Introduction to theAWS Incident Manager Automation PowerPack
This section describes how to use the automation policies and automation actions found in the AWS Incident Manager Automation PowerPack.
This PowerPack requires a subscription to ScienceLogic Standard solutions.
What is the AWS Incident Manager Automation PowerPack?
The AWS Incident Manager Automation PowerPack includes automation policies and actions that bidirectionally align incidents and events triggered and updated in Amazon Web Services (AWS) and SL1.
IMPORTANT: You must install and configure the AWS Incident Manager SyncPack version 1.0.0 and AWS Base Pack SyncPack version 1.0.0 before using the AWS Incident Manager Automation PowerPack.
Installing the AWS Incident Manager Automation PowerPack
Before completing the steps in this section, you must import and install the latest version of the AWS Incident Manager Automation PowerPack.
The AWS Incident Manager Automation PowerPack requires SL1 version 10.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
