (HA), Disaster Recovery (DR), or both (HA+DR), to change the IP address of the Database Servers, you must also modify the clustering software configuration files, as described in this step.
    Changes to the running Cluster Resource Manager (CRM) configuration take effect immediately. ScienceLogic recommends that you wait to wait to change the virtual IP address until all of the Database Servers have been moved to its new location, if applicable.
  2. You must edit the settings for the virtual IP for the cluster. At the command line, enter the following:
    crm resource stop virtual_ip
    crm resource param virtual_ip set ip <new_IP_address>
    crm resource param virtual_ip set cidr_netmask <new_subnet_mask_in_CIDR_notation>
    crm resource start virtual_ip
  3. In a High Availability configuration, the two Database Servers use two rings:
  • ring0 defines the private interfaces that are connected directly to one another via crossover cable.
  • ring1 defines the public interfaces that host the virtual IP and conduct the Skylar One related tasks.
To update these values in a High Availability configuration, you must edit the file /etc/corosync/corosync.conf..
  1. Use a file editor like vi to edit /etc/corosync/corosync.conf.
  2. You will see something like this:
    nodelist {
     node {
      ring0_addr: 192.168.25.200
      ring1_addr: 10.1.20.25
      nodeid: 1
     node {
      ring0_addr: 192.168.25.201
      ring1_addr: 10.1.20.26
      nodeid:2
  3. For the Database Server with the new IP address, edit the value for ring0_addr to match the new IP address. Save the file.
    DRBD is the service that synchronizes the Database Servers in a High Availability or Disaster Recovery configuration. The DRBD file /etc/drbd.d/r0.res defines how data (on resource 0) is synchronized.
  • In Skylar One configured for High Availability , DRBD uses the private IPs to synchronize high-availability data.
  • In Skylar One configured for High Availability plus Disaster Recovery, DRBD uses the private interface to synchronize high-availability data and the virtual IP and the public IP addresses to synchronize data for disaster recovery.
  • In Skylar One configured for Disaster Recovery, DRBD uses the virtual IP and the public IP addresses to synchronize data.=
  1. Use a file editor like vi to edit /etc/drbd.d/r0.res. It will look something like this:
    resource r0 {
     protocol A;
     device /dev/drdb1;
     stacked-on-top-of r0-L {
      address 127.0.0.1:7789;
      proxy on hadrdb1 hadrdb2 {
       inside 127.0.0.1:7790;
       outside 192.168.25.200:7788;
    on hadrdb2
      disk /dev/mapper/em7vg-db;
      meta-disk internal;
      proxy on hadrdb3 {
       outside 192.168.25.201:7788;
  2. Replace instances of the old IP address with the new IP address and save the file.
  3. Shut down the Database Server .
  4. Upon reboot of the Database Server, run a discovery session to rediscover the Database Server with its new IP address.
Reboot the Database Server to apply all of the changes you made.
If you are migrating a High Availability cluster, shut down the secondary first, then the primary, so that Skylar One does not perform a failover. Restart up the primary first, and after it is up and running, restart on the secondary.
Step 7. Change the Database Appliance IP Address in the Administration Portals, Data Collectors, and Message Collectors
You must edit the configuration for each Skylar One node that communicates with the Database Server. To do so, perform the following steps on each Administration Portal, Data Collector, and Message Collector in your Skylar One system.
  1. You can log in to the Web Configuration Utility using any web browser supported by Skylar One. The address of the Web Configuration Utility is in the following format:
    For AWS instances, ip-address-of-appliance is the public IP for the AWS instance. To locate the public IP address for an AWS instance, go to AWS, go to the Instances page, and highlight an instance. The Description tab in the lower pane will display the public IP.
  1. When prompted to enter your user name and password, log in as the "em7admin" user with the appropriate password.
  2. After logging in, the main Configuration Utility page appears.
  1. Click the Device Settings button in the upper-right of the page. The Settings page appears.
  2. In the Settings page, enter the following:
  • Database IP Address. The new IP address of the Database Server.
  • Database Username. Username for the database account that the Administration Portal will use to communicate with the Database Server.
  • Accept the default values in all other fields.
  1. Click the Save button. You may now log out of the Web Configuration Utility.
Step 8. Confirm the Change in Skylar One
Changing the IP Address on a Data Collector or Message Collector
Whenever possible, ScienceLogic recommends that you simply create a new collector and decommission the old collector in a situation like this.
You can change the IP address of a Data Collector or Message Collector in two ways:
  • In the Web Configuration Utility
  • From the command line of the Data Collector or Message Collector
Regardless of the method you choose, Skylar One will automatically update the IP address of the Data Collector or Message Collector in:
  • /etc/silo.conf (this file should only be edited using the visilo command)
  • /etc/sysconfig/network-scripts/ifcfg-ens160
  • /etc/hosts
  • the master.system_settings_licenses table, in the ip column
The following sections explain the necessary steps.
Using the Web Configuration Utility to Change the IP Address of a Data Collector or Message Collector
  1. Select the Interfaces tab.
  2. In the Interfaces page, select the interface that you want to edit.
  3. Enter values in the following field:
  • Interface IP Address. Required. Enter the IP address for the bonded interface in standard IPv4, dotted-octet format.
  1. The IP address for the Data Collector or Message Collector will be automatically updated in all the necessary configuration file and database tables.
Using the Command Line to Change the IP Address of a Data Collector or Message Collector
  1. Either go to the console of the Data Collector or Message Collector or use SSH to access the server.
    sudo visilo
  3. At the shell prompt, enter:
    update_ip <interface_ID> <new_IP>
    • interface_ID is the name of the interface, usually ensn32 or ens160.
    • new_IP is the new IP address to assign to the interface.
  4. The IP address for the Data Collector or Message Collector will be automatically updated in all the necessary configuration file and database tables.
Confirming the IP Address Change on the Appliance Manager Page
After changing the IP address for your Skylar One appliance, go to the Appliance Manager page (System > Settings > Appliances) and confirm that the correct IP address appears for that appliance in the IP Address column.
If the Appliance Manager page does not display the new IP address, you can manually update the address. To do so:
  2. Click the wrench icon () of the appliance you want to update. Its values appear in the fields at the top of the page.
  3. In the IP Address field, type the new IP address.
  4. Click Save.
