For this SyncPack, you can make a copy of the "AWS Incidents Base Config" configuration object, which is the sample configuration file that was installed with the AWS Incident Manager SyncPack.
The "AWS Incidents Base Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and AWS settings.
For more information about the AWS terms and concepts in this section, see the AWS documentation.
To create a configuration object based on the "AWS Incidents Base Config" configuration object:
Click the button (
) for the "AWS Incidents Base Config" configuration object and select Edit. The Configuration pane appears:
Click . The Create Configuration pane appears.
- sl1_host. Type the hostname or IP address of the SL1 system the alerts will synchronize to.
- aws_region_name. Type the region of your AWS system.
- aws_access_key_id. Type the access key ID of your AWS system.
- aws_secret_access_key. Type the secret access key ID of your AWS system.
- aws_service. Keep the default value.
- aws_default_response_plan_arn_1. Type the ARN for the default AWS response plan for PowerFlow to use when creating an incident in AWS.
- add_template. Toggle the JSON editor to define the template to translate SL1 event information to an AWS incident.
- summary_template. Toggle the JSON editor to define the summary format to translate an SL1 event to an AWS incident.
- event_response_plan_map. You can configure specific SL1 event criteria to trigger alternative response plans in AWS. To define an alternative response plan, toggle the JSON editor and enter an event property, search key to match to the event, and the ARN for the alternative AWS response plan. For example, if you want to trigger an alternative response plan for an SL1 event that contains "database" in the event message, enter the JSON code as follows:
- resolve_from_aws. When enabled, this parameter resolves SL1 events from AWS incidents. The default value is 'enabled'. To disable this parameter, change this value to 'disabled'.
- populate_external_url. The option to add an AWS incident URL to the corresponding SL1 event. The default value is 'enabled'.
- time_delta. Type the time configuration in days to synchronize your AWS incidents and SL1 events. The "Bulk Resolve SL1 Events from AWS" application will only collect incidents that have been updated within the number of days defined in this parameter.
"event_property": "%M",
"response_plan": "arn:aws:ssm-incidents::XXXXXXXX:response-plan/XXXXXXXXX",
"search_key": "database"
With this SyncPack, any status changes made to an SL1 event are sent to AWS to update the corresponding incident. Any status changes to the AWS incident are synced back to the corresponding SL1 event. You will need to align the AWS Incident Manager applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- "Bulk Resolve SL1 Events From AWS"
- "Create Timeline Event In AWS Incident Manager"
- "Resolve AWS Incident"
- "Send SL1 Event to AWS Incident Manager"
- Wait until you see the "App & Config modifications saved" pop-up message before proceeding.
To trigger the "Bulk Resolve SL1 Events From AWS" application, you must schedule the application.
To schedule an application:
On the Applications page (
Click . The schedule is added to the list of schedules on the initial Schedule window. Also, on the Applications page, the word "Scheduled" appears in the Scheduled column for this application, and the button contains a check mark:
When either multiple SL1 instances or multiple AWS instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or AWS instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or AWS instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
