Configuring Applications for the Ansible SyncPack
This section describes how to set up the run book automations in SL1 and how to configure the PowerFlow applications in the "Ansible" SyncPack.
The following workflows describe how to configure SL1 and PowerFlow to work with the "Ansible" SyncPack.
Configuring SL1
  2. Enable the Ansible event policies
  3. Edit the Ansible action policies
  4. Enable the Ansible run book automation policies
Configuring PowerFlow
  1. Create and align a PowerFlow configuration object
  2. Configure the PowerFlow applications
Configuring SL1
The following topics cover how to set up your SL1 instance to work with the "Ansible" SyncPack.
You will need to create a SOAP/XML credential so that the action policies included in the "Ansible Automation" PowerPack can access your PowerFlow system.
  1. In SL1, go to the Credentials page (Manage > Credentials).
  2. Take note of the SL1-assigned ID number for the new credential on the Credentials page, in the ID column. You will need the ID number when editing the input parameters of the automation actions included in the "Ansible Automation" PowerPack.
Enabling the Ansible Event Policies
The "Ansible Automation" PowerPack includes two standard API event policies that you can enable to trigger the events detected by the applications included in the "Ansible" SyncPack and its associated automation action policy.
To enable the event policies:
  1. In SL1, go to the Event Policies page (Events > Event Policies).
  2. Click the check boxes for the "Ansible-Command" and "Ansible-Tower" event policies. A row of buttons appear at the top of the list.
  3. Click Enable. The Status for both policies is updated to "Enabled".
Editing the Ansible Run Book Action Policies
The "Ansible Automation" PowerPack includes two action policies:
  • Ansible: Command (triggers the "Call Playbook from Ansible CLI" application in PowerFlow)
  • Ansible: Tower (triggers the "Call Playbook from Ansible Tower" application in PowerFlow)
These action policies use the "Run Integration Service Application" action type to trigger the corresponding PowerFlow application that collects data from Ansible. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
  1. In SL1, go to the Actions page (Registry > Run Book > Actions).
  2. Locate the action policy that you want to use ("Ansible: Command" or "Ansible: Tower"), and then click its wrench icon (). The Editing Action page appears.
  • credential_id. Change the value to the credential ID that you noted earlier when creating a credential for your PowerFlow system. This parameter is required.
Enabling the Ansible Run Book Automation Policies
The "Ansible Automation" PowerPack includes two standard run book automation policies that you will need to enable, depending on which Ansible application you are monitoring:
  • Ansible:Command
  • Ansible:Tower
These policies update the SL1 event with the state of the associated Ansible Command or Ansible Tower.
To enable the run book automation policies:
  1. In SL1, go to the Automation page (Registry > Run Book > Automation).
  2. Locate the "Ansible:Command " automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select "Run Integration Service Application: Ansible:Command" (or "Ansible:Tower" for the "Ansible:Tower" automation policy) and click the arrows to move it to Aligned Actions.
  2. Repeat steps 2-4 for the "Ansible:Tower" run book automation policy.
The following topics cover how to set up your PowerFlow instance to work with the "Ansible" SyncPack.
For this SyncPack, you should make a copy of the "Sample Ansible Configuration" configuration object, which is the sample configuration file that was installed with the Ansible SyncPack.
The "Sample Ansible Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Ansible settings.
To create a configuration object based on the "Sample Ansible Configuration" configuration object:
  2. Click the Actions button () for the "Sample Ansible Configuration" configuration object and select Edit. The Configuration pane appears.
    • sl1_host. Type the hostname or IP address of the SL1 system the alerts will synchronize with.
    • sl1_password. Type the password for your SL1 system.
    • sl1_user. Type the username for your SL1 system.
    • ansible_url. Enter the URL for your Ansible system.
    • ansible_username. Type the username for your Ansible system.
    • ansible_password. Type the password for your Ansible system.
    • template_id. Type the Ansible Tower template ID. This field is only required if you are monitoring an Ansible Tower.
    • host_name. Type the host name for your Ansible system.
    • playbook. Type the name of your Ansible playbook.
    • inventory_id. Type the Ansible Tower inventory ID. This field is only required if you are monitoring an Ansible Tower.
    • credential_id. Type the Ansible Tower credential ID. This field is only required if you are monitoring an Ansible Tower.
    • ssh_username. Type your SSH username.
    • ssh_password. Type your SSH password.
    • host_name_status. Toggle on (blue) to enter the host name status from the event details.
    • ssh_pem_status. Toggle on (blue) to enter the SSH status from the event details.
    • ssh_pem. Enter the RSA key for SSH connection and type "\n" before and after your RSA key.
    • ssh_host. Type your SSH host name.
    • add_template. Toggle the JSON editor to define a message for the description field in the SL1 event.
For more information about the Ansible terms and concepts in this section, see the Ansible documentation.
In PowerFlow, you will need to align the "Ansible" SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
  1. On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click Configure. The Configurations pane for that application appears.
  2. Repeat this process for the other PowerFlow applications.
To trigger some applications in this SyncPack, you must schedule the application. If you want to use the following applications, you must schedule the application:
PowerFlow Application Recommended Schedule Time
Ansible Tower Job Status Update Every five minutes
Clear SL1 Events Every 10 minutes
To schedule an application:
  1. To delete the selected schedule, click Delete. The schedule is removed.
When either multiple SL1 instances or multiple Ansible instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Ansible instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Ansible instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
