This section describes the device-level and global settings that affect assets. It also describes how to customize fields and drop-down lists in asset records.
Device Settings That Affect Asset Records
The Device Investigator and the Device Properties page both include a field, Disable Asset Update, which allows you to disable the creation of or automatic updates to asset records for a specific device.
tab of theFor the selected device, this checkbox overrides any settings defined in the Asset Automation page (System > Settings > Assets).
To edit the Disable Asset Update field from the Device Investigator:
Go to the Devices page.
Locate the device you want to update this setting for and click its Device Name hyperlink. The Device Investigator for that device appears.
Click the
tab. -
Click
Do one of the following in the Disable Asset Update field:
Select the checkbox if you do not want SL1 to create or update asset records for that device.
Clear the checkbox if you want SL1 to create or automatically update the asset record associated with the device with any new information during hourly asset automation.
Click
To edit the Disable Asset Update field from the Device Manager page:
Go to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic SL1 user interface).
Locate the device you want to update this setting for and click its wrench icon (
). The Device Properties page for that device appears.
In the Preferences section, do one of the following in the Disable Asset Update field:
Global Settings That Affect Asset Records
In addition to the default asset record behavior settings that you can set on the Asset Automation page, the Behavior Settings page includes two fields that affect assets across your SL1 system.
To update these fields from the Behavior Settings page:
Update one or more of the following fields:
Enable Unique Asset Tag to Organization Constraint. Select this option if you want to prevent an asset from being moved to another organization if the new organization is already aligned to an asset with the same asset tag. Do not select this option if you want to allow assets with the same asset tags in the same organization. This field is selected by default.
Asset Warranty Expiry. Select the amount of time that should pass before SL1 generates an event to notify you that an asset's warranty is about to expire. The choices range from 1 day to 9 months.
Customizing Select Objects
SL1 allows you to customize the options, called select objects, that appear in the drop-down lists associated with assets. The following steps describe how to customize select objects.
- Navigate to the Select Objects Editor page (System > Customize > Selected Objects).
- In the upper right of the page, the Filter drop-down displays a list of entries that can be customized, separated by project area (such as "Assets"). Each entry in the drop-down list specifies the tab on which the drop-down list appears (such as "Properties"), and the name of the drop-down list (such as "Facility").
- The default asset drop-down lists you can customize are:
- Components tab
- Connect
- Type
- Configuration tab
- Asset Owner
- Function
- Installed Memory (Mb.)
- Operating System
- Service Status
- Licenses tab
- Product
- Networks tab
- Identification
- Speed
- Properties tab
- Facility
- Make
- Rack
- Shelf
- Zone
- Asset Owner
- To add a Select Object to a specific drop-down, select the field name for which you want to add an object. The Select Objects Editor is populated with the Select Objects already defined for the drop-down list.
- In the top pane, supply a Definition / Value for the desired Select Object and click .
- To delete a Select Object from the Select Objects Editor, click its bomb icon (
Asset Records can also be affected by a Device Template. With a Device Template, you can configure a device for nightly auto update, and can disable asset updates.
Customizing Form Fields
In addition to the default set of asset forms, you can add additional custom forms that will appear for all asset records. Custom forms are either embedded (appear in one of the default tabs) or tabbed (appear in a new, user-defined tab). You can define only one embedded asset form, which appears under the
tab. You can add as many tabbed forms as you need.As the embedded form has already been created in the
tab, the user can begin editing it with additional form fields that are not already included in the tab.To add a tabbed form:
- Navigate to the Application Forms page (System > Customize > Form Fields).
- Click the button. Enter values in the following fields:
- GUI Type. Select Tabbed.
- Form Type. Select Asset.
- Description. Enter a description for the tabbed form.
- The user now has two forms they can edit: The default embedded form, or the newly created tabbed form. Many of the same form fields are available in both options, although some are only available in the newly created tab.
- Click the wrench icon (
). The Editing Form page appears.
- The Editing Form page allows you to specify the layout and form fields that will appear on the custom form. The buttons allow you to add container elements that can be used to arrange the layout of the form fields.
- The Add Forms form fields and buttons allow you to add form fields to the custom forms. The options are:
- Form Name/Description. The name and description of the new form.
- Tab Label. The name of the tab that will hold the new form.
- VarChar32. A label that allows you to enter a string up to 32 alphanumeric characters in length.
- VarChar48. A label that allows you to enter a string up to 48 alphanumeric characters in length.
- VarChar64. A label that allows you to enter a string up to 64 alphanumeric characters in length.
- Float. Allows you to enter a floating-point number.
- Drop-Down. Allows you to add a drop-down box. An optional SQL query performed on SL1's database can be added to populate the drop-down list.
- Checkbox. Allows you to create a checkbox to toggle queries on or off. This option is only available in tabbed forms.
- Textbox Creates a blank text box that allows you to create notes. This option is only available in the tabbed form.
- Rich Text Area. Creates a blank text box that allows you to format the text in the text box. This option is only available in the tabbed form.
- Large RTxt Area. Creates a large blank text box that allows you to create notes. This option is only available in the tabbed form.
- Password. Allows you to create a password.
- Multiple. Allows you to create a multiple select list.
- Phone Number. Allows you to enter a phone number.
- Email Address. Allows you to enter an Email address
- Web Address. Allows you to enter a Web Address.
- Date. Allows you to enter a date.
- Date & Time. Allows you to enter a date and time.
- The Drag and Drop icon (
) allows you to rearrange the order of form elements and nest form fields inside container elements. To delete a form or container element, click its delete icon (
- You can further edit a form or container element using the following buttons:
- Clicking the button opens a new window showing what the new form will look like.
- To clear the form fields you have created and start over, click the button.
- To create and/or edit a guide for the new form, click the button.
- The Editing Form page. button clears any entries you have made and opens an empty
- To save the new form, click the button.
