What is the ELK Stack AutomationPowerPack?
The ELK Stack Automation PowerPack includes automation policies and event policies that bidirectionally sync jobs, pipeline jobs, and node status between ELK and SL1 This PowerPack also comes with one example credential.
The ELK Stack Automation PowerPack includes:
- ELK: IndexCreate Run Book Automation policy
- ELK: ExtLog Run Book Automation policy
- ELK: Search in ELK in SL1 Run Book Automation policy
- ELK: ExternalLog event policy
- ELK: Sync SL1 Log event policy
- ELK: Search event policy
- PowerFlow ELK SOAP/XML Credentials
Installing the ELK Stack Automation PowerPack
IMPORTANT:: You must install and configure the ELK Stack SyncPack version 1.0.0 before using the ELK Stack Automation PowerPack.
The ELK Stack Automation PowerPack requires SL1 version 11.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
