Configuring Applications for the CrowdStrike Falcon SyncPack
This section describes how to set up the PowerFlow applications for theCrowdStrike Falcon  SyncPack.
For this SyncPack, you should make a copy of the "CrowdStrike Sample Configuration" configuration object, which is the sample configuration file that was installed with the CrowdStrike Falcon Automation SyncPack.
The "CrowdStrike Sample Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and CrowdStrike settings.
To create a configuration object based on the "CrowdStrike Sample Configuration" configuration object:
  2. Click the Actions button () for the "CrowdStrike Sample Configuration" configuration object and select Edit. The Configuration pane appears:
An image of the configuration object page.
  • sl1_host. Type the hostname or IP address of the SL1 system the alerts will synchronize with.
  • sl1_password. Type the password for your SL1 system.
  • sl1_user. Type the username for your SL1 system.
  • crowdstrike_url. Enter the URL for your CrowdStrike system.
  • crowdstrike_username. Type the username for your CrowdStrike system.
  • crowdstrike_password. Type the password for your CrowdStrike system.
  • job_name. Type the name for your CrowdStrike job.
  • receiver_mail. Type the email address that you want to receive updates on SL1 events and your CrowdStrike jobs.
  • sender_mail. Type the email address that you want updates on SL1 events and your CrowdStrike jobs to send from.
  • sender_mail_password. Type the password for the sender email address that you entered.
  • mailserver. Type the server for your sender email.
  • mailserverport. Type the port for your sender email.
The following fields are required only if you choose to manually create a virtual device for your CrowdStrike instance:
  • device_class_id. Type the device class ID for your CrowdStrike instance.
  • collector_group_id. Type the collector group ID for your CrowdStrike instance.
  • device_id.Type the device ID for your CrowdStrike instance.
For more information about the CrowdStrike terms and concepts in this section, see the CrowdStrike documentation.
With this SyncPack, you can create SL1 events based on CrowdStrike jobs. You will need to align the CrowdStrike Falcon Automationapplications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
  1. On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click Configure (). The Configurations pane for that application appears:
An image of the Configure Application page.
  2. Repeat this process for the other PowerFlow applications.
To create a schedule on PowerFlow version 2.5.0 and later:
  1. On the Applications page (), click the Schedule button for the application you want to schedule. The Scheduler window appears:
  1. In the Schedule List pane, click the down arrow icon () next to an existing schedule to view the details for that schedule.
  2. In the Schedule Creator pane, complete the following fields for the default Frequency setting:
To create a schedule on PowerFlow version 2.4.1 or earlier:
When either multiple SL1 instances or multipleCrowdStrike instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or CrowdStrike instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or CrowdStrike instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
